Donni H
Installing Discord On Raspberry Pi
Tue Apr 04, 2017 11:43 pm
A very popular chatting app, called Discord has been lauched for over two years now. They also have a linux file. I've tried several times to install it on my pi. Has anyone been able to successfully install it? If so can you please provide the steps. Thank you!
Donni
Re: Installing Discord On Raspberry Pi
Tue Apr 04, 2017 11:54 pm
Donni H wrote:Hello,
Donni
On the downloads page it states 64bit Linux, which is x86-64 CPU
The Raspberry Pi has an ARM CPU, so not surprising incompatible.
Donni H
Wed Apr 05, 2017 12:13 am
Oh, I see. Thanks.
nex86
Fri Aug 11, 2017 2:39 am
why though? I thought its all written in java script ?
https://www.reddit.com/r/discordapp/com ... f_discord/
guessing its the modules for audio that needed to be executed on X86..
Heater
Fri Aug 11, 2017 4:26 am
Java never works everywhere. Despite what they advertise.
Slava Ukrayini.
nex86
Fri Aug 11, 2017 7:18 pm
I got the web version to work. its somewhat usable. feels like on one of my old windows tablets.
Heater
Fri Aug 11, 2017 8:21 pm
next86,
Sorry, you said "JavaScript", I read "Java".
From your link: https://www.reddit.com/r/discordapp/com ... f_discord/ we can read that it is indeed written in Javascript.
We also read that it uses Electron as it run time engine. https://electron.atom.io/
Electron is the Google browser HTML and JavaScript engine being used for display and user input coupled with node.js for interaction with the operating system. Basically a way to create desktop applications using web technologies.
So, before Discord will run there needs to be an Electron that runs on the Pi.
So far the only nice way to do that I have found is via the services of resin.io.
I'm pretty sure whatever downloads Discord have include Electron built for x86.
Slava Ukrayini.
118251
Sat Nov 07, 2020 4:18 am
Actually, it is possible. Twister OS which is based on Raspberry Pi OS, actually has it pre-installed! so there MUST be a way. I also don't know. It does not use stuff such as Box86. If you want to install it right now, post this into terminal : curl -sSL https://git.io/JfAPE | bash it will install pi-kiss. then open it. navigate to the internet section and you will find discord click enter on discord. it will install discord and then it will show pres any key to exit. then open discord. always first it opens terminal and starts to emulate it. then after 10-20 sec it will open discord and ask you to sign in.
It worked for me and should work on any pi. Hope it helped you. If not, just use the web version. type discord.com, click on Login and login.. It wil open discord.
Botspot
Sat Nov 07, 2020 2:35 pm
Well since this thread was necro'd, I might as well help any future viewers out.
The Pi-Apps Raspberry Pi app store has Discord in it. And unlike PiKISS, this Discord is a much newer version, with fixed bugs and more features.
Install Pi-Apps with:
git clone https://github.com/Botspot/pi-apps
~/pi-apps/install
Launch Pi-Apps from the menu, select Discord, and click Install. That's it!
Once Discord is installed, launch it from the menu:
Easily install anything on your Pi using Pi-Apps. Over 2 million users.
Over 200 apps including image editors, IDEs, games, web browsers, appearance themes, and more to upgrade your Raspberry Pi desktop.
OofChair
Thu Dec 31, 2020 1:33 am
PiApps works, can confirm :D
Discord works great, and so do the other apps :D
nagol12344
Thu Feb 25, 2021 11:21 pm
i cant find discord on pi apps
Botspot
Fri Feb 26, 2021 4:33 pm
It's under the Internet category. Are you on a 32-bit OS or on a 64-bit OS?
