tfcb
Raspbian Stretch: Wifi not starting on boot
Thu Aug 17, 2017 10:25 pm
I just installed the latest Stretch lite image: 2017-08-16-raspbian-stretch-lite.zip on a RPi3. I'm attempting to use the built in Wifi.
From what I can tell wpa_supplicant is NOT successfully being started on boot which results in the wlan0 not working. That said, I don't see anything in dmesg or /var/log/messages.
If I login at the console and execute:
sudo wpa_supplicant -Dnl80211 -iwlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
Then wlan0 works until the next reboot.
I tried:
systemctl enable wpa_supplicant.service
but that didn't make a difference.
Any thoughts on how to make this work after a reboot? Any sense why:
sudo ifup wlan0 results in:
ifup: unknown interface wlan0
tfcb
Re: Raspbian Stretch: Wifi not starting on boot
Thu Aug 17, 2017 10:45 pm
I don't understand the wpa_supplicant subsystem at all but here is a workaround to my issue:
Rather than run the generic wpa_supplicant.service I am now running the interface specific version.
Here are the commands I used:
sudo cp wpa_supplicant.conf wpa_supplicant-wlan0.conf
sudo systemctl disable wpa_supplicant.service
systemctl enable wpa_supplicant@wlan0.service
After this I now have Wifi working across reboots. With any luck someone with actual knowledge will fill in some of the blanks.
BTW, sudo ifup wlan0 still returns ifup: unknown interface wlan0.
Ugh.
ncguk
Thu Aug 17, 2017 11:02 pm
I've been fighting this all evening. My solution on a fresh Raspbian Lite install:
Make sure your wpa_supplicant.conf is in place then do
sudo nano /etc/network/interfaces
and add
allow-hotplug wlan0
iface wlan0 inet manual
to the end of the file. Then do
sudo systemctl enable wpa_supplicant.service
Then reboot.
Paul Webster
Contact: Twitter
Fri Aug 18, 2017 8:01 am
I've not tried Strech yet but I did read that networking interface names have changed (default at least).
So wlan0 possibly no longer correct until you made you edits.
ncguk
Fri Aug 18, 2017 9:44 am
I just double-checked my fix with a brand new install of Raspbian Lite Stretch, and it works with wlan0 as the interface name. In fact, you don't even need to perform the 'sudo systemctl enable wpa_supplicant.service' step. I've not seen any evidence of the new 'predictable' interface names, but it may be different on an install of full Raspbian.
NB: I'm not certain this is the "correct" way to fix the problem, however it's simple, clean, and is easily reversible.
hopback
Fri Aug 18, 2017 12:23 pm
I also had this issue with the new Stretch image. ncguk's workaround resolved the issue for me. Many thanks.
ShiftPlusOne
Fri Aug 18, 2017 12:39 pm
Would be interesting to figure out why this happens. Everything is working as expected for me, so steps to reproduce the issue would be useful.
What is the output of 'apt-cache policy dhcpcd5' and just 'apt-cache policy'?
scruss
Fri Aug 18, 2017 1:36 pm
In an upgrade from Jessie to Stretch, one of my Raspberry Pis had /etc/network/interfaces ending at the
line: no iface lines at all. Manually edited it, and it's happy now.
Pronouns: he/him
ShiftPlusOne
Fri Aug 18, 2017 1:53 pm
That's intended. dhcpcd should start wpa_supplicant itself.
stewart_elmwood
Fri Aug 18, 2017 3:56 pm
... and should /etc/network/interfaces.d be empty?
Either way, wifi didn't work until I put back all the lines that had previously been in the /etc/network/interfaces file.
I work at Elmwood Electronics — Canadian Source for Raspberry Pi, Adafruit, Arduino, SparkFun and more. Local pickup available in Toronto ­— https://elmwood.to/
  (a.k.a. scruss for non-work things)
ShiftPlusOne
Fri Aug 18, 2017 4:07 pm
stewart_elmwood wrote: ... and should /etc/network/interfaces.d be empty?
Yes, interfaces.d should be empty as well.
stewart_elmwood wrote: Either way, wifi didn't work until I put back all the lines that had previously been in the /etc/network/interfaces file.
And it would be good to figure out why.
ncguk
Fri Aug 18, 2017 7:08 pm
The following is from a Pi Zero W with a clean install of Raspbian Lite Stretch:
apt-cache policy dhcpcd5:
dhcpcd5:
  Installed: 1:6.10.1-1+rpi3
  Candidate: 1:6.10.1-1+rpi3
  Version table:
 *** 1:6.10.1-1+rpi3 500
        500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
        100 /var/lib/dpkg/status
     6.10.1-1 500
        500 http://mirrordirector.raspbian.org/raspbian stretch/main armhf Packages
apt-cache policy:
Package files:
     release a=now
 500 http://archive.raspberrypi.org/debian stretch/ui armhf Packages
     release o=Raspberry Pi Foundation,a=testing,n=stretch,l=Raspberry Pi Foundation,c=ui,b=armhf
     origin archive.raspberrypi.org
     release o=Raspberry Pi Foundation,a=testing,n=stretch,l=Raspberry Pi Foundation,c=main,b=armhf
 500 http://mirrordirector.raspbian.org/raspbian stretch/rpi armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=rpi,b=armhf
     origin mirrordirector.raspbian.org
 500 http://mirrordirector.raspbian.org/raspbian stretch/non-free armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=non-free,b=armhf
 500 http://mirrordirector.raspbian.org/raspbian stretch/contrib armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=contrib,b=armhf
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=main,b=armhf
Pinned packages:
Wifi has refused to work on a couple of fresh installs until I applied the workaround above.
ShiftPlusOne
Mon Aug 21, 2017 9:18 am
If placing 'ssh' and 'wpa_supplicant.conf' on /boot isn't working for you, could you please post the full output of 'sudo journalctl' and 'cat /etc/wpa_supplicant/wpa_supplicant.conf' (with your password hidden).
ncguk
Mon Aug 21, 2017 12:24 pm
Okay. Solved it. Running sudo journalctl on a completely fresh install of Raspbian Stretch Lite on a Pi Zero W gave me the information I needed:
Aug 16 01:22:47 raspberrypi dhcpcd-run-hooks[261]: wlan0: ctrl_interface not defined in /etc/wpa_supplicant/wpa_supplicant.conf
Aug 16 01:22:47 raspberrypi dhcpcd[238]: wlan0: not interacting with wpa_supplicant(8)
Aug 16 01:22:47 raspberrypi systemd[1]: Starting Login Service...
