jebukaty
USB Error
Thu May 04, 2017 7:03 pm
Every time I start up my pi, it displays this error:
1.480895] usb 1-1: device descriptor read/64, error -71
1.770933] usb 1-1: device descriptor read/64, error -71
2.240926] usb 1-1: device descriptor read/64, error -71
2.591090] usb 1-1: device descriptor read/64, error -71
3.300939] usb 1-1: device not accepting address 4, error -71
4.140919] usb 1-1: device not accepting address 5, error -71
4.150927] usb usb1-port1: unable to enumerate USB device
My mouse and keyboard obviously don't work because of this error. This is wierd because everything was working fine on the pi, then when I started it up again, it showed me this error. I didn't change or do anything with the pi. If someone could help that would be great.
Re: USB Error
Thu May 04, 2017 7:41 pm
More often than not, those errors are due to a weedy power supply or a cruddy cable between the power supply and your RPi along with too many USB devices pulling too much current.
jebukaty
Re: USB Error
Thu May 04, 2017 8:00 pm
The thing is, I started up the raspberry pi with no usbs hooked up to see what would happen, and it was still giving me that error.
Re: USB Error
Thu May 04, 2017 8:18 pm
The LAN controller is a USB device. So the assumption of weedy power or cruddy cable tends to become more of a reality than a theory.
jebukaty
Re: USB Error
Thu May 04, 2017 8:22 pm
What kind of cable should I get then? Thanks
Re: USB Error
Thu May 04, 2017 8:25 pm
jebukaty wrote:What kind of cable should I get then? Thanks
One that can reliably deliver 5V @ 2.4A from your power supply without a voltage drop.
You also need a power supply that reliably supplies 5V @ 2.4A.
Re: USB Error
Thu May 04, 2017 8:30 pm
Purchase the Official Power Supply very good quality
https://www.raspberrypi.org/products/un ... er-supply/
drgeoff
Re: USB Error
Thu May 04, 2017 9:41 pm
No naked RPi model released so far needs a supply that can deliver 2.4 amps. But it is wise to have the extra available if the addition of power hungry USB peripheral(s) is a possibility.
As Dougie might say: "No-one ever got fired for choosing a 2.4 amp PSU." :)
jebukaty
Re: USB Error
Tue May 09, 2017 5:39 pm
Hi, I got the type of power supply you guys recommended but I am still getting the same error. If someone could again help me with this that would be great.
Re: USB Error
Tue May 09, 2017 9:41 pm
It's time to spend somewhere between £5 and £35 for a new RPi to replace your broken one.
jebukaty
Re: USB Error
Tue May 09, 2017 11:08 pm
What do you think could be wrong with the pi?
Re: USB Error
Tue May 09, 2017 11:55 pm
jebukaty wrote:What do you think could be wrong with the pi?
It looks like you've blown up the SMSC9514 chip which runs the ethernet and USB interfaces.
jebukaty
Re: USB Error
Wed May 10, 2017 12:21 am
What do you think could have caused that? Also I appreciate your help.
Re: USB Error
Thu May 11, 2017 6:30 am
jebukaty wrote:What do you think could have caused that? Also I appreciate your help.
No idea.
