ICW
Touchscreen display and HDMI monitor [obsolete]
Wed Feb 15, 2017 1:23 pm
I have just got a 7" touchscreen display.
Once I have set this up with my pi 2, will I still be able to connect a normal monitor and keyboard to the pi 2 or will one of the screens then not work?
Any advice would be good.
Re: Touchscreen display and HDMI monitor
Wed Feb 15, 2017 1:49 pm
The HDMI display is normally disabled when the DSI 7" display is detected.
ktb
Wed Feb 15, 2017 4:47 pm
At least on the 4.9 kernel, using the vc4-kms-v3d overlay should support both HDMI and DSI connections at the same time. I didn't try messing around with the configuration very much, but I had dual screens working as extended-displays (not sure about mirroring). I tested it with LXDE, Pixel (IIRC) and Weston (weston-launch). There are some known (text/image quality and flickering) issues for DSI with the vc4-kms-v3d overlay. Another smaller issue is that it doesn't seem possible to rotate the console in an ideal way (at least for now). So if you normally use lcd_rotate=2 (not supported with vc4-kms-v3d) for the DSI touch display, you'll have the console on HDMI right side up and the console on DSI upside down. vc4-fkms-v3d does not support DSI and HDMI at the same time.
/home/pi/.config/autostart/lxrandr-autostart.desktop:
[Desktop Entry]
Type=Application
Name=LXRandR autostart
Comment=Start xrandr with settings done in LXRandR
Exec=sh -c 'xrandr --output Composite-1 --off --output HDMI-1 --mode 640x480 --pos 0x0 --rotate normal --output DSI-1 --mode 800x480 --pos 640x0 --rotate inverted'
OnlyShowIn=LXDE
/boot/cmdline.txt:
video=HDMI-1:640x480M@60m video=DSI-1:800x480M@60m net.ifnames=0 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
/boot/config.txt (vc4-kms-v3d enabled):
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=sd_overclock=63
dtparam=audio=on
audio_pwm_mode=2
enable_uart=1
lcd_rotate=2
ignore_lcd=0
gpu_mem=32
dtoverlay=vc4-kms-v3d,cma-256,rpi-ft5406
#gpu_mem=128
#dtoverlay=vc4-fkms-v3d,cma-192,rpi-ft5406
arm_freq=1200
arm_freq_min=600
core_freq=250
core_freq_min=250
h264_freq=300
isp_freq=250
v3d_freq=500
avoid_pwm_pll=1
sdram_freq=450
sdram_schmoo=0x02000020
over_voltage=2
over_voltage_sdram=2
decode_MPG2=0x3ab16f03
decode_WVC1=0x438a78fb
Wed Feb 15, 2017 6:35 pm
The biggest problem with that is that vc4-fkms-v3d is NOT READY for prime-time. It's still very much experimental.
ICW
Wed Feb 15, 2017 6:43 pm
DougieLawson wrote:The HDMI display is normally disabled when the DSI 7" display is detected.
If HDMI is normally disabled on detection of DSI 7" display, is it easy to change a setting to "enable" so that I do not have to keep disconnecting the DSI if I want to use a full size monitor?
ktb
Wed Feb 15, 2017 7:11 pm
You can try adding ignore_lcd=1 to config.txt
Wed Feb 15, 2017 7:17 pm
Nobody knows.
harish49477`
Mon Feb 20, 2017 6:42 pm
Hi is it possible to run DSI raspberry pi 7inch display as main display and HDMI for projector as extended display using Raspberry pi 3 , OS raspbian jessie pixel
Mon Feb 20, 2017 7:54 pm
I refer you to my previous answer.
