Mwright
Pi micro SD card as removable storage
Fri Apr 07, 2017 3:39 pm
Is it possible to use the micro sd card on the raspberry pi zero for removable storage for files I'm saving on the pi?
FTrevorGowen
Re: Pi micro SD card as removable storage
Fri Apr 07, 2017 3:47 pm
Mwright wrote:Is it possible to use the micro sd card on the raspberry pi zero for removable storage for files I'm saving on the pi?
Can you clarify what you mean by "removable storage"? - for example, if you want to remove the card whilst the Pi is powered and running then the answer's No. However, if you remove the card after the Pi has been shutdown cleanly and powered off, transfer it to another (Linux) computer (eg. a card reader in another Pi) then the answer's Yes, it's possible, but you need to know where to find the files.
Trev.
Fri Apr 07, 2017 3:49 pm
Only if your RPi isn't booted from it. (Which is possible on an RPi3B, CM3 and RPi2B2.) If you pull the root filesystem that would be like pulling the harddrive from your laptop while you're using it.
It's much easier to use a plain old USB stick.
Mwright
Fri Apr 07, 2017 5:26 pm
Trev.
Right sorry! So I'm saving images and then after powering the pi off I want to be able to insert the micro SD card into a computer and grab the images from that SD card in a folder called lets say IMAGES.
Mwright
Fri Apr 07, 2017 5:30 pm
DougieLawson wrote:Only if your RPi isn't booted from it. (Which is possible on an RPi3B, CM3 and RPi2B2.) If you pull the root filesystem that would be like pulling the harddrive from your laptop while you're using it.
Right Sorry! I meant after it's turned off. I'm currently using a usb stick but I wanted to see if I could get rid of it. I'm saving images and then after powering the pi off I want to be able to insert the micro SD card into a computer and grab the images from that SD card in a folder called lets say IMAGES. I don't think it's possible but I wasn't sure if there was something I was overlooking.
jahboater
Fri Apr 07, 2017 5:55 pm
Mwright wrote:Right sorry! So I'm saving images and then after powering the pi off I want to be able to insert the micro SD card into a computer and grab the images from that SD card in a folder called lets say IMAGES.
What operating system does your computer run?
If its Linux, then yes you can do that and it will be simple as inserting the SD card and waiting for it to automount.
Fri Apr 07, 2017 6:02 pm
The filesystem on your SDCard is ext4. You can read that with Linux systems. Windows will look at it and go "No, doesn't make any sense to me" and ask "Would you like to reformat your SDCard?".
Use a USB stick it's a million times easier.
hommar
Fri Apr 07, 2017 7:40 pm
I use USB-boot for backup SD
I plugout SD, plugin USB-storage with Raspbian-Lite, and boot from it.
Then system from USB was started, I plugin SD and copy image SD to USB-storage
HawaiianPi
Sat Apr 08, 2017 7:21 pm
Assuming you are running one of the Raspbian images, your SD card is split into 2 partitions, a tiny FAT32 partition used for the boot code, and the rest of the card formatted with the Linux ext4 file system that is used for the OS and all user data. The small boot partition won't hold much, and as Dougie said above, Windows (or Mac) computers can't read the ext4 file system by default.
There are a few solutions for that.
1. Run Linux on your main PC.
2. Install ext4 filesystem drivers for Windows/Mac.
3. Save your pictures to a network resource (NAS, shared folder or connected computer).
4. Repartition the SD card to give you additional storage for your images (expand the boot partition and save your pictures there).
5. And, of course, the ubiquitous USB flash drive.
If your Pi is connected to your network, then option 3 would probably be the best and simplest solution. You would have access to your images without even shutting the Pi down.
Martin Frezman
Sat Apr 08, 2017 11:13 pm
Since you mention specifically that you are using a PiZero, you could use the tricks described in the URL below to (more or less) turn the Zero into a USB flash drive. The trick here is that you create a virtual drive image in a file (an ordinary file, residing in the normal Linux rootfs part of the SD card) that is formatted FAT32, then you put your files there. Then when you plug the Zero into your Windows machine (via, say, a micro USB to USB A cable), the Zero is seen as a flash drive containing the files in the virtual drive image.
Sounds like exactly what you need.
URL: http://blog.gbaman.info/?p=699
Gavinmc42
Sun Apr 09, 2017 3:21 am
On my IoT data logger Pi's I use piCore OS.
Three partitions, boot- 30MB, piCore OS - 100MB (only really need about 12MB, the rest is just in case), data - rest of SDcard.
Any Linux OS will have no trouble reading the third partition and getting the data off it.
You can even take the SDcard out while it is still running, as piCore runs from ram.
It only reads the 1st two partitions on power up.
With good coding it only writes data to the sdcard if there is the third partition.
Sticking card back in and you only loose the data from the time the card was out.
With smarter coding this data could be buffered in ram until card is back in and ready.
Pi Zero USB drive sounds like a good idea for portable Pi data loggers.
These days I am using Ultibo and baremetaling the logger application as the OS.
Same thing, boots from sd and then runs from ram.
I nearly always take out the SD card while running, upgrade the kernel.bin code and reset.
Trying to do this with Raspbian = world of pain.
You need a lot of Linux knowledge to bullet proof it.
Gets broken and you have a 4-8GB SDcard that needs backing up.
I find it easier to backup the <3MB Ultibo kernel.bin ;)
I'm dancing on Rainbows.
