Does this site (raspberrypi.org) have an up-to-date list of "official" (or "approved") repositories which it expects users to use?
It seems like this site expects people to use Raspbian, and Raspbian lists its official repository on its site.
But, I was trying to troubleshoot a Java issue and saw the post on the blog (from 2013), with the instruction about just running the two commands (update && install) to install the package. However, the Raspbian repository for Debian Jessie does not contain that package. Only when I asked about its absence in that repository, did someone mention I should use a different repository, one to which I had never seen a reference on any official channels. I would think that a mention on this site's blog would also mention that a user would need to add a different repository, but I couldn't find a mention of that anywhere. Have I just missed the page that explains all of this?
Repositories which Pi endorses
Re: Repositories which Pi endorses
Different operating systems will have different repositories. The only official operating system is Raspbian, and the only official/endorsed repositories are the one that is default when you install Raspbian. So only apt-sources that end with "raspberrypi.org" are official. ( but because of load balancing you will be redirected to one of many official mirrors when you install packages )
The raspbian.org web site is not ( afaik ) official and most of the information there should be considered outdated.
There are some times when peoples needs can not be fulfilled from the official repository. So blogs and this forum might suggest that you add another apt-source. You do this on your own risk and there is no guarantee that the repository still exists or work with the current version of Raspbian.
This is not true. raspbian.org is the main repository for Raspbian. There's an additional repository "on top" from raspberrypi.org which adds modified and additional packages.
Minimal Kiosk Browser (kweb)
But can the information on the web page be trusted ? The apt-source example refers to Wheezy, Installation guide dated 2012 etc..This is not true. raspbian.org is the main repository for Raspbian. There's an additional repository "on top" from raspberrypi.org which adds modified and additional packages.
- DougieLawson
There's lots of info here: http://raspbian.org/
I downloaded the latest image from Raspberry Pi just to see the repositories it used. And indeed, it had:
# in /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi
# in /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ stretch main ui
http://archive.raspbian.net/palswim wrote: ↑Wed Aug 23, 2017 5:57 pmI downloaded the latest image from Raspberry Pi just to see the repositories it used. And indeed, it had:Still, it would be nice to have a page to reference on rasberrypi.org (or even raspbian.org) to see the official repositories rather than having to download and mount the image.Code: Select all
# in /etc/apt/sources.list deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi # in /etc/apt/sources.list.d/raspi.list deb http://archive.raspberrypi.org/debian/ stretch main ui
I did check my own fresh install of Raspbian Stretch (Lite) before I posted:palswim wrote: ↑Wed Aug 23, 2017 5:57 pmI downloaded the latest image from Raspberry Pi just to see the repositories it used. And indeed, it had:Still, it would be nice to have a page to reference on rasberrypi.org (or even raspbian.org) to see the official repositories rather than having to download and mount the image.Code: Select all
pi@raspberrypi:/etc/apt/sources.list.d $ cat raspi.list
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspberrypi.org/debian/ stretch main ui
How would I have known about these without asking in this thread? I am saying that no official page lists the correct repositories so that I would know about them. The Raspbian page lists only the raspbian.org source.gkreidl wrote: ↑Wed Aug 23, 2017 6:16 pmhttp://archive.raspbian.net/palswim wrote: ↑Wed Aug 23, 2017 5:57 pmStill, it would be nice to have a page to reference on rasberrypi.org (or even raspbian.org) to see the official repositories rather than having to download and mount the image.
If you're confused about the mismatch between the contents of your raspi.list file and what I posted, I posted just the uncommented lines from my sources.list and raspi.list files.topguy wrote: ↑Wed Aug 23, 2017 6:30 pmI did check my own fresh install of Raspbian Stretch (Lite) before I posted:palswim wrote: ↑Wed Aug 23, 2017 5:57 pmStill, it would be nice to have a page to reference on rasberrypi.org (or even raspbian.org) to see the official repositories rather than having to download and mount the image.Code: Select all
So.. I'm confused...Code: Select all
pi@raspberrypi:/etc/apt/sources.list.d $ cat raspi.list deb http://archive.raspberrypi.org/debian/ stretch main ui # Uncomment line below then 'apt-get update' to enable 'apt-get source' #deb-src http://archive.raspberrypi.org/debian/ stretch main ui
No, I had confused myself with the assumption that if there was stuff in "/etc/apt/sources.list.d" you wouldn't use "/etc/apt/sources.list" but gkreidl is absolutely correct in his statement. The Raspbian you download from here depends on both raspbian.org and raspberrypi.org repositories.