Aug 16 01:22:47 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Aug 16 01:22:47 raspberrypi dhcpcd-run-hooks[263]: wlan0: not interacting with wpa_supplicant(8)
So I added this to my wpa_supplicant.conf:
ctrl_interface=/var/run/wpa_supplicant
And when I rebooted, wlan0 came up on the network and I could ssh into it. My wpa_supplicant.conf up to that point was a known good file and worked on Jessie.
I also spotted this:
Aug 16 01:22:50 raspberrypi systemd-udevd[152]: error changing net interface name 'eth0' to 'enx8cae4cf9e087': Device or resource busy
Aug 16 01:22:50 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Aug 16 01:22:50 raspberrypi systemd-udevd[152]: could not rename interface '3' from 'eth0' to 'enx8cae4cf9e087': Device or resource busy
Aug 16 01:22:50 raspberrypi systemd-udevd[147]: Process '/usr/sbin/alsactl -E HOME=/run/alsa restore 0' failed with exit code 99.
Aug 16 01:22:50 raspberrypi dhcpcd[238]: eth0: soliciting a DHCP lease
Aug 16 01:22:50 raspberrypi dhcpcd[238]: eth0: offered 192.168.0.14 from 192.168.0.1
Aug 16 01:22:50 raspberrypi dhcpcd[238]: eth0: probing address 192.168.0.14/24
Aug 16 01:22:51 raspberrypi systemd-udevd[147]: Process '/sbin/crda' failed with exit code 249.
Which seems to offer a hint about why predictable interface names are failing.
Here's the complete output of sudo journalctl:
-- Logs begin at Wed 2017-08-16 01:22:11 UTC, end at Mon 2017-08-21 12:06:41 UTC. --
Aug 16 01:22:11 raspberrypi kernel: Booting Linux on physical CPU 0x0
Aug 16 01:22:11 raspberrypi kernel: Linux version 4.9.41+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1023 Tue Aug
Aug 16 01:22:11 raspberrypi kernel: CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Aug 16 01:22:11 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 16 01:22:11 raspberrypi kernel: OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Aug 16 01:22:11 raspberrypi kernel: cma: Reserved 8 MiB at 0x1b400000
Aug 16 01:22:11 raspberrypi kernel: Memory policy: Data cache writeback
Aug 16 01:22:11 raspberrypi kernel: On node 0 totalpages: 114688
Aug 16 01:22:11 raspberrypi kernel: free_area_init_node: node 0, pgdat c09168d4, node_mem_map db010000
Aug 16 01:22:11 raspberrypi kernel:   Normal zone: 1008 pages used for memmap
Aug 16 01:22:11 raspberrypi kernel:   Normal zone: 0 pages reserved
Aug 16 01:22:11 raspberrypi kernel:   Normal zone: 114688 pages, LIFO batch:31
Aug 16 01:22:11 raspberrypi kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Aug 16 01:22:11 raspberrypi kernel: pcpu-alloc: [0] 0
Aug 16 01:22:11 raspberrypi kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
Aug 16 01:22:11 raspberrypi kernel: Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:
Aug 16 01:22:11 raspberrypi kernel: PID hash table entries: 2048 (order: 1, 8192 bytes)
Aug 16 01:22:11 raspberrypi kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Aug 16 01:22:11 raspberrypi kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Aug 16 01:22:11 raspberrypi kernel: Memory: 435932K/458752K available (5949K kernel code, 489K rwdata, 1952K rodata, 400K init, 734K bss, 14628K reserved, 8192K
Aug 16 01:22:11 raspberrypi kernel: Virtual kernel memory layout:
                                        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                        vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
                                        lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
                                        modules : 0xbf000000 - 0xc0000000   (  16 MB)
                                          .text : 0xc0008000 - 0xc05d78dc   (5951 kB)
                                          .init : 0xc0842000 - 0xc08a6000   ( 400 kB)
                                          .data : 0xc08a6000 - 0xc0920788   ( 490 kB)
                                           .bss : 0xc0920788 - 0xc09d7f88   ( 734 kB)
Aug 16 01:22:11 raspberrypi kernel: SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Aug 16 01:22:11 raspberrypi kernel: NR_IRQS:16 nr_irqs:16 16
Aug 16 01:22:11 raspberrypi kernel: sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Aug 16 01:22:11 raspberrypi kernel: clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Aug 16 01:22:11 raspberrypi kernel: bcm2835: system timer (irq = 27)
Aug 16 01:22:11 raspberrypi kernel: Console: colour dummy device 80x30
Aug 16 01:22:11 raspberrypi kernel: console [tty1] enabled
Aug 16 01:22:11 raspberrypi kernel: Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Aug 16 01:22:11 raspberrypi kernel: pid_max: default: 32768 minimum: 301
Aug 16 01:22:11 raspberrypi kernel: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Aug 16 01:22:11 raspberrypi kernel: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Aug 16 01:22:11 raspberrypi kernel: Disabling cpuset control group subsystem
Aug 16 01:22:11 raspberrypi kernel: CPU: Testing write buffer coherency: ok
Aug 16 01:22:11 raspberrypi kernel: ftrace: allocating 21719 entries in 64 pages
Aug 16 01:22:11 raspberrypi kernel: Setting up static identity map for 0x8200 - 0x8238
Aug 16 01:22:11 raspberrypi kernel: devtmpfs: initialized
Aug 16 01:22:11 raspberrypi kernel: VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Aug 16 01:22:11 raspberrypi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Aug 16 01:22:11 raspberrypi kernel: futex hash table entries: 256 (order: -1, 3072 bytes)
Aug 16 01:22:11 raspberrypi kernel: pinctrl core: initialized pinctrl subsystem
Aug 16 01:22:11 raspberrypi kernel: NET: Registered protocol family 16
Aug 16 01:22:11 raspberrypi kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
Aug 16 01:22:11 raspberrypi kernel: hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Aug 16 01:22:11 raspberrypi kernel: hw-breakpoint: maximum watchpoint size is 4 bytes.
