MowingBar
How to install Geckodriver for Selenium
Sat Dec 03, 2016 10:25 am
Selenium recently updated and now requires Geckodriver to function correctly: https://github.com/mozilla/geckodriver/releases
I can't figure out how to install Geckodriver on raspbian. There are several examples I found on google but they don't work for me:
https://www.npmjs.com/package/geckodriver
http://askubuntu.com/questions/851401/w ... on-package
Does anyone know how to install Geckodriver on rasbian?
Re: How to install Geckodriver for Selenium
Sat Dec 03, 2016 5:00 pm
MowingBar wrote:Selenium recently updated and now requires Geckodriver to function correctly: https://github.com/mozilla/geckodriver/releases
I was under the impression geckodriver is installable via Firefox add-ons ????
MowingBar
Sat Dec 03, 2016 9:05 pm
I don't see it in the addon store for Firefox and the references in my opening post indicate that it needs to be installed manually.
Mayurshah
Sun Dec 04, 2016 6:34 pm
Download geckodriver from below location and add it to your PATH veriable.
Exit existing command line and reopen the same. This should help you.
Src
http://mayurshah.in/893/selenium-except ... executable
Maroun1
Tue May 30, 2017 12:34 pm
Good evening.
i have a question please.
how i can install a geckodrive on raspberry pi 3 ?
what is the steps ??
thank you d'advanced
nickradomus
Mon Jul 24, 2017 1:55 am
currently all that's available is geckodriver-v0.18.0-arm7hf.tar.gz . and it's targeted directly at ARM7, not ARM6 like the Raspberry Pi 3 uses. At this point in time you'd need to build it from source. Someone, please supply a tutorial to move this issue forward.
Mon Jul 24, 2017 9:06 am
nickradomus wrote:currently all that's available is geckodriver-v0.18.0-arm7hf.tar.gz . and it's targeted directly at ARM7, not ARM6 like the Raspberry Pi 3 uses. At this point in time you'd need to build it from source. Someone, please supply a tutorial to move this issue forward.
The Raspberry Pi 3B is ARMv8 :shock:
jaymz
Wed Dec 13, 2017 1:04 pm
I have a new raspberry pi 3, running raspbian 9.
I did the following, and it seems to work:
$ sudo apt-get upgrade
$ sudo apt-get update
$ sudo apt-get install iceweasel
$ sudo pip3 install selenium
$ curl -O https://github.com/mozilla/geckodriver/ ... 7hf.tar.gz
$ tar -xzvf geckodriver-v0.19.1-arm7hf.tar.gz
$ sudo cp geckodriver /usr/local/bin/
$ python3
>>> from selenium import webdriver
>>> browser = webdriver.Firefox()
and a browser pops up
Wed Dec 13, 2017 5:46 pm
$ python3
Why not use ""firefox-esr"" which is the actual package which replaces iceweasel:
https://packages.debian.org/stretch/iceweasel
https://packages.debian.org/stretch/firefox-esr
https://wiki.debian.org/Firefox
GolemuS
Tue Jun 02, 2020 11:58 am
Hello all
I just managed to install geckodriver with latest selenium v 3
by downloading firefox-esr ( 68.8.0esr-1~deb10u1+rpi1 )
then i downloaded the zip for gecko-dev ESR branch
https://codeload.github.com/mozilla/gec ... _RELBRANCH
and compiled according to
https://github.com/mozilla/geckodriver/issues/1628
sudo apt install -y gcc-arm-linux-gnueabihf libc6-armhf-cross libc6-dev-armhf-cross
git clone --depth=1 https://github.com/mozilla/gecko-dev
curl https://sh.rustup.rs -sSf | bash -s -- -v -y
declare -a bindirs=("$HOME/.cargo/bin")
if [[ "$(cat $HOME/.bashrc | grep -P "^PATH=" )" == "" ]]; then
  echo -e "PATH=\$PATH\n" >> $HOME/.bashrc
fi
for binfolder in "${bindirs[@]}"
do
  if [[ "$(cat $HOME/.bashrc | grep -P "^PATH=" | grep "${binfolder}:")" == "" ]]; then
    sed -i -e "s/^PATH=\"\(.*\)\"/PATH=\"$(echo "$binfolder" | sed "s/\//\\\\\//g"):\1\"/g" $HOME/.bashrc # place with no spaces in it
    export PATH="$PATH:$binfolder"
  fi
done
source $HOME/.bashrc
rustup target install armv7-unknown-linux-gnueabihf
echo -e "[target.armv7-unknown-linux-gnueabihf]
linker = \"arm-linux-gnueabihf-gcc\"" > "$HOME/gecko-dev/testing/geckodriver/.cargo/config"
cd "$HOME/gecko-dev/testing/geckodriver"
cargo build --release --target armv7-unknown-linux-gnueabihf
# test the binary executable with this command
$HOME/gecko-dev/target/armv7-unknown-linux-gnueabihf/release/geckodriver --version
pls enjoy my geckodriver binary tested both on raspberry 3B and 4 latest raspbian https://gofile.io/d/wlJvs0 with firefox-esr
Tanu Gupta
Fri Sep 18, 2020 7:09 pm
Firefox browser implements the WebDriver protocol using Gecko driver.
The below article provides the installation steps of Geckodriver with selenium
https://tequality.tech/course/selenium- ... owser.html
Hope it is useful :)
