Raspbian Stretch (9.1) has arrived !!
Thu Aug 17, 2017 9:03 am
When the Raspbian Stretch with Desktop is unpacked it is 4.6GB
https://www.raspberrypi.org/blog/raspbian-stretch/
https://www.raspberrypi.org/downloads/raspbian/
https://downloads.raspberrypi.org/raspb ... 017-08-17/
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.1 (stretch)
Release: 9.1
Codename: stretch
My RPi 3B:
Linux raspberrypi 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017 armv7l GNU/Linux
chromium-browser - Version 60.0.3112.89 (Developer Build) Built on Ubuntu 14.04, running on Raspbian 9.1 (32-bit)
Last edited by fruitoftheloom on Thu Aug 17, 2017 10:50 am, edited 5 times in total.
PeterO
Re: Has Raspbian Stretch arrived ??
Thu Aug 17, 2017 9:04 am
Looks like it.....
Downloading now...
PeterO
mikerr
Re: Raspbian Stretch has arrived !!
Thu Aug 17, 2017 9:39 am
Nice to see LibreELEC included in the offline NOOBS install - is that new ?
ShiftPlusOne
Thu Aug 17, 2017 9:41 am
It should have been included in the previous two NOOBS releases, unless there has been a snafu.
runboy93
Thu Aug 17, 2017 10:40 am
With Chromium V60 :o and fix to Broadpwn exploit (only for built-in WiFi and not for official dongle?)
I thought Broadpwn was fixed on 4.9.43, according to github additions?
allfox
Re: Raspbian Stretch (9.1) has arrived !!
Thu Aug 17, 2017 10:53 am
On my laptop, Stretch not work with USB WiFi dongle. Then I found this: https://lists.debian.org/debian-user/20 ... 01045.html
It looks like the new naming rule would give USB dongle a name based on MAC, which is very long, and for some reason, too long to work.
Anyway, I would try it tonight.
runboy93
Thu Aug 17, 2017 10:56 am
On my laptop, Stretch not work with USB WiFi dongle. It looks like the new naming rule would give USB dongle a name based on MAC, which is very long, and for some reason, too long to work: https://lists.debian.org/debian-user/20 ... 01045.html
Urgh, and that was reported in June :/
RaTTuS
Contact: Twitter YouTube
Thu Aug 17, 2017 10:57 am
can you upgrade from jessie to stretch ...
yes though it would probably be quicker to download and start again
however
sudo apt-get update && sudo apt-get dist-upgrade -y
reboot
then edit
/etc/apt/sources.list
/etc/apt/sources.list.d/raspi.list
and change jessie to stretch
in
remove the staging
then
sudo apt-get update
ignore errors , answer Y to all questions [there will be a few] - you can make copies of any that you want to keep
reboot
sudo apt-get auto-remove
then
lsb_release -a ; uname -as
should say something like
No LSB modules are available.
Release:        9.1
Codename:       stretch
Linux PI3 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017 armv7l GNU/Linux
Covfefe
Thu Aug 17, 2017 11:00 am
Yes Rattus it was in the BLOG linked to above :D
Upgrading an existing Jessie image is possible, but is not guaranteed to work in every circumstance. If you wish to try upgrading a Jessie image to Stretch, we strongly recommend taking a backup first – we can accept no responsibility for loss of data from a failed update.
As an aside I download and created the SD Card on my new Asus Chromebit using the ChromeOS Recovery Utility which like Etcher unzips and writes :P
Last edited by fruitoftheloom on Thu Aug 17, 2017 11:02 am, edited 1 time in total.
runboy93
Fresh image is always less risk.
RaTTuS
Thu Aug 17, 2017 11:03 am
OH I didn't read the blog ;-p
bad me I'll go and read now :D
Covfefe
Thu Aug 17, 2017 11:57 am
That kernel version was, I think, only available via rpi-update. So most people didn't have it. Also consider the split between kernel and distribution.
The fix is for built in, dongle still in progress.
Tichun
Thu Aug 17, 2017 12:08 pm
Upgraded to Stretch some time ago and after apt-updating today I see only firmware packages update and so my chromium is at 56.
That's my apt.source
deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi
ShiftPlusOne
Thu Aug 17, 2017 12:11 pm
and raspi.list?
bensimmo
Thu Aug 17, 2017 12:28 pm
With the ALSA changes, has anyone updated a Google AIY setup yet (AIY image and/or installed on Raspbian).?
Before I go ahead and find out for myself ;-)
Thu Aug 17, 2017 12:44 pm
Nice to see it go generally available. I've been running Stretch for months. Eight out of fourteen are already upgraded.
The next move is to rebuild the SDCard/USB stick/HDD for each raspberry with a fresh download (to get rid of the crud and cruft that's accumulated). That will also get all fourteen running on an identical software base. That'll keep me busy for a few days.
Martin Frezman
Thu Aug 17, 2017 12:47 pm
If you don't care about your data or installed programs.
croston
Thu Aug 17, 2017 12:49 pm
It's a good way to test your backups are fit for purpose.
Thu Aug 17, 2017 12:52 pm
It's a good way to get just the stuff that's running re-installed. The data is all held on my NAS anyway.
allfox
Thu Aug 17, 2017 1:03 pm
1024 upgraded, 332 newly installed, 38 to remove and 0 not upgraded.
That's many.
lyonel
Thu Aug 17, 2017 1:16 pm
I installed Raspbian stretch on Raspberry Pi 3 but when I want to install a software, I have the following error :
Err:1 http://raspbian.42.fr/raspbian stretch/main armhf liberror-perl all 0.17024-1
  Could not connect to raspbian.42.fr:80 (163.172.250.246). - connect (111: Connection refused) [IP: 163.172.250.246 80]
Do you have a solution ?
B.Goode
Thu Aug 17, 2017 1:40 pm
Maybe that server is very busy right now serving up lots of downloads of Raspbian Stretch?
Perhaps try again later...
Thu Aug 17, 2017 1:43 pm
Seems you have an Internet Connection failure ??
Did you run the following ??
sudo apt-get update
sudo apt-get install liberror-per
l
beta-tester
Thu Aug 17, 2017 3:16 pm
nice, thank you for Raspbian Stretch!!!
i just installed Raspbian Stretch from scratch... (2017-08-16-raspbian-stretch.img / 2017-08-16-raspbian-stretch-lite.img)
BUT: now figuring out the main network adapter from script is way more tricky, because is isn't called eth0 anymore.now it is enx+MAC
(e.g. enx112233445566)
is this the new standard from now or is it by accident?
Thu Aug 17, 2017 3:36 pm
BUT: now figuring out the main network adapter from script is way more tricky, because is isn't called eth0 anymore.now it is enx + MAC
Also asked by another Poster may be better to follow that one as I started this one to flag up Stretch has arrived:
viewtopic.php?f=28&t=191030