Aug 16 01:22:11 raspberrypi kernel: Serial: AMBA PL011 UART driver
Aug 16 01:22:11 raspberrypi kernel: bcm2835-mbox 2000b880.mailbox: mailbox enabled
Aug 16 01:22:11 raspberrypi kernel: uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Aug 16 01:22:11 raspberrypi kernel: bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Aug 16 01:22:11 raspberrypi kernel: SCSI subsystem initialized
Aug 16 01:22:11 raspberrypi kernel: usbcore: registered new interface driver usbfs
Aug 16 01:22:11 raspberrypi kernel: usbcore: registered new interface driver hub
Aug 16 01:22:11 raspberrypi kernel: usbcore: registered new device driver usb
Aug 16 01:22:11 raspberrypi kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2017-08-08 12:01
Aug 16 01:22:11 raspberrypi kernel: clocksource: Switched to clocksource timer
Aug 16 01:22:11 raspberrypi kernel: VFS: Disk quotas dquot_6.6.0
Aug 16 01:22:11 raspberrypi kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 16 01:22:11 raspberrypi kernel: FS-Cache: Loaded
Aug 16 01:22:11 raspberrypi kernel: CacheFiles: Loaded
Aug 16 01:22:11 raspberrypi kernel: NET: Registered protocol family 2
Aug 16 01:22:11 raspberrypi kernel: TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Aug 16 01:22:11 raspberrypi kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Aug 16 01:22:11 raspberrypi kernel: TCP: Hash tables configured (established 4096 bind 4096)
Aug 16 01:22:11 raspberrypi kernel: UDP hash table entries: 256 (order: 0, 4096 bytes)
Aug 16 01:22:11 raspberrypi kernel: UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Aug 16 01:22:11 raspberrypi kernel: RPC: Registered named UNIX socket transport module.
Aug 16 01:22:11 raspberrypi kernel: RPC: Registered udp transport module.
Aug 16 01:22:11 raspberrypi kernel: RPC: Registered tcp transport module.
Aug 16 01:22:11 raspberrypi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Aug 16 01:22:11 raspberrypi kernel: hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Aug 16 01:22:11 raspberrypi kernel: workingset: timestamp_bits=14 max_order=17 bucket_order=3
Aug 16 01:22:11 raspberrypi kernel: FS-Cache: Netfs 'nfs' registered for caching
Aug 16 01:22:11 raspberrypi kernel: NFS: Registering the id_resolver key type
Aug 16 01:22:11 raspberrypi kernel: Key type id_resolver registered
Aug 16 01:22:11 raspberrypi kernel: Key type id_legacy registered
Aug 16 01:22:11 raspberrypi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Aug 16 01:22:11 raspberrypi kernel: io scheduler noop registered
Aug 16 01:22:11 raspberrypi kernel: io scheduler deadline registered (default)
Aug 16 01:22:11 raspberrypi kernel: io scheduler cfq registered
Aug 16 01:22:11 raspberrypi kernel: BCM2708FB: allocated DMA memory 5b500000
Aug 16 01:22:11 raspberrypi kernel: BCM2708FB: allocated DMA channel 0 @ dc80d000
Aug 16 01:22:11 raspberrypi kernel: Console: switching to colour frame buffer device 82x26
Aug 16 01:22:11 raspberrypi kernel: bcm2835-rng 20104000.rng: hwrng registered
Aug 16 01:22:11 raspberrypi kernel: vc-cma: Videocore CMA driver
Aug 16 01:22:11 raspberrypi kernel: vc-cma: vc_cma_base      = 0x00000000
Aug 16 01:22:11 raspberrypi kernel: vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
Aug 16 01:22:11 raspberrypi kernel: vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
Aug 16 01:22:11 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Aug 16 01:22:11 raspberrypi kernel: brd: module loaded
Aug 16 01:22:11 raspberrypi kernel: loop: module loaded
Aug 16 01:22:11 raspberrypi kernel: Loading iSCSI transport class v2.0-870.
Aug 16 01:22:11 raspberrypi kernel: usbcore: registered new interface driver smsc95xx
Aug 16 01:22:11 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Aug 16 01:22:11 raspberrypi kernel: Core Release: 2.80a
Aug 16 01:22:11 raspberrypi kernel: Setting default values for core params
Aug 16 01:22:11 raspberrypi kernel: Finished setting default values for core params
Aug 16 01:22:11 raspberrypi kernel: Using Buffer DMA mode
Aug 16 01:22:11 raspberrypi kernel: Periodic Transfer Interrupt Enhancement - disabled
Aug 16 01:22:11 raspberrypi kernel: Multiprocessor Interrupt Enhancement - disabled
Aug 16 01:22:11 raspberrypi kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
Aug 16 01:22:11 raspberrypi kernel: Dedicated Tx FIFOs mode
Aug 16 01:22:11 raspberrypi kernel: WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Aug 16 01:22:11 raspberrypi kernel: FIQ FSM acceleration enabled for :
                                    Non-periodic Split Transactions
                                    Periodic Split Transactions
                                    High-Speed Isochronous Endpoints
                                    Interrupt/Control Split Transaction hack enabled
Aug 16 01:22:11 raspberrypi kernel: dwc_otg: Microframe scheduler enabled
Aug 16 01:22:11 raspberrypi kernel: WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04519f4
Aug 16 01:22:11 raspberrypi kernel: WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451cd0 length 36
Aug 16 01:22:11 raspberrypi kernel: WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
Aug 16 01:22:11 raspberrypi kernel: dwc_otg 20980000.usb: DWC OTG Controller
Aug 16 01:22:11 raspberrypi kernel: dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Aug 16 01:22:11 raspberrypi kernel: dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Aug 16 01:22:11 raspberrypi kernel: Init: Port Power? op_state=1
Aug 16 01:22:11 raspberrypi kernel: Init: Power Port (0)
Aug 16 01:22:11 raspberrypi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Aug 16 01:22:11 raspberrypi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 16 01:22:11 raspberrypi kernel: usb usb1: Product: DWC OTG Controller
Aug 16 01:22:11 raspberrypi kernel: usb usb1: Manufacturer: Linux 4.9.41+ dwc_otg_hcd
Aug 16 01:22:11 raspberrypi kernel: usb usb1: SerialNumber: 20980000.usb
Aug 16 01:22:11 raspberrypi kernel: hub 1-0:1.0: USB hub found
Aug 16 01:22:11 raspberrypi kernel: hub 1-0:1.0: 1 port detected
Aug 16 01:22:11 raspberrypi kernel: dwc_otg: FIQ enabled
Aug 16 01:22:11 raspberrypi kernel: dwc_otg: NAK holdoff enabled
Aug 16 01:22:11 raspberrypi kernel: dwc_otg: FIQ split-transaction FSM enabled
