Currently I'm working on home automation system powered with an RPi 3B. I have two Arduino Nano based modules, one for measuring the temperature and humidity and one to control the outputs of custom-made 3-phase electricity monitoring unit. I want Arduinos to be connected to Pi via Ethernet while the Pi itself is connected wirelessly to WiFi router and to Internet.
What I have for now: static IPs for wlan0 and eth0 are set, the data from Arduino modules is coming by request from Pi and I am able to browse Internet from inside the Pi. BUT. I cannot SSH nor ping to it from the outside (from my PC via the same WiFi router). When I disconnect the Ethernet cable from Pi I CAN SSH and ping to it.
My config files:
/etc/dhcpcd.conf
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
# Custom static IP address for eth0.
interface eth0
static ip_address=192.168.0.200/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1
# Custom static IP address for wlan0.
interface wlan0
# Include files from /etc/network/interfaces.d:
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
update_config=1
country=UA
network={
ssid="<wlan_ssid_here>"
scan_ssid=1
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="<wlan_pwd_here>"
id_str="Aquarius"
priority=5
Linux raspberrypi 4.4.34-v7+ #930 SMP Wed Nov 23 15:20:41 GMT 2016 armv7l GNU/Linux
Struggling with it for the last eight days so any help is appreciated. Thanks.
