andermutu
Crontab not working at reboot
Sun Sep 17, 2017 5:31 pm
Hello everybody:
I am trying to run two Python scripts with Crontab. The problem is that if I try to run them with Crontab every 5 minutes everything works well. But if I try to run them with @reboot none of them work. There is my Crontab file:
It works:
*/5 * * * * python /home/pi/Desktop/Telegram/pyTelegramBotAPI/ComandosRes.py
*/5 * * * * sudo python /home/pi/Desktop/Telegram/pyTelegramBotAPI/Correo+.py
It does not work:
@reboot sudo python /home/pi/Desktop/Telegram/pyTelegramBotAPI/Correo+.py
@reboot python /home/pi/Desktop/Telegram/pyTelegramBotAPI/ComandosRes.py
Any idea or suggestion is welcomed. Thanks in advance. :D
pcmanbob
Re: Crontab not working at reboot
Sun Sep 17, 2017 8:52 pm
Hi.
It probably that your pi has not reached a suitable point in the boot process to actually run your commands, for example networking may not be ready
Try adding a delay of 60 seconds to each entry like this
@reboot sleep 60 && sudo python /home/pi/Desktop/Telegram/pyTelegramBotAPI/Correo+.py
@reboot sleep 60 && python /home/pi/Desktop/Telegram/pyTelegramBotAPI/ComandosRes.py
also its not good practice to run sudo like that if you want to run your script at root the use sudo crontab -e to create your cron line in the root cron.
Sun Sep 17, 2017 9:57 pm
Is this a nasty case of "sudoitis" where the OP assumes everything remotely complex needs to run under sudo?
Martin Frezman
Sun Sep 17, 2017 10:01 pm
False. OP, please ignore this comment by the previous poster.
A) There is nothing wrong with using sudo in crontab (or anywhere else that you need it to get your work done).
B) Editing the root crontab is a formula for pain and suffering. All sorts of bad things can result, starting with just the general hassle of having to keep track of two files, when one is sufficient.
Incidentally, this advice (to use "sudo crontab -e") is given frequently in this forum, so the previous poster can be forgiven for being taken in.
Martin Frezman
Sun Sep 17, 2017 10:02 pm
Quite possibly. Impossible to say w/o seeing the code.
asandford
Sun Sep 17, 2017 11:23 pm
Depends which users crontab is trying to run the code, the OP doesn't say.
Perhaps their 5 minute code runs as Pi and now they're trying to run as root at reboot?
sudo crontab -e will edit the root crontab and shouldn't need the use of sudo <command> as it's run as root anyway.
I would say to the OP to fully qualify the path of python as well, as the root crontab environment is scarcely populated.
moonfarms
Wed Dec 13, 2017 1:39 pm
I have same problem, slightly different:
I have two script.py in same directory: /home/pi, same permission
-rwxr-xr-x 1 pi pi 1335 Dec 13 09:55 pws.py
-rwxr-xr-x 1 pi pi 937 Nov 19 11:04 bmp180datalogger.py
crontab:
@reboot /home/pi/./bmp180datalogger.py &
@reboot /home/pi/./pws.py &
bmp180datalogger.py works pws.py not
I can run both from terminal
also tried
@reboot python /home/pi/./pws.py &
@reboot python2.7 /home/pi/./pws.py &
@reboot python2.7 /home/pi/pws.py &
all will run from :/etc/rc.local
Any help greatly appreciated
pcmanbob
Wed Dec 13, 2017 8:59 pm
What does pws.py do ?
does it need the gpio or network to be available. ?
moonfarms
Thu Dec 14, 2017 10:27 am
thank you for your time, here is the code:
#!/usr/bin/env python
from lxml import html
import requests
import sys
import time
import datetime
FREQUENCY_SECONDS = 300
while True:
page = requests.get('http://192.168.88.18/livedata.htm')
tree = html.fromstring(page.content)
relPressure = tree.xpath('//input[@name="RelPress"]')[0].value
outTemp = tree.xpath('//input[@name="outTemp"]')[0].value
outHumid = tree.xpath('//input[@name="outHumi"]')[0].value
windDir = tree.xpath('//input[@name="windir"]')[0].value
windSpeed = tree.xpath('//input[@name="avgwind"]')[0].value
windGust = tree.xpath('//input[@name="gustspeed"]')[0].value
solarRadiation = tree.xpath('//input[@name="solarrad"]')[0].value
uv = tree.xpath('//input[@name="uv"]')[0].value
uvi = tree.xpath('//input[@name="uvi"]')[0].value
rainHourly = tree.xpath('//input[@name="rainofhourly"]')[0].value
ts = time.time()
st = datetime.datetime.fromtimestamp(ts).strftime('%Y%m%d%H%M')
f = open("pwsdata.txt","a")
with open("pwsdata.txt", "a") as f:
f.write(st + ",")
f.write(relPressure + ",")
f.write(outTemp + ",")
f.write(outHumid + ",")
f.write(windDir + ",")
f.write(windSpeed + ",")
f.write(windGust + ",")
f.write(solarRadiation + ",")
f.write(uv + ",")
f.write(uvi + ",")
f.write(rainHourly + "\n")
time.sleep(FREQUENCY_SECONDS)
basically it is web scraping
RaTTuS
Contact: Twitter YouTube
Thu Dec 14, 2017 10:34 am
make a system.service file to do it and wait until the network is up before starting
reboot is too fast [also
code tags
will help
Covfefe
moonfarms
Thu Dec 14, 2017 10:36 am
Thank you for your time, will do and get back
pcmanbob
Thu Dec 14, 2017 10:53 am
Or as a quick work around just change your cron lines and add a 60 second delay.