Aug 16 01:22:11 raspberrypi kernel: Module dwc_common_port init
Aug 16 01:22:11 raspberrypi kernel: usbcore: registered new interface driver usb-storage
Aug 16 01:22:11 raspberrypi kernel: mousedev: PS/2 mouse device common for all mice
Aug 16 01:22:11 raspberrypi kernel: bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Aug 16 01:22:11 raspberrypi kernel: bcm2835-cpufreq: min=700000 max=1000000
Aug 16 01:22:11 raspberrypi kernel: sdhci: Secure Digital Host Controller Interface driver
Aug 16 01:22:11 raspberrypi kernel: sdhci: Copyright(c) Pierre Ossman
Aug 16 01:22:11 raspberrypi kernel: sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Aug 16 01:22:11 raspberrypi kernel: mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Aug 16 01:22:11 raspberrypi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Aug 16 01:22:11 raspberrypi kernel: ledtrig-cpu: registered to indicate activity on CPUs
Aug 16 01:22:11 raspberrypi kernel: hidraw: raw HID events driver (C) Jiri Kosina
Aug 16 01:22:11 raspberrypi kernel: usbcore: registered new interface driver usbhid
Aug 16 01:22:11 raspberrypi kernel: usbhid: USB HID core driver
Aug 16 01:22:11 raspberrypi kernel: vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Aug 16 01:22:11 raspberrypi kernel: Initializing XFRM netlink socket
Aug 16 01:22:11 raspberrypi kernel: NET: Registered protocol family 17
Aug 16 01:22:11 raspberrypi kernel: Key type dns_resolver registered
Aug 16 01:22:11 raspberrypi kernel: registered taskstats version 1
Aug 16 01:22:11 raspberrypi kernel: vc-sm: Videocore shared memory driver
Aug 16 01:22:11 raspberrypi kernel: [vc_sm_connected_init]: start
Aug 16 01:22:11 raspberrypi kernel: [vc_sm_connected_init]: end - returning 0
Aug 16 01:22:11 raspberrypi kernel: 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Aug 16 01:22:11 raspberrypi kernel: sdhost: log_buf @ db513000 (5b513000)
Aug 16 01:22:11 raspberrypi kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Aug 16 01:22:11 raspberrypi kernel: mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Aug 16 01:22:11 raspberrypi kernel: mmc-bcm2835 20300000.mmc: DMA channel allocated
Aug 16 01:22:11 raspberrypi kernel: random: fast init done
Aug 16 01:22:11 raspberrypi kernel: Indeed it is in host mode hprt0 = 00021501
Aug 16 01:22:11 raspberrypi kernel: of_cfs_init
Aug 16 01:22:11 raspberrypi kernel: of_cfs_init: OK
Aug 16 01:22:11 raspberrypi kernel: Waiting for root device PARTUUID=18489702-02...
Aug 16 01:22:11 raspberrypi kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Aug 16 01:22:11 raspberrypi kernel: mmc0: new high speed SDHC card at address aaaa
Aug 16 01:22:11 raspberrypi kernel: mmcblk0: mmc0:aaaa SE16G 14.8 GiB
Aug 16 01:22:11 raspberrypi kernel:  mmcblk0: p1 p2
Aug 16 01:22:11 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Aug 16 01:22:11 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Aug 16 01:22:11 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Aug 16 01:22:11 raspberrypi kernel: usb 1-1: new high-speed USB device number 2 using dwc_otg
Aug 16 01:22:11 raspberrypi kernel: Indeed it is in host mode hprt0 = 00001101
Aug 16 01:22:11 raspberrypi kernel: EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Aug 16 01:22:11 raspberrypi kernel: EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Aug 16 01:22:11 raspberrypi kernel: mmc1: new high speed SDIO card at address 0001
Aug 16 01:22:11 raspberrypi kernel: EXT4-fs (mmcblk0p2): recovery complete
Aug 16 01:22:11 raspberrypi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Aug 16 01:22:11 raspberrypi kernel: VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Aug 16 01:22:11 raspberrypi kernel: devtmpfs: mounted
Aug 16 01:22:11 raspberrypi kernel: Freeing unused kernel memory: 400K (c0842000 - c08a6000)
Aug 16 01:22:11 raspberrypi kernel: This architecture does not have kernel memory protection.
Aug 16 01:22:11 raspberrypi kernel: usb 1-1: New USB device found, idVendor=0b95, idProduct=7720
Aug 16 01:22:11 raspberrypi kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 16 01:22:11 raspberrypi kernel: usb 1-1: Product: AX88x72A
Aug 16 01:22:12 raspberrypi kernel: usb 1-1: Manufacturer: ASIX Elec. Corp.
Aug 16 01:22:12 raspberrypi kernel: usb 1-1: SerialNumber: 0003A3
Aug 16 01:22:12 raspberrypi systemd[1]: System time before build time, advancing clock.
Aug 16 01:22:12 raspberrypi kernel: NET: Registered protocol family 10
Aug 16 01:22:12 raspberrypi kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Aug 16 01:22:12 raspberrypi systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +
Aug 16 01:22:12 raspberrypi systemd[1]: Detected architecture arm.
Aug 16 01:22:12 raspberrypi systemd[1]: Set hostname to <raspberrypi>.
Aug 16 01:22:12 raspberrypi systemd[1]: Listening on Syslog Socket.
Aug 16 01:22:12 raspberrypi systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Aug 16 01:22:12 raspberrypi systemd[1]: Listening on fsck to fsckd communication Socket.
Aug 16 01:22:12 raspberrypi systemd[1]: Listening on Journal Socket (/dev/log).
Aug 16 01:22:12 raspberrypi systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
Aug 16 01:22:12 raspberrypi systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Aug 16 01:22:12 raspberrypi systemd[1]: Created slice User and Session Slice.
Aug 16 01:22:12 raspberrypi kernel: random: crng init done
Aug 16 01:22:12 raspberrypi systemd-journald[105]: Journal started
Aug 16 01:22:12 raspberrypi systemd-journald[105]: Runtime journal (/run/log/journal/4dce856198fc4ee195dc48e771719fdf) is 2.7M, max 21.7M, 18.9M free.
Aug 16 01:22:12 raspberrypi systemd-fsck[88]: e2fsck 1.43.4 (31-Jan-2017)
Aug 16 01:22:12 raspberrypi systemd-fsck[88]: Superblock last mount time (Wed Aug 16 01:22:19 2017,
Aug 16 01:22:12 raspberrypi systemd-fsck[88]:         now = Thu Nov  3 17:16:44 2016) is in the future.
Aug 16 01:22:12 raspberrypi systemd-fsck[88]: Fix? yes
Aug 16 01:22:12 raspberrypi systemd-fsck[88]: Superblock last write time (Wed Aug 16 01:22:11 2017,
Aug 16 01:22:12 raspberrypi systemd-fsck[88]: Pass 1: Checking inodes, blocks, and sizes
Aug 16 01:22:12 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Aug 16 01:22:12 raspberrypi systemd[1]: Started Apply Kernel Variables.
