tensor
Please help: Pi3 Wifi not working: brcmfmac not loading
Wed Jan 11, 2017 6:45 pm
I want to use the Wifi on my brand new Pi3.
I flashed 2016-11-25-Jessie-lite to a 4 GB micro SD card.
After booting, iwlist wlan0 scan says "wlan0 Interface doesn't support scanning."
lsmod says
cfg80211              427855  0
rfkill                 16037  1 cfg80211
joydev                  9024  0
evdev                  11396  2
snd_bcm2835            20447  0
snd_pcm                75762  1 snd_bcm2835
snd_timer              19288  1 snd_pcm
snd                    51908  3 snd_bcm2835,snd_timer,snd_pcm
bcm2835_gpiomem         3040  0
bcm2835_wdt             3225  0
uio_pdrv_genirq         3164  0
uio                     8000  1 uio_pdrv_genirq
ipv6                  347594  30
modprobe brcmfmac inserts it, but iwlist still gives the same message.
Dmesg has not error or 'fail' messages. brcmfmac is not mentioned:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.34-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #930 SMP Wed Nov 23 15:20:41 GMT 2016
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 808c4f40, node_mem_map b9fa6000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22592 r8192 d22464 u53248
[    0.000000] pcpu-alloc: s22592 r8192 d22464 u53248 alloc=13*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x8c4f25c3 smsc95xx.macaddr=B8:27:EB:4F:25:C3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939064K/966656K available (6357K kernel code, 432K rwdata, 1716K rodata, 476K init, 764K bss, 19400K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
    lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x807ea674   (8074 kB)
      .init : 0x807eb000 - 0x80862000   ( 476 kB)
      .data : 0x80862000 - 0x808ce250   ( 433 kB)
       .bss : 0x808d1000 - 0x809901ec   ( 765 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000291] Console: colour dummy device 80x30
[    0.001345] console [tty1] enabled
[    0.001389] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001456] pid_max: default: 32768 minimum: 301
[    0.001793] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001837] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002790] Disabling cpuset control group subsystem
[    0.002846] Initializing cgroup subsys io
[    0.002897] Initializing cgroup subsys memory
[    0.002963] Initializing cgroup subsys devices
[    0.003006] Initializing cgroup subsys freezer
[    0.003049] Initializing cgroup subsys net_cls
[    0.003119] CPU: Testing write buffer coherency: ok
[    0.003209] ftrace: allocating 21236 entries in 63 pages
[    0.053289] CPU0: update cpu_capacity 1024
[    0.053356] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.053388] [bcm2709_smp_prepare_cpus] enter
[    0.053556] Setting up static identity map for 0x8240 - 0x8274
[    0.055253] [bcm2709_boot_secondary] cpu:1 started (0) 18
[    0.055469] [bcm2709_secondary_init] enter cpu:1
[    0.055513] CPU1: update cpu_capacity 1024
[    0.055519] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.055904] [bcm2709_boot_secondary] cpu:2 started (0) 18
[    0.056067] [bcm2709_secondary_init] enter cpu:2
[    0.056087] CPU2: update cpu_capacity 1024
[    0.056094] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.056459] [bcm2709_boot_secondary] cpu:3 started (0) 17
[    0.056589] [bcm2709_secondary_init] enter cpu:3
[    0.056610] CPU3: update cpu_capacity 1024
[    0.056616] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.056676] Brought up 4 CPUs
[    0.056775] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.056805] CPU: All CPU(s) started in HYP mode.
[    0.056832] CPU: Virtualization extensions available.
[    0.057461] devtmpfs: initialized
[    0.068389] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.068764] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.069501] pinctrl core: initialized pinctrl subsystem
[    0.070036] NET: Registered protocol family 16
[    0.075216] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.082123] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.082172] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.082345] Serial: AMBA PL011 UART driver
[    0.082496] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.082725] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.145448] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[    0.146052] SCSI subsystem initialized
[    0.146263] usbcore: registered new interface driver usbfs
[    0.146375] usbcore: registered new interface driver hub
[    0.146495] usbcore: registered new device driver usb
[    0.152848] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-11-25 16:03
[    0.180013] clocksource: Switched to clocksource arch_sys_counter
[    0.225127] FS-Cache: Loaded
[    0.225427] CacheFiles: Loaded
[    0.237787] NET: Registered protocol family 2
[    0.238666] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.238804] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.239015] TCP: Hash tables configured (established 8192 bind 8192)
[    0.239131] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.239199] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.239450] NET: Registered protocol family 1
[    0.239795] RPC: Registered named UNIX socket transport module.
[    0.239828] RPC: Registered udp transport module.
[    0.239856] RPC: Registered tcp transport module.