Nobody knows.
ktb
Mon Feb 20, 2017 8:24 pm
Yes, but it's not really worth using it that way at this point in time.
harish49477`
Tue Feb 21, 2017 4:18 am
hi pls go through the video this person managed to do it https://www.youtube.com/watch?v=d2ouG1VmD88&t=1269s
ktb
Tue Feb 21, 2017 4:30 am
1. That is not the Official 7" DSI Touch Display
2. They are not using a VC4 overlay.
What is your point?
harish49477`
Tue Feb 21, 2017 4:47 am
ya true its not for Official 7" DSI Touch Display. Im asking whether we can achieve this type of the extended display, and earlier you mentioned {Yes, but it's not really worth using it that way at this point in time}. can i know y
ktb
Tue Feb 21, 2017 5:05 am
harish49477` wrote:ya true its not for Official 7" DSI Touch Display. Im asking whether we can achieve this type of the extended display, and earlier you mentioned {Yes, but it's not really worth using it that way at this point in time}. can i know y
I mentioned why it's not worth using it in my first post in this thread. To get the DSI touch display and another HDMI display working at the same time, you need to use the vc4-kms-v3d overlay and currently using that overlay with the DSI touch display results in a flickering picture, poor text/image/anti-aliasing quality on the DSI screen while the HDMI screen will look good. I also mentioned another smaller issue, but you can go back and read that if you are interested.
I'm not sure why Dougie felt the need to provide "definitive" answers to questions on a topic with which he apparently lacks experience. You'll have to ask him.
Tue Feb 21, 2017 4:49 pm
Ah ha, finally we've found the expert that knows. This piece of information has been carefully hidden from the whole population of Official RPF 7" screen users for too long.
I've not yet even thought of using that vc4-kms-v3d stuff because it appears to be too experimental for general use.
So the definitive answer is "This is not possible with stock standard, fully supported, generally available firmware."
harish49477`
Fri Feb 24, 2017 4:11 am
Hi guys i have not tried this but pls go through the link https://github.com/thesawolf/RK3188-kernel-builder
ktb
Fri Feb 24, 2017 4:23 am
harish49477` wrote:Hi guys i have not tried this but pls go through the link https://github.com/thesawolf/RK3188-kernel-builder
I don't understand why you posted this link. It's the GitHub repo for a kernel build script that supports three devices which have a RockChip RK3188 SoC -- https://en.wikipedia.org/wiki/Rockchip#RK31xx_series.
Current Devices supported:
Tronsmart MK908
Tronsmart T428
Imito QX-1
Those are Android TV stick/box devices. Do you have a question about those devices?
harish49477`
Fri Feb 24, 2017 4:43 am
sorry i was not aware of the Current Devices supported,
Tronsmart MK908
Tronsmart T428
Imito QX-1
thank you for letting me know
pls go through this link
https://groups.google.com/forum/#!topic ... NZT1aG8zqA
ktb
Fri Feb 24, 2017 4:51 am
I'm aware of the various partially-working Android builds for Pi. Do you have a question?
harish49477`
Tue Feb 28, 2017 3:55 pm
ktb wrote:I'm aware of the various partially-working Android builds for Pi. Do you have a question?
I wanted to run this dual screen project so that i can use my b9 3d printer using raspberry pi 3 and i also failed to install the b9 application on raspbian jessie. Can u help in installing (https://github.com/yuenar/B9Creator-QT5.X) pls
ktb
Tue Feb 28, 2017 4:48 pm
I'll try if you make your own new thread about it.
harish49477`
Tue Feb 28, 2017 5:03 pm
Hi ktb
I have make a new thread about how to install b9 application on raspbian jessie
in the following link viewtopic.php?f=63&t=175850
GettingGreyer
Mon May 20, 2019 10:21 pm
Rekindling this old debate:
1. I believe that the Noobs install does run both displays. The Img install does not.
Why do I think this? I did Noobs yesterday and today I did the img install using balenaEtcher.
I might be mistaken.... :lol:
JimBurke
Wed Jul 08, 2020 6:48 am
I'm trying to drive both the "official" 7" touch-screen monitor as well as a large HDMI display.
However I'm running this on a (Buster) headless operating system, with X server running. The code is in Java (plus JavaFX).
Does anyone know if this is possible ?
Many thanks,
Jim
Wed Jul 08, 2020 10:05 am
Many thanks,
Jim
Start a new thread. Too much has changed with the RPi4, RaspiOS and the video stuff for this to be in any way related to this original RPi3 thread.
You also need to tell us what RPi you're running on.