Aug 16 01:22:12 raspberrypi fake-hwclock[95]: Wed 16 Aug 01:22:11 UTC 2017
Aug 16 01:22:12 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Aug 16 01:22:13 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Aug 16 01:22:13 raspberrypi systemd[1]: Started Set the console keyboard layout.
Aug 16 01:22:34 raspberrypi systemd-fsck[88]: Pass 2: Checking directory structure
Aug 16 01:22:37 raspberrypi systemd-fsck[88]: Pass 3: Checking directory connectivity
Aug 16 01:22:37 raspberrypi systemd-fsck[88]: Pass 4: Checking reference counts
Aug 16 01:22:38 raspberrypi systemd-fsck[88]: Pass 5: Checking group summary information
Aug 16 01:22:40 raspberrypi systemd-fsck[88]: /dev/mmcblk0p2: 39357/938672 files (0.1% non-contiguous), 334202/3877760 blocks
Aug 16 01:22:40 raspberrypi systemd[1]: Started File System Check on Root Device.
Aug 16 01:22:40 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Aug 16 01:22:40 raspberrypi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Aug 16 01:22:40 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Aug 16 01:22:40 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Aug 16 01:22:40 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Aug 16 01:22:40 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Aug 16 01:22:40 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Aug 16 01:22:40 raspberrypi systemd[1]: Started Load/Save Random Seed.
Aug 16 01:22:40 raspberrypi systemd-journald[105]: Runtime journal (/run/log/journal/4dce856198fc4ee195dc48e771719fdf) is 2.7M, max 21.7M, 18.9M free.
Aug 16 01:22:40 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Aug 16 01:22:41 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Aug 16 01:22:41 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Aug 16 01:22:41 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 156 (plymouthd).
Aug 16 01:22:41 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Aug 16 01:22:41 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Aug 16 01:22:41 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Aug 16 01:22:41 raspberrypi systemd[1]: Reached target Paths.
Aug 16 01:22:42 raspberrypi kernel: gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Aug 16 01:22:42 raspberrypi systemd[1]: Found device /dev/serial1.
Aug 16 01:22:43 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/18489702-01.
Aug 16 01:22:43 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/18489702-01...
Aug 16 01:22:43 raspberrypi mtp-probe[171]: checking bus 1, device 2: "/sys/devices/platform/soc/20980000.usb/usb1/1-1"
Aug 16 01:22:43 raspberrypi kernel: usbcore: registered new interface driver brcmfmac
Aug 16 01:22:43 raspberrypi kernel: brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
Aug 16 01:22:44 raspberrypi systemd-fsck[174]: fsck.fat 4.1 (2017-01-24)
Aug 16 01:22:44 raspberrypi systemd-fsck[174]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Aug 16 01:22:44 raspberrypi systemd-fsck[174]:  Automatically removing dirty bit.
Aug 16 01:22:44 raspberrypi systemd-fsck[174]: Performing changes.
Aug 16 01:22:44 raspberrypi systemd-fsck[174]: /dev/mmcblk0p1: 148 files, 42948/84272 clusters
Aug 16 01:22:44 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/18489702-01.
Aug 16 01:22:44 raspberrypi systemd[1]: Mounting /boot...
Aug 16 01:22:44 raspberrypi systemd[1]: Mounted /boot.
Aug 16 01:22:44 raspberrypi systemd[1]: Reached target Local File Systems.
Aug 16 01:22:44 raspberrypi mtp-probe[171]: bus: 1, device: 2 was not an MTP device
Aug 16 01:22:44 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Aug 16 01:22:44 raspberrypi systemd[1]: Starting Set console font and keymap...
Aug 16 01:22:44 raspberrypi systemd[1]: Starting Raise network interfaces...
Aug 16 01:22:44 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Aug 16 01:22:44 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Aug 16 01:22:44 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Aug 16 01:22:44 raspberrypi systemd[1]: Started Set console font and keymap.
Aug 16 01:22:44 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Aug 16 01:22:45 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Aug 16 01:22:45 raspberrypi systemd[1]: Starting Network Time Synchronization...
Aug 16 01:22:45 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Aug 16 01:22:45 raspberrypi systemd[1]: Reached target NFS client services.
Aug 16 01:22:45 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Aug 16 01:22:45 raspberrypi systemd[1]: Reached target Remote File Systems.
Aug 16 01:22:46 raspberrypi kernel: asix 1-1:1.0 eth0: register 'asix' at usb-20980000.usb-1, ASIX AX88772 USB 2.0 Ethernet, 8c:ae:4c:f9:e0:87
Aug 16 01:22:46 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Aug 16 01:22:46 raspberrypi kernel: usbcore: registered new interface driver asix
Aug 16 01:22:46 raspberrypi systemd[1]: Started Network Time Synchronization.
Aug 16 01:22:46 raspberrypi systemd[1]: Reached target System Initialization.
Aug 16 01:22:46 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Aug 16 01:22:46 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Aug 16 01:22:46 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Aug 16 01:22:46 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Aug 16 01:22:46 raspberrypi systemd[1]: Reached target Sockets.
Aug 16 01:22:46 raspberrypi systemd[1]: Reached target Basic System.
Aug 16 01:22:46 raspberrypi systemd[1]: Started Regular background program processing daemon.
Aug 16 01:22:46 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Aug 16 01:22:46 raspberrypi cron[236]: (CRON) INFO (pidfile fd = 3)
Aug 16 01:22:46 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Aug 16 01:22:46 raspberrypi cron[236]: (CRON) INFO (Running @reboot jobs)
Aug 16 01:22:46 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
Aug 16 01:22:46 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Aug 16 01:22:46 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Aug 16 01:22:46 raspberrypi alsactl[240]: /usr/sbin/alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
Aug 16 01:22:47 raspberrypi alsactl[240]: Found hardware: "bcm2835" "Broadcom Mixer" "" "" ""
Aug 16 01:22:47 raspberrypi alsactl[240]: Hardware is initialized using a generic method
Aug 16 01:22:47 raspberrypi kernel: uart-pl011 20201000.serial: no DMA platform data
Aug 16 01:22:47 raspberrypi dhcpcd[238]: wlan0: ctrl_interface not defined in /etc/wpa_supplicant/wpa_supplicant.conf
Aug 16 01:22:47 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Aug 16 01:22:47 raspberrypi systemd[1]: Starting System Logging Service...