[    0.239884] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.240987] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.242340] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.255593] VFS: Disk quotas dquot_6.6.0
[    0.255925] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.258177] FS-Cache: Netfs 'nfs' registered for caching
[    0.259099] NFS: Registering the id_resolver key type
[    0.259161] Key type id_resolver registered
[    0.259190] Key type id_legacy registered
[    0.261552] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.261725] io scheduler noop registered
[    0.261760] io scheduler deadline registered (default)
[    0.261831] io scheduler cfq registered
[    0.264377] BCM2708FB: allocated DMA memory fac10000
[    0.264426] BCM2708FB: allocated DMA channel 0 @ f3007000
[    0.273170] Console: switching to colour frame buffer device 82x26
[    1.101720] bcm2835-rng 3f104000.rng: hwrng registered
[    1.104202] vc-cma: Videocore CMA driver
[    1.106584] vc-cma: vc_cma_base      = 0x00000000
[    1.108964] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.111263] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.113645] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.132715] brd: module loaded
[    1.143434] loop: module loaded
[    1.146360] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[    1.149929] Loading iSCSI transport class v2.0-870.
[    1.152736] usbcore: registered new interface driver smsc95xx
[    1.155003] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.357443] Core Release: 2.80a
[    1.359531] Setting default values for core params
[    1.361699] Finished setting default values for core params
[    1.564236] Using Buffer DMA mode
[    1.566404] Periodic Transfer Interrupt Enhancement - disabled
[    1.568648] Multiprocessor Interrupt Enhancement - disabled
[    1.570966] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.573227] Dedicated Tx FIFOs mode
[    1.575689] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac04000 dma = 0xfac04000 len=9024
[    1.580352] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    1.592197] dwc_otg: Microframe scheduler enabled
[    1.592251] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8044846c
[    1.594688] WARN::hcd_init_fiq:414: FIQ ASM at 0x804487dc length 36
[    1.597059] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb87e000
[    1.599415] dwc_otg 3f980000.usb: DWC OTG Controller
[    1.601747] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    1.604111] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    1.606435] Init: Port Power? op_state=1
[    1.608693] Init: Power Port (0)
[    1.611091] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.613403] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.615707] usb usb1: Product: DWC OTG Controller
[    1.617957] usb usb1: Manufacturer: Linux 4.4.34-v7+ dwc_otg_hcd
[    1.620254] usb usb1: SerialNumber: 3f980000.usb
[    1.623297] hub 1-0:1.0: USB hub found
[    1.625497] hub 1-0:1.0: 1 port detected
[    1.628123] dwc_otg: FIQ enabled
[    1.628133] dwc_otg: NAK holdoff enabled
[    1.628141] dwc_otg: FIQ split-transaction FSM enabled
[    1.628181] Module dwc_common_port init
[    1.628450] usbcore: registered new interface driver usb-storage
[    1.630846] mousedev: PS/2 mouse device common for all mice
[    1.633720] bcm2835-cpufreq: min=600000 max=1200000
[    1.636181] sdhci: Secure Digital Host Controller Interface driver
[    1.638438] sdhci: Copyright(c) Pierre Ossman
[    1.640987] sdhost: log_buf @ bac07000 (fac07000)
[    1.700044] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.704558] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    1.706853] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    1.757090] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.760131] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.760526] ledtrig-cpu: registered to indicate activity on CPUs
[    1.760640] hidraw: raw HID events driver (C) Jiri Kosina
[    1.760820] usbcore: registered new interface driver usbhid
[    1.760823] usbhid: USB HID core driver
[    1.761350] Initializing XFRM netlink socket
[    1.761381] NET: Registered protocol family 17
[    1.761521] Key type dns_resolver registered
[    1.762022] Registering SWP/SWPB emulation handler
[    1.762843] registered taskstats version 1
[    1.763017] vc-sm: Videocore shared memory driver
[    1.763026] [vc_sm_connected_init]: start
[    1.771453] [vc_sm_connected_init]: end - returning 0
[    1.772817] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    1.773159] of_cfs_init
[    1.773236] of_cfs_init: OK
[    1.800664] Waiting for root device /dev/mmcblk0p2...
[    1.802450] mmc0: new high speed SDHC card at address b368
[    1.803021] mmcblk0: mmc0:b368 NCard 3.69 GiB
[    1.806075]  mmcblk0: p1 p2
[    1.820131] Indeed it is in host mode hprt0 = 00021501
[    1.827787] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.831960] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.844643] devtmpfs: mounted
[    1.847574] Freeing unused kernel memory: 476K (807eb000 - 80862000)
[    2.000062] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.002592] Indeed it is in host mode hprt0 = 00001101
[    2.200336] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.202863] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.206133] hub 1-1:1.0: USB hub found
[    2.208701] hub 1-1:1.0: 5 ports detected
[    2.220548] random: systemd: uninitialized urandom read (16 bytes read, 38 bits of entropy available)
[    2.229743] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    2.235661] systemd[1]: Detected architecture 'arm'.
