Hi
Got action quake 2 sorta working Here are a few issues
***Play it without going into GUI performance drops when firing guns ( not sure what is causing this)
***play it with in GUI the mouse look only seems to turn till a certain point
( think it's cursor on desktop getting to edge of screen and interfering with game, as playing it without GUI mouse works fine, Have no idea how to fix this)
Video of issues : http://www.youtube.com/watch?v=z9Fw-y_nq2M
What you need to run it
http://www.mediafire.com/?wb4u60ikclr2163
**here is zip of all what you need, This does not contain any of quake2 full game so don't worry it's just mod and files you need to run it on raspberry pi**
1: Extract zip files to raspberry Pi
2:open terminal
3: switch to SU
4: browse to quake 2 folder in terminal--- eg : "cd /home/pi/quake2"
5:type following "chmod +x quake2"
6:still in folder on terminal type "./quake2 +game action +gamedir action"
This should load up action quake with console down
in action quake console type "connect 88.208.194.212"
This is my own server
Keybinding while in game
bind "key" bandage
FAQ
Q: When connecting to server it's starting to download
A: Make sure that "+gamedir action" is in list when firing it up, This is case sensitive
Q: where did you get quake2 files from
A: http://blog.sheasilverman.com/2012/08/r ... i-quake-2/
(No idea if this is person why made it or just complied it but credits to that person)
Q: Can PC players with action quake 2 join against raspberry Pi players
A: Yes. Seems to work fine
Re: Action quake 2 help + server
Edit :
I think I've fixed it,
New instructions
1: Turn on raspberry pi and log in under normal account
2: startx to get into GUI
3: extract and move quake2 to where you want it ie "cd /home/pi/quake2"
4: Log out of GUI so back to terminal
3: browse to quake 2 folder in terminal--- eg : "cd /home/pi/quake2"
5:type following "sudo chmod +x quake2"
6:still in folder on terminal type "sudo ./quake2 +game action +gamedir action"
**Note the game start very small change video to 1920-1080 res**
7: action quake will then load type in console"connect 88.208.194.212"
(this will download files to your raspberry Pi this can take upto 10 mins)
skybox might be missing but that should change when restarted or just change to 8bit textures
This should fix any mouse problems and firing gun issues as in video, Remember to change inverted mouse off .
if it's still freezing when firing weapon reload the game remember to use sudo or it will download files again
If this becomes popular will move server to a more permanent server
New instructions
Guess nobody cares lol
Thanks for this.
I was looking for exactly this!
I will try it out and report back.
Cheers. Let me know if there is any issues / changes need doing.
- MasterSplinter
Isn't that just quake1
I am actually attempting to set up a AQ2 dedicated server on my pi as it is headless.Bikko wrote:Cheers. Let me know if there is any issues / changes need doing.
I had it working at one stage however after adding maps and playing around with the cfgs it now loads up the baseq2 over the top (so when you fire the pistol it shoots the blaster, all the guns are replaced with default guns and you can see the spawn points).
pi@raspberrypi:~/games/q2/quake2$ ./q2ded +game action +gamedir action +exec LANserver.cfg
Yamagi Quake II v4.21
Client build options:
- CD audio
- OGG/Vorbis
- OpenAL audio
+ Zip file support
Platform: Linux
Architecture: Unknown
Byte ordering: little endian
Added packfile './baseq2/pak0.pak' (1106 files).
Using '/home/pi/.yq2/baseq2' for writing.
execing default.cfg
execing yq2.cfg
couldn't exec config.cfg
==== Yamagi Quake II Initialized ====
Added packfile './action/pak0.pak' (203 files).
Added packfile './action/configexamples.zip' (4 files).
gamedir is write protected.
execing LANserver.cfg
NET_Socket: socket: Address family not supported by protocol
-------- game initialization -------
LoadLibrary("game.so")
Game is starting up.
Game is baseq2.
------- server initialization ------
0 entities inhibited.
0 teams with 0 entities.
droptofloor: ammo_rockets startsolid at (-288 -404 432)
droptofloor: ammo_bullets startsolid at (1044 -976 16)
I'll try get it working on Pi as a server. I have a idea why it's doing it
nope sadly can't get it to use the models in action folder.
I think q2ded is set to go to base folder first
- MasterSplinter
Nope, it is many things. Check out the support list:Bikko wrote:Isn't that just quake1
-a2s
query Half-Life 2 new server
-ams
query America's Army v2.x server
-bfs
query BFRIS server
-d3g
query Descent3 Gamespy Protocol server
-d3m
query Descent3 Master (PXO) server
-d3p
query Descent3 PXO protocol server
-d3s
query Descent3 server
-dm3m
query Doom 3 Master server
-dm3s
query Doom 3 server
-efm
query Star Trek: Elite Force server
-efs
-eye
query All Seeing Eye Protocol server
-fcs
query FarCry server
-gps
query Gamespy Protocol server
-grs
query Ghost Recon server
-gs2
query Gamespy V2 Protocol server
-gs3
query Gamespy V3 Protocol server
-gs4
query Gamespy V4 Protocol server
-gsm
query Gamespy Master server
-h2s
query Hexen II server
-hl2s
query Half-Life 2 server
-hlm
query Half-Life Master server
-hls
query Half-Life server
-hrs
query Heretic II server
-hws
query HexenWorld server
-jk3m
query Jedi Knight: Jedi Academy server
-jk3s
-kps
query Kingpin server
-preys
query PREY server
-prs
query Pariah server
-q2m
query Quake II Master server
-q2s
query Quake II server
-q3m
query Quake III Master server
-q3s
query Quake III: Arena server
-q4m
query Quake 4 Master server
-q4s
query Quake 4 server
-qs
query Quake server
-qwm
query QuakeWorld Master server
-qws
query QuakeWorld server
-rss
query Ravenshield server
-rwm
query Return to Castle Wolfenstein Master server
-rws
query Return to Castle Wolfenstein server
-sas
query Savage server
-sfs
query Soldier of Fortune server
-sgs
query Shogo: Mobile Armor Division server
-sns
query Sin server
-stm
query Steam Master server
-t2m
query Tribes 2 Master server
-t2s
query Tribes 2 server
-tbm
query Tribes Master server
-tbs
query Tribes server
-tm
query TrackMania server
-ts2
query Teamspeak 2 server
-uns
query Unreal server
-ut2004m
query UT2004 Master server
-ut2s
query Unreal Tournament 2003 server
If you want some help with servers, I host most of the remaining North American servers (AQ2World.net) Contact me there