Aug 16 01:22:47 raspberrypi thd[264]: Found socket passed from systemd
Aug 16 01:22:48 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Aug 16 01:22:48 raspberrypi systemd[1]: Reached target System Time Synchronized.
Aug 16 01:22:48 raspberrypi avahi-daemon[265]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Aug 16 01:22:48 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Aug 16 01:22:48 raspberrypi avahi-daemon[265]: Successfully dropped root privileges.
Aug 16 01:22:48 raspberrypi avahi-daemon[265]: avahi-daemon 0.6.32 starting up.
Aug 16 01:22:48 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
Aug 16 01:22:48 raspberrypi liblogging-stdlog[267]:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="267" x-info="http://www.rsyslog.com"] start
Aug 16 01:22:48 raspberrypi avahi-daemon[265]: Successfully called chroot().
Aug 16 01:22:48 raspberrypi avahi-daemon[265]: Successfully dropped remaining capabilities.
Aug 16 01:22:48 raspberrypi avahi-daemon[265]: No service file found in /etc/avahi/services.
Aug 16 01:22:48 raspberrypi avahi-daemon[265]: Network interface enumeration completed.
Aug 16 01:22:48 raspberrypi avahi-daemon[265]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 475581220.
Aug 16 01:22:48 raspberrypi systemd[1]: Started System Logging Service.
Aug 16 01:22:49 raspberrypi dhcpcd[238]: eth0: waiting for carrier
Aug 16 01:22:49 raspberrypi kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Aug 16 01:22:49 raspberrypi kernel: IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Aug 16 01:22:49 raspberrypi kernel: brcmfmac: power management disabled
Aug 16 01:22:49 raspberrypi dhcpcd[238]: wlan0: waiting for carrier
Aug 16 01:22:49 raspberrypi dhcpcd[238]: wlan0: carrier acquired
Aug 16 01:22:49 raspberrypi dhcpcd[238]: wlan0: adding address fe80::3f78:df18:7a9d:a120
Aug 16 01:22:49 raspberrypi kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Aug 16 01:22:49 raspberrypi kernel: asix 1-1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Aug 16 01:22:49 raspberrypi dhcpcd[238]: DUID 00:01:00:01:21:26:5a:d6:b8:27:eb:0a:4b:90
Aug 16 01:22:49 raspberrypi dhcpcd[238]: wlan0: IAID eb:0a:4b:90
Aug 16 01:22:49 raspberrypi dhcpcd[238]: wlan0: carrier lost
Aug 16 01:22:49 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Aug 16 01:22:49 raspberrypi systemd-logind[262]: New seat seat0.
Aug 16 01:22:49 raspberrypi systemd[1]: Started Login Service.
Aug 16 01:22:49 raspberrypi dphys-swapfile[269]: Starting dphys-swapfile swapfile setup ...
Aug 16 01:22:49 raspberrypi raspi-config[237]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Aug 16 01:22:49 raspberrypi raspi-config[237]:  No. Switching to ondemand scaling governor.
Aug 16 01:22:49 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Aug 16 01:22:49 raspberrypi dhcpcd[238]: wlan0: deleting address fe80::3f78:df18:7a9d:a120
Aug 16 01:22:49 raspberrypi dhcpcd[238]: eth0: carrier acquired
Aug 16 01:22:49 raspberrypi dhcpcd[238]: eth0: adding address fe80::9d43:7614:3d38:a3cd
Aug 16 01:22:49 raspberrypi dhcpcd[238]: eth0: IAID 4c:f9:e0:87
Aug 16 01:22:50 raspberrypi dphys-swapfile[269]: want /var/swap=100MByte, checking existing: keeping it
Aug 16 01:22:50 raspberrypi systemd[1]: Started Raise network interfaces.
Aug 16 01:22:50 raspberrypi kernel: Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
Aug 16 01:22:50 raspberrypi dphys-swapfile[269]: done.
Aug 16 01:22:50 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Aug 16 01:22:50 raspberrypi dhcpcd[238]: eth0: soliciting an IPv6 router
Aug 16 01:22:50 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Aug 16 01:22:50 raspberrypi systemd[1]: Reached target Sound Card.
Aug 16 01:22:50 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Aug 16 01:22:51 raspberrypi avahi-daemon[265]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9d43:7614:3d38:a3cd.
Aug 16 01:22:51 raspberrypi avahi-daemon[265]: New relevant interface eth0.IPv6 for mDNS.
Aug 16 01:22:51 raspberrypi avahi-daemon[265]: Registering new address record for fe80::9d43:7614:3d38:a3cd on eth0.*.
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: Core ver 2.22
Aug 16 01:22:51 raspberrypi kernel: NET: Registered protocol family 31
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: HCI device and connection manager initialized
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: HCI socket layer initialized
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: L2CAP socket layer initialized
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: SCO socket layer initialized
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: HCI UART driver ver 2.3
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: HCI UART protocol H4 registered
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
Aug 16 01:22:51 raspberrypi kernel: Bluetooth: HCI UART protocol Broadcom registered
Aug 16 01:22:51 raspberrypi btuart[243]: bcm43xx_init
Aug 16 01:22:51 raspberrypi btuart[243]: Flash firmware /lib/firmware/BCM43430A1.hcd
Aug 16 01:22:51 raspberrypi btuart[243]: Set Controller UART speed to 3000000 bit/s
Aug 16 01:22:51 raspberrypi btuart[243]: Device setup complete
Aug 16 01:22:51 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Aug 16 01:22:51 raspberrypi systemd[1]: Starting Bluetooth service...
Aug 16 01:22:52 raspberrypi bluetoothd[367]: Bluetooth daemon 5.43
Aug 16 01:22:52 raspberrypi systemd[1]: Started Bluetooth service.
Aug 16 01:22:52 raspberrypi systemd[1]: Reached target Bluetooth.
Aug 16 01:22:52 raspberrypi bluetoothd[367]: Starting SDP server
Aug 16 01:22:52 raspberrypi kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 16 01:22:52 raspberrypi kernel: Bluetooth: BNEP filters: protocol multicast
Aug 16 01:22:52 raspberrypi kernel: Bluetooth: BNEP socket layer initialized
Aug 16 01:22:52 raspberrypi bluetoothd[367]: Bluetooth management interface 1.14 initialized
Aug 16 01:22:52 raspberrypi bluetoothd[367]: Failed to obtain handles for "Service Changed" characteristic
Aug 16 01:22:52 raspberrypi dbus[245]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Aug 16 01:22:52 raspberrypi bluetoothd[367]: Sap driver initialization failed.
