I JUST TRIED:
apt-get install python-mysql.connector
But got this error:
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-mysql.connector all 1.2.3-2
Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... -2_all.deb Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I tried apt-get update but failed similarly
Please help.
My original sense hat Pi SD Card died and I need to install a new Raspbian + python + mysql asap to reduce the down time of recording the air pressure.
Thanks in advance.
Re: is the raspian mirror server down?
It appears it is down- It was working about an hour or so ago. Give it a little time and try again.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
OK - I was about to post, asking if this was a systemic problem or just a "middle of the night problem" - i.e., a "try again later".
Here's the message I get when doing apt-get update:
root@jessie:/home/pi# apt-get update
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie Release.gpg
Unable to connect to mirrordirector.raspbian.org:http: [IP: 5.153.225.207 80]
Get:1 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
Get:2 http://archive.raspberrypi.org jessie/main Sources [54.8 kB]
Hit http://archive.raspberrypi.org jessie/ui Sources
Get:3 http://archive.raspberrypi.org jessie/main armhf Packages [136 kB]
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Fetched 214 kB in 6s (31.0 kB/s)
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg Unable to connect to mirrordirector.raspbian.org:http: [IP: 5.153.225.207 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
I'm having the same issue trying to install OpenVPN, booting from a fresh install of the 2017-01-11 release where the one and only setting that's been changed was to enable SSH.
Guess it's time to fire up a game and give this a shot tomorrow
There appears to be a glitch in the Matrix !!
Yup not working for me as well.
Same for me
This is the error:
Anyone know if there is a work around mirror?
This is the error:
Just done a fresh install.Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
You could (temporarily) change the URL in /etc/apt/sources.list to one of the mirrors: https://www.raspbian.org/RaspbianMirrorskazz wrote:Anyone know if there is a work around mirror?
It's back up...
it is finally normal now.
Not quite. Still reporting an issue for Jessie/ui sources
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
IIRC 'ui' is only on the RPF repo, not the Raspbian...SteveSpencer wrote:Not quite. Still reporting an issue for Jessie/ui sources
I don't get any errors on that BTW
To be clear,
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main Sources
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Err http://archive.raspberrypi.org jessie/ui Sources
406 Not Acceptable [IP: 46.235.227.11 80]
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/ui/source/Sources 406 Not Acceptable [IP: 46.235.227.11 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Steve S
Too bad. I turned out it was only partially normal. When I tried
apt-get install libmysqlclient-dev
it got another error:
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... u1_all.deb 404 Not Found [IP: 5.153.225.207 80]
Hope the admin notice this error and fix it soon.
- DougieLawson
Looks like the server is triksadecaphobic. Judging by today's date.
Or even friggatriskaidekaphobic / paraskevidekatriaphobicDougieLawson wrote:Looks like the server is triksadecaphobic. Judging by today's date.
looks like ther is a problem today
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... ce/Sources 406 Not Acceptable [IP: 93.93.128.230 80]
- ShiftPlusOne
Looks okay from this end.Paulwood wrote:looks like ther is a problem today
- ZzyzxWolfe
Paulwood wrote: ↑Wed Jan 18, 2017 1:32 pmlooks like ther is a problem today
With the "406 Not Acceptable" error with apt-get, it seems to happen when apt tries to resume a partial download and the server doesn't support it.
If you get the "406 Not Acceptable" error, you can fix it by deleting the partially downloaded files from inside /var/lib/apt/lists/partial.
You can delete the partial downloads by running:
sudo rm /var/lib/apt/lists/partial/*
sudo apt-get update
Hope this helps!
Cheers,
Zzyzx
“Don't lose your mind trying to set it free...”
http://mirrordirector.raspbian.org/raspbian/ is not working for me at the moment, so tried:DirkS wrote: ↑Fri Jan 13, 2017 11:06 amYou could (temporarily) change the URL in /etc/apt/sources.list to one of the mirrors: https://www.raspbian.org/RaspbianMirrorskazz wrote:Anyone know if there is a work around mirror?
deb http://raspbian.mirrors.wvstateu.edu/raspbian/ stretch main contrib non-free rpi
but that got a 404 on stretch/armhf
and then it also stuck on connecting to archive.raspberrypi.org
guess I'll have to go to work after all. I was contemplating "hookey" today.
