fluviolobo
Bluetooth adapter NOT found Raspberry Pi 3
Wed Jan 18, 2017 9:04 pm
I have been having some issue with the built-in Bluetooth adapter recently.
I have 5 raspberry pi 3s, 4 of them have had this issue.
I managed to fix 2 by following the instructions in this post http://forum.modmypi.com/technical-supp ... -t612.html
However, this did not exactly work on the last 4. I was wondering if there is anyone experiencing the following issues...
After booting the Bluetooth icon remains grey.
When running;
sudo bluetoothctl
No adapter information comes up
When running;
sudo hciconfig
The adapter information come sup but the status is "DOWN"
When trying to "reset" the adapter, I get a timeout error!!
Has anyone experienced this?
Douglas6
Re: Bluetooth adapter NOT found Raspberry Pi 3
Wed Jan 18, 2017 9:15 pm
What happens if you do
sudo hciconfig hci0 up
fluviolobo
Thu Jan 19, 2017 4:39 pm
I was getting that the device was "POWERING UP" but then nothing would happen on the screen.
I decided to revert Raspbian to the 2016-09 image and everything seems to be working fine.
I was hoping someone would point to a bug on the recent updates.
Nerdlinger
Tue Mar 07, 2017 3:09 pm
I just had this problem and this is what fixed it for me....
My pi said, "No Bluetooth Adapter Found"
You DO NOT have to re-image your SD card, but you should start clean and remove any fragments of the existing bluetooth program as it may be corrupted in some way if you were messing around with sudo nano inside the bluez service.
It is assumed that you press ENTER after each line...
sudo apt-get remove bluetooth bluez blueman
sudo apt-get autoclean
sudo apt-get update
sudo apt-get upgrade -y
sudo reboot
sudo apt-get install Bluetooth bluez blueman
sudo apt-get install bluez bluez-firmware
sudo systemctl daemon-reload
sudo systemctl restart bluetooth
sudo usermod -G bluetooth -a pi
sudo cat /etc/group | grep bluetooth
sudo reboot
sudo systemctl status bluetooth
...After doing all this, your bluetooth adapter should be fixed. Granted some of the steps above may not have been necessary, but I did them anyway just to make sure I took all the necessary steps.
I hope this helps.
jerseytechguy
Sun Jan 28, 2018 11:20 pm
I just tried this process and now the problem is worse. It's showing no bluetooth adapter found. Prior to this the adapter was at least being found.
Software Architect, Electronic Engineer, Car Enthusiast, Chef, Blogger, Paranormal Investigator (and Skeptic). I'm like MacGyver, Alton Brown, Doc Brown and Peter Venkman all in one.
dckornbluh
Sun Nov 18, 2018 11:39 pm
There's a typo in Nerdlinger's instructions. The 7th command should contain bluetooth with a lower-case 'b'.
In any case, this didn't help me either. When I do
as suggested by Douglas6, the response is "Can't get device info: No such device".
Douglas6
Sun Nov 18, 2018 11:53 pm
That response indicates that no HCI (Bluetooth) device can be found by the operating system. Could be a hardware error, and the Bluetooth chip is toast. Not likely, especially if WiFi is working. More likely is that the hciuart.service didn't run. Either it's missing, or encountered errors. First thing to do is check the results of
systemctl status hciuart
Post those here.
stuffmc
Tue Nov 20, 2018 8:00 pm
● hciuart.service
Loaded: masked (/dev/null)
Active: inactive (dead)
Douglas6
Tue Nov 20, 2018 8:39 pm
Ok, no idea why that service would be masked. You could try unmasking it
sudo systemctl unmask hciuart
and then rebooting.
Obrest
Thu Dec 27, 2018 4:16 pm
It's old topic but i got an answer -
sudo apt-get install pi-bluetooth
and bluetooth will be work -WITHOUT REBOOT!!! :D