Aug 16 01:22:52 raspberrypi bluetoothd[367]: sap-server: Operation not permitted (1)
Aug 16 01:22:52 raspberrypi systemd[1]: Starting Hostname Service...
Aug 16 01:22:52 raspberrypi dbus[245]: [system] Successfully activated service 'org.freedesktop.hostname1'
Aug 16 01:22:52 raspberrypi systemd[1]: Started Hostname Service.
Aug 16 01:22:55 raspberrypi dhcpcd[238]: eth0: leased 192.168.0.14 for 864000 seconds
Aug 16 01:22:55 raspberrypi dhcpcd[238]: eth0: adding route to 192.168.0.0/24
Aug 16 01:22:55 raspberrypi dhcpcd[238]: eth0: adding default route via 192.168.0.1
Aug 16 01:22:55 raspberrypi avahi-daemon[265]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.14.
Aug 16 01:22:55 raspberrypi avahi-daemon[265]: New relevant interface eth0.IPv4 for mDNS.
Aug 16 01:22:55 raspberrypi avahi-daemon[265]: Registering new address record for 192.168.0.14 on eth0.IPv4.
Aug 16 01:22:56 raspberrypi dhcpcd[238]: Too few arguments.
Aug 16 01:22:56 raspberrypi dhcpcd[238]: forked to background, child pid 425
Aug 16 01:22:56 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Aug 16 01:22:56 raspberrypi systemd[1]: Reached target Network.
Aug 16 01:22:56 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Aug 16 01:22:56 raspberrypi systemd[1]: Starting Permit User Sessions...
Aug 16 01:22:56 raspberrypi systemd[1]: Reached target Network is Online.
Aug 16 01:22:56 raspberrypi systemd[1]: apt-daily.timer: Adding 26min 22.746380s random time.
Aug 16 01:22:56 raspberrypi systemd[1]: Started Daily apt download activities.
Aug 16 01:22:56 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 27min 20.454809s random time.
Aug 16 01:22:56 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Aug 16 01:22:56 raspberrypi systemd[1]: Reached target Timers.
Aug 16 01:22:56 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Aug 16 01:22:56 raspberrypi systemd[1]: Started Permit User Sessions.
Aug 16 01:22:56 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Aug 16 01:22:56 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Aug 16 01:22:56 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Aug 16 01:22:56 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 156 (plymouthd).
Aug 16 01:22:56 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Aug 16 01:22:56 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Aug 16 01:22:56 raspberrypi systemd[1]: Started Getty on tty1.
Aug 16 01:22:56 raspberrypi sshd[426]: Server listening on 0.0.0.0 port 22.
Aug 16 01:22:56 raspberrypi systemd[1]: Reached target Login Prompts.
Aug 16 01:22:56 raspberrypi sshd[426]: Server listening on :: port 22.
Aug 16 01:22:57 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Aug 16 01:22:57 raspberrypi systemd[1]: Reached target Multi-User System.
Aug 16 01:22:57 raspberrypi systemd[1]: Reached target Graphical Interface.
Aug 16 01:22:57 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Aug 16 01:22:57 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Aug 16 01:22:57 raspberrypi systemd[1]: Startup finished in 1.988s (kernel) + 48.381s (userspace) = 50.370s.
Aug 16 01:23:03 raspberrypi dhcpcd[425]: eth0: no IPv6 Routers available
Aug 21 11:59:40 raspberrypi systemd[1]: Time has been changed
Aug 21 11:59:40 raspberrypi systemd[1]: apt-daily.timer: Adding 11h 54min 7.824589s random time.
Aug 21 11:59:40 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 38min 26.486052s random time.
Aug 21 11:59:40 raspberrypi systemd-timesyncd[210]: Synchronized to time server 134.0.16.1:123 (2.debian.pool.ntp.org).
Aug 21 11:59:40 raspberrypi systemd[1]: Starting Daily apt download activities...
Aug 21 12:00:02 raspberrypi systemd[1]: Started Daily apt download activities.
Aug 21 12:00:02 raspberrypi systemd[1]: apt-daily.timer: Adding 8h 11min 48.058538s random time.
Aug 21 12:00:02 raspberrypi systemd[1]: apt-daily.timer: Adding 5h 3min 6.979803s random time.
Aug 21 12:00:02 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
Aug 21 12:00:06 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Aug 21 12:00:06 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 15min 41.396745s random time.
Aug 21 12:00:06 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 39min 22.671346s random time.
Aug 21 12:01:55 raspberrypi sshd[548]: Accepted password for pi from 192.168.0.18 port 51446 ssh2
Aug 21 12:01:55 raspberrypi sshd[548]: pam_unix(sshd:session): session opened for user pi by (uid=0)
Aug 21 12:01:55 raspberrypi systemd[1]: Created slice User Slice of pi.
Aug 21 12:01:55 raspberrypi systemd-logind[262]: New session c1 of user pi.
Aug 21 12:01:55 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Aug 21 12:01:55 raspberrypi systemd[1]: Started Session c1 of user pi.
Aug 21 12:01:55 raspberrypi systemd[554]: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Aug 21 12:01:55 raspberrypi systemd[554]: Reached target Paths.
Aug 21 12:01:55 raspberrypi systemd[554]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Aug 21 12:01:55 raspberrypi systemd[554]: Reached target Timers.
Aug 21 12:01:55 raspberrypi systemd[554]: Listening on GnuPG cryptographic agent and passphrase cache.
Aug 21 12:01:55 raspberrypi systemd[554]: Listening on GnuPG cryptographic agent (access for web browsers).
Aug 21 12:01:55 raspberrypi systemd[554]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Aug 21 12:01:55 raspberrypi systemd[554]: Reached target Sockets.
Aug 21 12:01:55 raspberrypi systemd[554]: Reached target Basic System.
Aug 21 12:01:55 raspberrypi systemd[554]: Reached target Default.
Aug 21 12:01:55 raspberrypi systemd[554]: Startup finished in 136ms.
Aug 21 12:01:55 raspberrypi systemd[1]: Started User Manager for UID 1000.
Aug 21 12:02:11 raspberrypi sudo[583]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Aug 21 12:02:11 raspberrypi sudo[583]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Aug 21 12:06:25 raspberrypi sudo[583]: pam_unix(sudo:session): session closed for user root
Aug 21 12:06:41 raspberrypi sudo[592]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Aug 21 12:06:41 raspberrypi sudo[592]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
and sudo cat /etc/wpa_supplicant/wpa_supplicant.conf (with the ctrl_interface line added in):
country=GB
network={
    ssid="**********"
    psk="***********"
Hope this helps.