[    2.386705] NET: Registered protocol family 10
[    2.390985] systemd[1]: Inserted module 'ipv6'
[    2.395775] systemd[1]: Set hostname to <raspberrypi>.
[    2.490090] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.551267] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 64 bits of entropy available)
[    2.590377] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.593165] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.598738] smsc95xx v1.0.4
[    2.663669] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4f:25:c3
[    2.671817] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[    2.678875] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[    2.686192] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[    2.708939] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[    2.715833] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[    2.722405] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[    2.760074] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
[    2.768600] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[    2.775585] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[    2.902181] usb 1-1.4: New USB device found, idVendor=1a81, idProduct=1006
[    2.905726] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.909203] usb 1-1.4: Product: Wireless keyboard and mouse
[    2.912636] usb 1-1.4: Manufacturer: KYE
[    2.917299] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[    2.927955] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    2.941344] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    2.949889] input: KYE Wireless keyboard and mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1A81:1006.0001/input/input0
[    2.957109] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.963776] systemd[1]: Starting Remote File Systems (Pre).
[    2.970920] systemd[1]: Reached target Remote File Systems (Pre).
[    2.974286] systemd[1]: Starting Encrypted Volumes.
[    2.980909] systemd[1]: Reached target Encrypted Volumes.
[    2.984221] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    2.994620] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.001169] systemd[1]: Starting Swap.
[    3.007647] systemd[1]: Reached target Swap.
[    3.010740] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    3.010991] hid-generic 0003:1A81:1006.0001: input,hidraw0: USB HID v1.11 Keyboard [KYE Wireless keyboard and mouse] on usb-3f980000.usb-1.4/input0
[    3.022835] systemd[1]: Starting Root Slice.
[    3.028768] systemd[1]: Created slice Root Slice.
[    3.031583] systemd[1]: Starting User and Session Slice.
[    3.037438] systemd[1]: Created slice User and Session Slice.
[    3.040264] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    3.043395] input: KYE Wireless keyboard and mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1A81:1006.0002/input/input1
[    3.054568] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.057401] systemd[1]: Starting Delayed Shutdown Socket.
[    3.063266] systemd[1]: Listening on Delayed Shutdown Socket.
[    3.066089] systemd[1]: Starting Journal Socket (/dev/log).
[    3.072073] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.074941] systemd[1]: Starting udev Control Socket.
[    3.080704] systemd[1]: Listening on udev Control Socket.
[    3.083480] systemd[1]: Starting udev Kernel Socket.
[    3.089178] systemd[1]: Listening on udev Kernel Socket.
[    3.092026] systemd[1]: Starting Journal Socket.
[    3.097765] systemd[1]: Listening on Journal Socket.
[    3.100616] systemd[1]: Starting System Slice.
[    3.100771] hid-generic 0003:1A81:1006.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [KYE Wireless keyboard and mouse] on usb-3f980000.usb-1.4/input1
[    3.111469] systemd[1]: Created slice System Slice.
[    3.114154] systemd[1]: Starting File System Check on Root Device...
[    3.170543] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    3.176574] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.179367] systemd[1]: Starting system-getty.slice.
[    3.185496] systemd[1]: Created slice system-getty.slice.
[    3.188360] systemd[1]: Starting Increase datagram queue length...
[    3.196751] systemd[1]: Starting Restore / save the current clock...
[    3.231746] systemd[1]: Starting Load Kernel Modules...
[    3.240958] systemd[1]: Mounting Debug File System...
[    3.249528] systemd[1]: Starting udev Coldplug all Devices...
[    3.259202] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    3.271035] systemd[1]: Mounting POSIX Message Queue File System...
[    3.332579] systemd[1]: Started Set Up Additional Binary Formats.
[    3.335641] systemd[1]: Mounted Huge Pages File System.
[    3.338632] systemd[1]: Starting Slices.
[    3.344452] systemd[1]: Reached target Slices.
[    3.353263] systemd[1]: Mounted POSIX Message Queue File System.
[    3.359385] systemd[1]: Mounted Debug File System.
[    3.366529] systemd[1]: Started Increase datagram queue length.
[    3.387918] systemd[1]: Started Load Kernel Modules.
[    3.445759] systemd[1]: Started Restore / save the current clock.
