LetHopeItsSnowing
Error installing dbus-python
Mon Mar 27, 2017 8:44 am
Im build a python package which uses the dbus-python package, but I'm having problems installing it from pip.
sudo pip3 install dbus-python3
Errors with:
checking for DBUS... no
configure: error: Package requirements (dbus-1 >= 1.6) were not met:
No package 'dbus-1' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables DBUS_CFLAGS
and DBUS_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I can install it from apt-get but I want to make dbus-python a dependency for my pip package installer.
Any ideas? Thanks
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
LetHopeItsSnowing
Re: Error installing dbus-python
Mon Mar 27, 2017 4:05 pm
Not to worry...
I have been pointed in the right direction. For others who find yourself in this situation, dbus-python is now obsolete, you should be using pydbus:
sudo pip3 install pydbus
Return to “Python”
