I am trying to enable SPI1. I have SPI0 working fine and running a SPI LCD screen on CS0 and Touch on CS1. I also want to run my APA102 RBG LEDs on SPI1 as it this chip has a data line and clock ;line but no CS line. I can run the APA102 on SPI0 when I don't have the LCD screen attached to it.
I have added this line to the config.txt file "dtoverlay=spi1-1cs" but once I do that the RPi fails to boot
here is a copy of my current config.txt file
# http://rpf.io/configtxtreadme
#hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtoverlay=spi1-1cs
#dtoverlay=lirc-rpi
dtparam=audio=on
# NOOBS Auto-generated Settings:
start_x=1
gpu_mem=128
enable_uart=1
dtoverlay=w1-gpio
- OutoftheBOTS
- OutoftheBOTS
Re: enabling SPI1
Ok I have found the solution.
I removed the 'console=serial0,115200' parameter from /boot/cmdline.txt as it apparently conflicts with SPI1
So now the next question what does "console=serial0,115200" do ???
Re: enabling SPI1
I just followed recently this guide on how to enable spi1 on raspberry pi and I was succesfully to use three nrf24 modules!
Re: enabling SPI1
You can get 2+3=5 SPI(0+1) chip select lines out of the box:pradroprod wrote: ↑Sat Sep 30, 2017 7:50 pmI just followed recently this guide on how to enable spi1 on raspberry pi and I was succesfully to use three nrf24 modules!
viewtopic.php?f=44&t=22608&p=1216154#p1216154