@reboot sleep 60 && python /home/pi/bmp180datalogger.py
@reboot sleep 60 && python /home/pi/pws.py
moonfarms
Thu Dec 14, 2017 11:41 am
@pcmanbob
/home/pi/bmp180datalogger.py was working as is
BUT
SOLVED my problem
Thank you very much for your help, I have spent more than one day trying to solve the issue.
Regards, Paul
simonliu
Tue Mar 17, 2020 1:46 pm
Hi.
Bravo, adding 'sleep 60' solves my problem~!
AJSG1969
Fri Oct 09, 2020 9:38 am
I know this is an old post but thank you for the tip, was going crazy trying to figure out why @reboot was not working!!!
Andrew.
daBee
Tue Feb 09, 2021 6:04 pm
Even with sleep 60 mine ain't workin.
@reboot sleep 60 && /usr/bin/kismet >> /home/pi/rfs/_cronlog.txt 2>&1
No entry into the cronlog file as well. Not sure what's happening.
thagrol
Tue Feb 09, 2021 6:57 pm
This kismet? https://www.kismetwireless.net/
Giving you the benefit of the doubt that you're not doing anything nefarious with it...
  1. How do you know it's not working?
  2. Have you checked the process list?
    ps aux|grep kismet
  3. Does kismet actually produce any output to stdout when running correctly? If it doesn't, the log file will be empty.
  4. The sleep may be failing. That won't show in the log file.
    Try /bin/sleep instead of just sleep.
neilgl
Ah, kismet is a GUI program so you need to start it after desktop etc. has loaded. Edit the autostart:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
then add your command e.g. for my python timer GUI:
@python3 /home/pi/scripts/tktimer4.py
daBee
Tue Feb 09, 2021 9:56 pm
Well, I reboot it and there's nothing in the _cronlog.txt file, nor are there any new log files that archive what it's found. The unit works when I induce it manually.
But having said that, the processes:
root       580 99.9  0.3   5824  3404 ?        R    13:01 228:16 /usr/bin/kismet_client
pi         730  0.0  0.0   4784   500 pts/0    S+   16:49   0:00 grep kismet
Seems root is at 100% core speed, but not logging.
I don't have any desktop loaded on this. There's no file here: /etc/xdg/lxsession/LXDE-pi/autostart
There is a directory:
[Tue Feb 09 16:55 pi@pi /etc/xdg] tree
|-- autostart
|   `-- xdg-user-dirs.desktop
|-- systemd
|   `-- user -> ../../systemd/user
|-- user-dirs.conf
`-- user-dirs.defaults
Here's the OS info:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
neilgl
Tue Feb 09, 2021 10:35 pm
Hold on, that is kismet_client
Let’s rewind - what are you trying to achieve on reboot?
daBee
Tue Feb 09, 2021 10:42 pm
Ya I'm currently reading up on kismet_server.
neilgl
Tue Feb 09, 2021 10:55 pm
And not forgetting "You will not be able to capture from the built-in Wi-Fi on the Raspberry Pi 3 or Pi 4 unless you also install the nexmon driver patch. "
daBee
Tue Feb 09, 2021 11:03 pm
I'm on RP2. Testing kismet_server, which seems to be working.
thagrol
Wed Feb 10, 2021 12:32 am
I'm now thoroughly confused.
Assuming that comand you're calling in your crontab is correct and exists it's most likely down to the differences in environment between the logged in session and cron.
Try this in your crontab:
@reboot /bin/sleep 60; sudo -i -u pi "/usr/bin/kismet >>/home/pi/rfs/_cronlog.txt 2>&1"
Replace pi with the user you want to use. Yes, use the above even in root's crontab (though you'd use -u root in place of -u pi).
Key changes:
  • ";" rather than "&&" means the second command will be run regardless of whether the sleep fails or succeeds. With "&&" it only gets run if the sleep succceeds.
  • "sudo -i -u pi" gets you a much closer environment to the one you get after login.
  • Quoting the kismet command and the redirect should ensure what you get redirected is the output and errors from kismet not from sudo.
  • Removed a " " after ">>". Shouldn't have caused problems but you never know.
Is the sleep 60 there to try to ensure certain services are up before you run /usr/bin/kismet? If so you'll likely have more success using a systemd service with apropriate dependencies.
neilgl
Wed Feb 10, 2021 12:38 am
Pi2 with a usb WiFi dongle?
