Re: Raspbian Stretch: Wifi not starting on boot
Can confirm that this worked for me aswell. must state that i get an error when rebooting " [FAILED] FAILED TO START RAISE NETWORK INTERFACES " but it works for now. some official communication from Raspberry.org would be nice with new releases that explains what and why they @@@@ the system
Hai guys ..I am new budy..and my first post
I was in a similar ccondition .and I did all according to forum
Edited WPA supplicant then network interfaces file and dhcpcd file.
Then enabled systemctl wpa_ supplicant. Service,but still not working ?
Sudo ifup wlan0 now recognize wlan0 interface but shows /sbin/wpa_supplicant deamon failed to start.
/etc/network/if-pre-up.d/wpasupplicant exited with return code=1.
Ifup:failed to bring up wlan 0
And i dont find afile named interface in /var/run as mentioned in wpa_supplicant.conf using file manager.
iwlist scan wlan0 gives me all thehotspot around..so my adapter is working. Hhm.
Is this the problem of my specific release of raspbian image??
Fed up completely..worked many hours please help
- DougieLawson
Run wpa_supplicant from a command line with
sudo wpa_supplicant -d -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
To get lots of debugging messages. Run it with -dd for even more debugging noise.
Thanks for all the help.
In the end I got both my cabled network and my wifi up and running by editing the two mentioned files.
add to /etc/wpa_supplicant/wpa_supplicant.conf the following lines
country=XX
ctrl_interface=/var/run/wpa_supplicant
network={
ssid="**********"
psk="***********"
and change /etc/network/interfaces to
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.1.88
netmask 255.255.255.0
gateway 192.168.1.254
auto wlan0
iface wlan0 inet static
address 192.168.1.86
or whatever you require in the way of ip addresses.
key is the addition of the lines starting with auto
Once done, reboot and check with ifconfig.
P.S. One small glitch, if eth0 is not plugged in, wlan0 will not start!
country=XX
network={
ssid="**********"
psk="***********"
auto eth0
auto wlan0
You shouldn't use /etc/network/interfaces to assign static network settings. That is now accomplished in /etc/dhcpcd.conf.
My advice applies to RaspiOS only. Please mention if you use another OS.
I just finished two days of flogging with "wlan0 not associated" with 2017-09-07-raspbian-stretch on a Pi3 that was playing nice under jessie-lite.
I tried the headless method with: wpa_supplicant.conf per the thread head:
country=US
update_config=1
network={
ssid=“myssid”
scan_ssid=1
psk=“mypasskey”
key_mgmt=WPA-PSK
Then I tried stock stretch hooking a keyboard and monitor to edit the /etc/wpa_supplicant/wpa_supplicant.conf - to no avail
I ended up having to:
sudo wpa_supplicant -Dnl80211 -iwlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
(which said there was some problem and suggested I remove /var/run/wpa_supplicant/wlan0 )
sudo rm /var/run/wpa_supplicant/wlan0
(kept saying auth key failure)
and then a reboot got wlan0 to come up and all is well now.
country=US
update_config=1
network={
ssid=“myssid”
scan_ssid=1
psk=“mypasskey”
key_mgmt=WPA-PSK
Have there been recent changes to the headless wifi configuration for the pi zero w? I'm using the 2017-09-07 distribution (2017-09-07-raspbian-stretch-lite.img) and the changes outlined in this thread are not working.
Here's my setup:
cat /etc/wpa_supplicant/wpa_supplicant.conf
country=US
update_config=1
network={
ssid="<ssid removed>"
#psk="<password removed>"
psk=theHashCreatedByTheFunction-wpa_passphrase
/etc/network folder exists but is empty
reading about issues about "Predictable Network Interface Names" I also tried adding this to cmdline.txt in the root folder:
net.ifnames=0
No cigar. Device boots but is not getting an IP address via DHCP. I've checked both the router and using NMAP.
Here's my setup:
country=US
update_config=1
network={
net.ifnames=0
- ShiftPlusOne
Could you please post the output of "sudo journalctl"?jughead wrote: ↑Thu Nov 09, 2017 2:14 amHave there been recent changes to the headless wifi configuration for the pi zero w? I'm using the 2017-09-07 distribution (2017-09-07-raspbian-stretch-lite.img) and the changes outlined in this thread are not working.
Here's my setup:
country=US
update_config=1
network={
net.ifnames=0
I've tried all your tips but cannot get it working.
I've changed the interfaces file and the wpa_supplicant file to the things you written but wifi is not booting on startup. If I start the wlan myself, it does not connect to my network with the supplied information in the wpa file.