ShiftPlusOne
Mon Aug 21, 2017 12:30 pm
Yup, failing predictable interface names are a known issue and the next image will disable them by default.
Is everybody else who is seeing the issue missing the "ctrl_interface=/var/run/wpa_supplicant" line?
ShiftPlusOne
Mon Aug 21, 2017 1:07 pm
The default wpa_supplicant.conf, looks like this:
country=GB
update_config=1
I would recommend having that header before the network blocks.
ncguk
Mon Aug 21, 2017 1:17 pm
country=GB
update_config=1
Will do. That one was definitely user oversight.
wedgetail84
Sat Aug 26, 2017 7:09 am
no i I have the line but my wifi is not working on reboot. I was working (once). To confirm my wpa_supplicant.conf starts
"country=AU
update_config=1"
I changed nothing, rebooted and now no connection (I was able to access it on SSH from my mac). What else can I check?
Sat Aug 26, 2017 2:53 pm
Run this:
sudo -i
cd /etc/wpa_supplicant
wpa_passphrase SSIDgoeshere passwordgoeshere >> wpa_supplicant.conf
exit
With your SSID and your password. The two angle brackets (>>) are crucial as that means append the results to the file.
p6ril
Sat Aug 26, 2017 9:13 pm
Hi everyone,
initially I had the exact same issue. I'm working with a headless configuration and was writing the wpa_supplicant.conf to the boot partition so it's taken into account on startup. However, on Jessie you could set up the file with just the result of the wpa_passphrase command. This doesn't work anymore with Stretch.
Reading the comments above, by simply adding the wpa_passphrase result to the default wpa_supplicant.conf, it worked. One has just to be careful when working a headless configuration :)
so my /etc/wpa_supplicant/wpa_supplicant.conf file now looks like this:
country=FR
update_config=1
network={
	ssid="xxxxxxxxx"
	scan_ssid=1
	psk=yyyyyyyyyy
fceledon
Sun Aug 27, 2017 1:04 am
I'm starting it using the serial cable. so, to start use a linux friendly editor (on Windows use Notepad++) and append the following two lines
/boot/config.txt
core_freq=250
enable_uart=1
then use sudo to go root and just type your wifi SSID and password as follows
wpa_passphrase "SSID" "password" >> /etc/wpa_supplicant/wpa_supplicant.conf
soslug
Contact: Website Yahoo Messenger
Thu Sep 07, 2017 11:05 pm
I also had issues with networking with the new stretch however it can be fixed.
First of all you need to realise the naming conventions for network interfaces has now changed. No longer can you use eth0, wlan0 or with an external wireless wlan1. I understand the reason for this has something to do with network collisions, but may have that wrong.
A friend of mine noticed the problem early on Lewis Cowles has posted a fix on gist as yet this is not an official fix but it does work. https://gist.github.com/Lewiscowles1986 ... 0adfe04cdb
Many thanks for his help in getting it running
The changed file applies to the following
/usr/lib/dhcpcd5/dhcpd
please copy old dhcpd file before editing if you have no network and have know way to paste the above you will need to use nano thus:
sudo nano /usr/lib/dhcpcd5/dhcpd
This at least this gets ethernet working
/etc/networks/interfaces file will also need editing with this
auto lo
iface lo inet loopback
iface eth0 inet manual
This is the same as previous and seems to contradict what I said above, all I can say is that it worked if some has the correct entries for this file given the changes please post.
I have wireless working also this was a little more complicated than usual and I am not ready to post details at this time as I am not sure of the steps when I do I will post.
IPFreely, to weed the network demons that dwell in them their Windows!
jasonxh
Fri Sep 08, 2017 2:04 am
I ran into the same problem after a fresh install of Raspbian Stretch on a Pi 2. Everything was pristine:
  • /etc/network/interfaces is mostly empty
  • /etc/network/interfaces.d is empty as well
  • ifconfig shows that wlan has been renamed to wlx******
  • /etc/wpa_supplicant/wpa_supplicant.conf contains the necessary headers
    country=US
    update_config=1
  • I appended my wifi network to /etc/wpa_supplicant/wpa_supplicant.conf
The issue is wpa_supplicant wasn't started at all. There's no trace of it in /var/log/syslog or journalctl. From a previous post in this thread I learned that wpa_supplicant is now supposed to be started by dhcpcd. After some digging, I found out that for some weird reason, my wireless interface was not detected as wireless by dhcpcd when it executed dhcpcd-run-hooks. So I appended a simple workaround to the end of /etc/dhcpcd.conf to force it:
# For some reason, the interface is not detected as wireless.
# Marking it so will start wpa_supplicant.
# Replace with your actual wireless interface name.
interface wlx******
env ifwireless=1
env wpa_supplicant_driver=nl80211,wext
The last line was needed for my RTL8188EUS based wifi adapter. Otherwise I get error "nl80211: Driver does not support authentication/association or connect commands". It may not be necessary for other wifi adapters, but shouldn't hurt either.
Now everything works after a reboot. Hope this helps.
tndog
Mon Sep 11, 2017 5:46 am
So a pretty painful experience but WiFi for my PiZeroW is working now. It would be good for the foundation to update their guides, or update the image.
Lots of conflicting information out there - this worked for me as of 11th Sep 2017 using a brand new install of Raspbian Stretch Lite (image 2017-08-16).
For others benefit:
Need to add the top 3 extra lines to /etc/wpa_supplicant/wpa_supplicant.conf in addition to your wifi network details. My country is Australia, hence the AU.
country=AU
update_config=1
network={
	ssid="yourWiFiNetworkSSID"
	psk="your WiFiPassword"
Then edit /etc/network/interfaces and add additional lines below the source-directory line (which was the only line populated)
# Include files from /etc/network/interfaces.d:
auto wlan0
allow-hotplug wlan0
No need to alter as per soslug's post.
This got me going on dhcp.
ifconfig wlan0 works fine.
I also went with a static IP address as per the instructions from https://raspberrypi.stackexchange.com/q ... ress#37921
However if you disable the DHCP client daemon and switch to standard Debian networking as per the instructions it DOES NOT work. Works fine by just editing /etc/dhcpcd.conf.
I also ran an upgrade from Jessie on another PiZeroW that had been working fine and I had no issues, again on a static IP address.
adamreisnz
Sat Sep 16, 2017 9:32 am
I can confirm that with the latest Raspbian Lite Stretch image, all that is needed to get wifi to work on boot is put a wpa_supplicant.conf file in /boot with the aforementioned 3 lines and your network configuration. That, plus the ssh file to enable ssh, allowed me to ssh into my pi with the fresh image.
