Finally I can pair my Raspberry Pi 3 with my Android phone without any user intervention on the Pi.
To do this you need to :
1) Create a file called "/usr/local/bin/auto-agent" containing the following code.
#!/usr/bin/python
from __future__ import absolute_import, print_function, unicode_literals
from optparse import OptionParser
import sys
import dbus
import dbus.service
import dbus.mainloop.glib
try:
from gi.repository import GObject
except ImportError:
import gobject as GObject
import bluezutils
BUS_NAME = 'org.bluez'
AGENT_INTERFACE = 'org.bluez.Agent1'
AGENT_PATH = "/test/agent"
bus = None
device_obj = None
dev_path = None
def ask(prompt):
try:
return raw_input(prompt)
except:
return input(prompt)
def set_trusted(path):
props = dbus.Interface(bus.get_object("org.bluez", path),
"org.freedesktop.DBus.Properties")
props.Set("org.bluez.Device1", "Trusted", True)
def dev_connect(path):
dev = dbus.Interface(bus.get_object("org.bluez", path),
"org.bluez.Device1")
dev.Connect()
class Rejected(dbus.DBusException):
_dbus_error_name = "org.bluez.Error.Rejected"
class Agent(dbus.service.Object):
exit_on_release = True
def set_exit_on_release(self, exit_on_release):
self.exit_on_release = exit_on_release
@dbus.service.method(AGENT_INTERFACE,
in_signature="", out_signature="")
def Release(self):
print("Release")
if self.exit_on_release:
mainloop.quit()
in_signature="os", out_signature="")
def AuthorizeService(self, device, uuid):
print("AuthorizeService (%s, %s)" % (device, uuid))
return # automatically authorize connection
authorize = ask("Authorize connection (yes/no): ")
if (authorize == "yes"):
return
raise Rejected("Connection rejected by user")
in_signature="o", out_signature="s")
def RequestPinCode(self, device):
print("RequestPinCode (%s)" % (device))
set_trusted(device)
#return ask("Enter PIN Code: ")
return "0000" # return default PIN Code of 0000
in_signature="o", out_signature="u")
def RequestPasskey(self, device):
print("RequestPasskey (%s)" % (device))
set_trusted(device)
#passkey = ask("Enter passkey: ")
passkey = "0000" # return default passkey of 0000
return dbus.UInt32(passkey)
in_signature="ouq", out_signature="")
def DisplayPasskey(self, device, passkey, entered):
print("DisplayPasskey (%s, %06u entered %u)" %
(device, passkey, entered))
def DisplayPinCode(self, device, pincode):
print("DisplayPinCode (%s, %s)" % (device, pincode))
in_signature="ou", out_signature="")
def RequestConfirmation(self, device, passkey):
print("RequestConfirmation (%s, %06d)" % (device, passkey))
set_trusted(device)
return # automatically trust
confirm = ask("Confirm passkey (yes/no): ")
if (confirm == "yes"):
set_trusted(device)
return
raise Rejected("Passkey doesn't match")
in_signature="o", out_signature="")
def RequestAuthorization(self, device):
print("RequestAuthorization (%s)" % (device))
auth = ask("Authorize? (yes/no): ")
if (auth == "yes"):
return
raise Rejected("Pairing rejected")
def Cancel(self):
print("Cancel")
def pair_reply():
print("Device paired")
set_trusted(dev_path)
dev_connect(dev_path)
mainloop.quit()
def pair_error(error):
err_name = error.get_dbus_name()
if err_name == "org.freedesktop.DBus.Error.NoReply" and device_obj:
print("Timed out. Cancelling pairing")
device_obj.CancelPairing()
else:
print("Creating device failed: %s" % (error))
mainloop.quit()
if __name__ == '__main__':
dbus.mainloop.glib.DBusGMainLoop(set_as_default=True)
bus = dbus.SystemBus()
capability = "KeyboardDisplay"
parser = OptionParser()
parser.add_option("-i", "--adapter", action="store",
type="string",
dest="adapter_pattern",
default=None)
parser.add_option("-c", "--capability", action="store",
type="string", dest="capability")
parser.add_option("-t", "--timeout", action="store",
type="int", dest="timeout",
default=60000)
(options, args) = parser.parse_args()
if options.capability:
capability = options.capability
path = "/test/agent"
agent = Agent(bus, path)