What is going on? I've spent 6 hours on this now. Why is Wifi disabled as default?
Is it supposed to be like this?
- HawaiianPi
WiFi is not disabled by default, and "just works" for most people.
This is the procedure I use for setting up headless boot with SSH and wireless network. It works with Raspbian Jessie or Stretch, Desktop or Lite, and with the built-in WiFi on the Pi3, or a Raspbian compatible USB WiFi dongle on other models (tested on an old model B, Pi2 and Pi Zero). Everything is done before you boot the SD card, and can be done on a Windows or Mac computer which only has access to the small FAT32 boot partition of a Raspbian SD card.
If this doesn't work, then check your router for security settings like MAC address filtering or wireless client/AP isolation. Also, make sure you are editing wpa_supplicant.conf with a pure text editor (anything that adds hidden formatting codes will mess it up).
- Grab the latest Raspbian image from https://www.raspberrypi.org/downloads/raspbian/
- Grab the Etcher software from https://etcher.io/
- Install Etcher and use it to write the Raspbian image to your SD card. You don't need to extract the image or format the card prior to writing. Just choose the Raspbian .zip, pick your SD card and write (if you have trouble, verify the SHA256 checksum of the download).
- Remove and reinsert the SD card so that your Windows or Mac PC can see the small FAT32 partition on the SD card.
- On that small partition, create a file with the name ssh (or ssh.txt).
- To connect to a wireless network, create another file on the FAT32 partition called wpa_supplicant.conf which has the following inside:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 country=US network={ ssid="Your network SSID" psk="Your WPA/WPA2 security key" key_mgmt=WPA-PSK }
- Edit country=, ssid= and psk= with your information and save the file.
- Safely eject the card from your PC and use it to boot the Pi.
@aradove: Did you modify /etc/network/interfaces? If you are using Stretch, you shouldn't need to do that. Post what you have in that file.
Edit: If you have something like this in /etc/network/interfaces, the interface will fail to start.
If you want to assign static network settings, do that in /etc/dhcpcd.conf.
@SurferTim, @HawaiianPi
I followed your guide and it worked right away. So I must have done something wrong.
May it be so that I added the files on second boot of pi? Or the settings I had below?
This is what I had in my interface. Does this destroy the settings? (I removed the default commented code)
# allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
This is all you should need in /etc/network/interfaces if you are using an onboard wifi unit.
You may need this if a usb wifi device
auto wlan0
allow-hotplug wlan0
- ShiftPlusOne
That /etc/network/interfaces is not needed for USB wifi devices either.SurferTim wrote: ↑Mon Nov 13, 2017 12:42 pmThis is all you should need in /etc/network/interfaces if you are using an onboard wifi unit.You may need this if a usb wifi deviceCode: Select all
source-directory /etc/network/interfaces.d auto wlan0 allow-hotplug wlan0 iface wlan0 inet manual
Reason: Fix typo and rephrase for clarity.
I didn't think so, but I don't have a RPi that doesn't have built-in wifi. I use a usb wifi device with the onboard wifi, and it doesn't need that.
OK, the result of the command is:
wpa_supplicant v2.4
random: Trying to read entropy from /dev/random
Successfully initialized wpa_supplicant
Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf'
country='GB'
ctrl_interface='DIR=/var/run/wpa_supplicant GROUP=netdev'
update_config=1
Line: 5 - start of a new network block
ssid - hexdump_ascii(len=13):
4d 4f xx xx xx 54 xx 52 xx 33 xx 32 43 MYSSID
PSK (ASCII passphrase) - hexdump_ascii(len=22): [REMOVED]
proto: 0x2
key_mgmt: 0x2
pairwise: 0x10
auth_alg: 0x1
PSK (from passphrase) - hexdump(len=32): [REMOVED]
Priority group 0
id=0 ssid='myssid'
Could not read interface wlan0 flags: No such device
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=0 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 0 iftype 2 (STATION)
nl80211: Failed to set interface 0 to mode 2: -19 (No such device)
wlan0: Failed to initialize driver interface
Failed to add interface wlan0
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
and reboot but wifi not work, insert the dongle wifi and any problems.
Jaume
wpa_supplicant v2.4
country='GB'
update_config=1
proto: 0x2
key_mgmt: 0x2
pairwise: 0x10
auth_alg: 0x1
Priority group 0
id=0 ssid='myssid'
Jaume
I don't know what the "failing predictable interface names" is supposed to be but apparently the 2017-09-07 releaseShiftPlusOne wrote: ↑Mon Aug 21, 2017 12:30 pmYup, failing predictable interface names are a known issue and the next image will disable them by default.
