California
How to run GUI application at boot
Sat Sep 23, 2017 11:45 am
Hello, I have a well working GUI application (PYQT4), which I would like to have started at boot of the RPi.
Some instructions from links below were followed but with no luck at all. My app is in "/home/pi/Project/Master_06.py".
https://www.dexterindustries.com/howto/ ... pberry-pi/
https://www.dexterindustries.com/howto/ ... t-startup/
What am I doing wrong?
Regards
topguy
Re: How to run GUI application at boot
Sat Sep 23, 2017 1:32 pm
None of the guides you link to are suitable for starting a GUI program.
They start the program before the X-server and desktop has loaded so your program fails to start.
viewtopic.php?t=131760
karrika
Sat Sep 23, 2017 1:42 pm
I have a similar desire to start the RPi-InfoScreen application at startup.
By adding a file called /etc/xdg/autostart/RPi-infoscreen.desktop
[Desktop Entry]
Type=Application
Name=RPi-infoscreen
Comment=Kivy RPI Infoscreen
NoDisplay=false
Exec=/usr/bin/lxterminal -e /home/pi/startKivy.sh
NotShowIn=GNOME;KDE;XFCE;
It will start a command line window and start my application that takes over the whole screen. The command line program is at /home/pi/startKivy.sh
#!/bin/bash
cd /home/pi/RPi-InfoScreen-Kivy
/usr/bin/python main.py
elParaguayo
Sat Sep 23, 2017 2:19 pm
Ha. Good piece of software to use as an example! :D
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
California
Sat Sep 23, 2017 5:20 pm
Thanks for help, obviously I am stil missing something. I can see CPU usage jumps over 20% but nothing happends.
/etc/xdg/autostart/SCADA.desktop
[Desktop Entry]
Type=Application
Name=SCADA
Comment=SCADA app
NoDisplay=false
Exec=/usr/bin/lxterminal -e /home/pi/Project/startMaster.sh
/home/pi/project/startMaster.sh
#!/bin/bash
cd /home/pi/Project
/usr/bin/python Master_06.py
karrika
Sat Sep 23, 2017 6:37 pm
Lol. It has been running in my hallway 24/7 since I added the bus displays to your project. It is almost in daily use. Very handy when you also see all traffic delays and cancellations. Thanks for creating it.
karrika
Sat Sep 23, 2017 7:57 pm
[Desktop Entry]
Type=Application
Name=SCADA
Comment=SCADA app
NoDisplay=false
#!/bin/bash
cd /home/pi/Project
Can you start the script file by typing
It has to be made executable.
chmod +x /home/pi/Project/startMaster.sh
California
Sat Sep 23, 2017 8:16 pm
Hm, it doesn't work ...
klricks
Sat Sep 23, 2017 9:39 pm
Have you tried using autostart as shown in the link in the 1st reply by topguy?
nano /home/pi/.config/lxsession/LXDE-pi/autostart
Your entry in autostart should look something like this added to the end of what's there already:
@lxterminal -e python /home/pi/Project/Master_06.py
If Python 3 then use python3 in above.
Unless specified otherwise my response is based on the latest and fully updated RPiOS Buster w/ Desktop OS.
Martin Frezman
Sun Sep 24, 2017 12:01 am
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
sudo??????????????????????????????
Note that in this case (*) it is not only unnecessary, but is dangerous. It is dangerous because you (usually) end up with these files owned by root - when they should obviously be owned by 'pi' - and then later on when you edit them the right way, you wonder why you get "permission denied" messages (and then you end up posting threads to this forum asking why things don't work).
(*) Specifically, using "sudo' to edit configuration files located in pi's home directory.
klricks
Sun Sep 24, 2017 12:55 am
I edited my post to remove sudo.
In this case it does not matter as the ownership of an existing file is not changed by sudo nano..... but it is a bad habit.
If a new file is created with sudo nano then it will be owned by root wherever it is located and that could cause problems later on.
California
Sun Sep 24, 2017 6:16 am
Thanks everybody, solution posted above works as expected.
With best regards,
Vlado
Return to “Python”