[    3.453288] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    3.471309] systemd[1]: Time has been changed
[    3.495885] systemd[1]: Started File System Check on Root Device.
[    3.503397] systemd[1]: Started udev Coldplug all Devices.
[    3.628381] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.660873] systemd[1]: Mounting Configuration File System...
[    3.669397] systemd[1]: Mounted FUSE Control File System.
[    3.672855] systemd[1]: Starting Apply Kernel Variables...
[    3.682231] systemd[1]: Starting Syslog Socket.
[    3.688584] systemd[1]: Listening on Syslog Socket.
[    3.691560] systemd[1]: Starting Journal Service...
[    3.703383] systemd[1]: Started Journal Service.
[    3.863147] systemd-udevd[135]: starting version 215
[    4.149884] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    4.155473] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    4.536795] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.842672] systemd-journald[132]: Received request to flush runtime journal from PID 1
[    5.782274] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    5.782784] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.122382] uart-pl011 3f201000.uart: no DMA platform data
[    6.472675] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:217084k SSFS
[    6.542733] cfg80211: World regulatory domain updated:
[    6.542749] cfg80211:  DFS Master region: unset
[    6.542755] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    6.542763] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    6.542769] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    6.542776] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    6.542783] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    6.542791] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    6.542797] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    6.542803] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    6.542810] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    7.745314] random: nonblocking pool is initialized
[    7.857306] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    7.858525] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
I have tried many different things without success:
1. Added dtoverlay=mmc to /boot/config.txt so that sdhost is disabled.
2. Flashed the full Jessie. Then apt-get update and upgrade. Also ran rpi-update
wh7qq
Re: Please help: Pi3 Wifi not working: brcmfmac not loading
Wed Jan 11, 2017 8:58 pm
A properly working full jessie should find the on-board wlan0 automatically. You should not have to do anything to get it to work. If you did update and upgrade successfully, you must have had some connection. Was it ethernet? If still connected, it will bypass the wlan preferentially. What does the output of "ifconfig" look like?
I am unsure why you would bother with Jessie Lite on an RPi3. 8 and 16G SD cards are only marginally more expensive than 4G cards and just as fast. Also, do not expect a great range from the on-board wifi...the antenna is tiny and size definitely matters. Even if you are able to capture a signal, you may be slowed down by low signal strength.
tensor
Thu Jan 12, 2017 3:41 am
ifconfig only lists eth0 and lo.
Yes, ethernet works properly.
My preference is for jessie. But I used that SD card with my Pi 1-B for a few weeks. So I can't be certain that I did not break something on it.
I have tons of experience with Ubuntu and even Red Hat, so I'm comfortable not working with a GUI.
Thu Jan 12, 2017 2:05 pm
What have you got in /etc/modprobe.d? Is there anything in there that's blacklisting brcmfmac?
tensor
Thu Jan 12, 2017 2:12 pm
No, it's stock jessie:
The blacklist only contains PCI style framebuffer devices
/etc/modules and /etc/modules-load.d/ is effectively empty.
Thu Jan 12, 2017 4:06 pm
Are you getting the little yellow lightening flash on the screen?
tensor
Thu Jan 12, 2017 4:27 pm
No.
I'm using an official power supply (2.5A at 5.1V).
So I measured the voltage at pin 2. It's between 5.1 and 5.2 V during boot.
The voltage supplied to USB devices drops to 0 as part of the reboot process, but I suppose that's a documented feature.
asavah
Thu Jan 12, 2017 4:34 pm
Do you have these files ?
ls -al /lib/firmware/brcm/
-rw-rw-r-- 1 root root 369576 Jan 11 23:02 brcmfmac43430-sdio.bin
-rw-rw-r-- 1 root root   1108 Jan 11 23:02 brcmfmac43430-sdio.txt
tensor
Thu Jan 12, 2017 4:51 pm
Yes. My files are the same size and dated 7 Jun 2016.
tensor
Thu Jan 12, 2017 5:07 pm
From the output of modprobe -c , I conclude that the wifi device should be on the sdio bus.
But my /sys/bus/sdio/devices directory is empty. Is this the problem ?
tensor
Fri Jan 13, 2017 4:45 am
I played a bit in config.txt with the dtparams for the sd bus. I turned debugging on and off. I also underclocked the bus. It turns out it does not boot without DMA.
Then I restored everything. Now I get a consistent error message in dmesg:
mmc1: error -110 whilst initialising SDIO card
Then I found this thread, that indicates there is no fix:
viewtopic.php?t=140324&p=929964
Here is a more detailed thread:
viewtopic.php?p=1002526#p1002526
It's just not production quality. Supplier should identify these units and sell them at a discount.
I guess I'll need to buy a USB 802.11 unit.