Is everybody else who is seeing the issue missing the "ctrl_interface=/var/run/wpa_supplicant" line?
* Disable predictable network interface names for Ethernet devices
Milliways wrote: ↑Sun Nov 26, 2017 9:25 amI don't know what the "failing predictable interface names" is supposed to be but apparently the 2017-09-07 releaseShiftPlusOne wrote: ↑Mon Aug 21, 2017 12:30 pmYup, failing predictable interface names are a known issue and the next image will disable them by default.
Is everybody else who is seeing the issue missing the "ctrl_interface=/var/run/wpa_supplicant" line?Can you please explain HOW so I can undo the change. (I know I could do a forensic analysis to find this myself.)Code: Select all
Just use the appropriate option that has been added to the raspi-config utility for this purpose.
(So the forensics might be as simple as reading the raspi-config shell script to see how the change is implemented.)
I haven't checked lately, but the last time I used raspi-config, it did not use predictable interface names for wlan0, and caused me a bit of grief.
If it still doesn't rename wlan0, this will.
To use mac based interface names in Stretch
Move or remove /etc/systemd/network/99-default.link
Open /etc/systemd/network/99-default.link with a text editor (new, empty file).
Insert this:
Reboot
Insert this:
[Link]
NamePolicy=kernel database onboard slot path mac
MACAddressPolicy=persistent
I have just looked through all the menu in raspi-config (on a fresh install), and can't seem to find any means of changing.B.Goode wrote: ↑Sun Nov 26, 2017 12:13 pmMilliways wrote: ↑Sun Nov 26, 2017 9:25 amI don't know what the "failing predictable interface names" is supposed to be but apparently the 2017-09-07 releaseShiftPlusOne wrote: ↑Mon Aug 21, 2017 12:30 pmYup, failing predictable interface names are a known issue and the next image will disable them by default.
This is not included in Raspberry Pi reference 2017-09-07, which broke the feature, but is available in an updated version. (Maybe the Foundation realised the error of its ways!)
Unbelievable and unacceptable the Foundation somehow allowed these issues to flood us. I still can't get my Zero to bloody connect to wifi correctly on a static IP after hours of chasing rabbits! I don't know how the upgrade to Stretch was "managed" for wifi connection -- but I'd say somebody deserves a little "chat" at the water cooler. The Foundation has taken many, many harmful hits as a result of all this totally avoidable nonsense.
It is unclear which of "these issues" you are complaining about.PorterDon wrote: ↑Tue Dec 05, 2017 7:37 amUnbelievable and unacceptable the Foundation somehow allowed these issues to flood us. I still can't get my Zero to bloody connect to wifi correctly on a static IP after hours of chasing rabbits! I don't know how the upgrade to Stretch was "managed" for wifi connection -- but I'd say somebody deserves a little "chat" at the water cooler. The Foundation has taken many, many harmful hits as a result of all this totally avoidable nonsense.
My problem is that the Foundation FINALLY introduced Predictable Network Names, more than a year after comparable distributions, only to get cold feet 3 weeks later.
I agree that their communication leaves much to be desired.
Most of this thread is about various ill-informed attempts to modify interface naming. I was always simple to select either the old (unpredictable) behaviour or Predictable Network Names, and now this is in raspi-config.
See How to set up networking/WiFi for a less passionate analysis.
- ShiftPlusOne
What issues would that be and how would you have done it instead? Every change has been made for a good reason and has been the result of changes upstream.PorterDon wrote: ↑Tue Dec 05, 2017 7:37 amUnbelievable and unacceptable the Foundation somehow allowed these issues to flood us. I still can't get my Zero to bloody connect to wifi correctly on a static IP after hours of chasing rabbits! I don't know how the upgrade to Stretch was "managed" for wifi connection -- but I'd say somebody deserves a little "chat" at the water cooler. The Foundation has taken many, many harmful hits as a result of all this totally avoidable nonsense.
- ShiftPlusOne
Nothing to do with the Foundation at all. We follow Debian and this came as a result of the move to Stretch.Milliways wrote: My problem is that the Foundation FINALLY introduced Predictable Network Names,
There was a flood of people complaining and saying it's the worst thing ever. Also, at the time of release, dhcpcd would grab the interface and the rename would fail. Having it only sort of kind of work defeats the point of it. Based on the feedback on the forum, a discussion in the office and the renaming issue, we took it out. Recognising that some users would prefer predictable names, the option was added to raspi-config. A later version of dhcpcd fixed the interface renaming issue.Milliways wrote:only to get cold feet 3 weeks later