mainloop = GObject.MainLoop()
obj = bus.get_object(BUS_NAME, "/org/bluez");
manager = dbus.Interface(obj, "org.bluez.AgentManager1")
manager.RegisterAgent(path, capability)
print("Agent registered")
# Fix-up old style invocation (BlueZ 4)
if len(args) > 0 and args[0].startswith("hci"):
options.adapter_pattern = args[0]
del args[:1]
if len(args) > 0:
device = bluezutils.find_device(args[0],
options.adapter_pattern)
dev_path = device.object_path
agent.set_exit_on_release(False)
device.Pair(reply_handler=pair_reply, error_handler=pair_error,
timeout=60000)
device_obj = device
else:
manager.RequestDefaultAgent(path)
mainloop.run()
#adapter.UnregisterAgent(path)
#print("Agent unregistered")
sudo chmod +x /usr/local/bin/auto-agent
import dbus
SERVICE_NAME = "org.bluez"
ADAPTER_INTERFACE = SERVICE_NAME + ".Adapter1"
DEVICE_INTERFACE = SERVICE_NAME + ".Device1"
def get_managed_objects():
manager = dbus.Interface(bus.get_object("org.bluez", "/"),
"org.freedesktop.DBus.ObjectManager")
return manager.GetManagedObjects()
def find_adapter(pattern=None):
return find_adapter_in_objects(get_managed_objects(), pattern)
def find_adapter_in_objects(objects, pattern=None):
for path, ifaces in objects.iteritems():
adapter = ifaces.get(ADAPTER_INTERFACE)
if adapter is None:
continue
if not pattern or pattern == adapter["Address"] or \
path.endswith(pattern):
obj = bus.get_object(SERVICE_NAME, path)
return dbus.Interface(obj, ADAPTER_INTERFACE)
raise Exception("Bluetooth adapter not found")
def find_device(device_address, adapter_pattern=None):
return find_device_in_objects(get_managed_objects(), device_address,
adapter_pattern)
def find_device_in_objects(objects, device_address, adapter_pattern=None):
path_prefix = ""
if adapter_pattern:
adapter = find_adapter_in_objects(objects, adapter_pattern)
path_prefix = adapter.object_path
device = ifaces.get(DEVICE_INTERFACE)
if device is None:
continue
if (device["Address"] == device_address and
path.startswith(path_prefix)):
return dbus.Interface(obj, DEVICE_INTERFACE)
raise Exception("Bluetooth device not found")
#!/usr/bin/python
# encoding=utf8
import sys
import time
import pexpect
import subprocess
class BtAutoPair:
"""Class to auto pair and trust with bluetooth."""
def __init__(self):
p = subprocess.Popen("/usr/local/bin/auto-agent", shell = False)
out = subprocess.check_output("/usr/sbin/rfkill unblock bluetooth", shell = True)
self.child = pexpect.spawn("bluetoothctl", echo = False)
def get_output(self,command, pause = 0):
"""Run a command in bluetoothctl prompt, return output as a list of lines."""
self.child.send(command + "\n")
time.sleep(pause)
start_failed = self.child.expect(["bluetooth", pexpect.EOF])
if start_failed:
raise BluetoothctlError("Bluetoothctl failed after running " + command)
return self.child.before.split("\r\n")
def enable_pairing(self):
"""Make device visible to scanning and enable pairing."""
print "pairing enabled"
try:
out = self.get_output("power on")
out = self.get_output("discoverable on")
out = self.get_output("pairable on")
out = self.get_output("agent off")
except BluetoothctlError, e:
print(e)
return None
def disable_pairing(self):
"""Disable devices visibility and ability to pair."""
try:
out = self.get_output("discoverable off")
out = self.get_output("pairable off")
print(e)
return None
#!/usr/bin/python
import BtAutoPair
autopair = BtAutoPair.BtAutoPair()
autopair.enable_pairing()
To check if it's working just run testAutoPair.py. You should then be able to pair your Pi to your phone without entering anything on the Pi.
If you are using legacy pairing then the code to enter on the phone is "0000".
You will need to install python-pexpect if it's not already installed.
sudo apt install python-pexpect
sudo apt install python-dbus
#DiscoverableTimeout = 0
A lot of the code for BtAutoPair.py was blatently ripped from https://gist.github.com/egorf/66d88056a9d703928f93
Cheers, Ian
