EmaU
Debian Stretch: deactivate screen blanking
Fri Sep 29, 2017 3:51 pm
Hi all,
I am rather new to the Raspberry pi and would need your help. I have a Raspberry 3b attached to the 7 Inch Raspberry pi touchscreen running on Stretch.
I would like to deactivate the screen blanking in the new Debian Stretch but I have been unsuccessful so far. I found several suggestions on the internet but some seem rather old and do not apply to Stretch anymore (see 3.).
I tried:
1) in /etc/ issue
add TERM=Linux setterm -blank 0
2) in /etc/xdg/lxsession/LXDE-pi/autostart
add:
@xset s noblank
@xset s off
@xset -dpms
3) there was a suggestion to add 3 lines in /etc/kbd/config but this file does not exist in Stretch
Nothing works.
Does anyone have any other suggestions that I could try?
By the way, the method that I used in Jessie does not work anymore, on the contrary I lost the taskbar and the application menu and had a hard time to undo everything:
In Jessie (not Stretch) I did:
in /etc/lightdm/lightdm.conf
added in the [SeatDefaults] section:
xserver-command=X -s 0 -dpms
I would really appreciate your help
Regards,
EmaU
Re: Debian Stretch: deactivate screen blanking
Fri Sep 29, 2017 6:26 pm
Hi all,
I tried:
1) in /etc/ issue
add:
@xset s noblank
@xset s off
@xset -dpms
Nothing works.
Regards,
EmaU
https://www.raspberrypi.org/documentati ... ensaver.md
klricks
Fri Sep 29, 2017 9:40 pm
add:
@xset s noblank
@xset s off
@xset -dpms
That is the wrong autostart, try:
/home/pi/.config/lxsession/LDXE-pi/autostart
MarkDH102
Sat Sep 30, 2017 6:41 am
I did this :
sudo nano /etc/lightdm/lightdm.conf
in section [Seat:*] add or adjust line to say
That worked for me with a normal HDMI monitor...
Lena01
Sat Sep 30, 2017 10:21 am
hi all, my name is Lena)) I am a new member here )) thanks for your post , nice to meet you all here, in this web site
:D
EmaU
Sat Sep 30, 2017 11:43 am
Hi all,
Thanks to all for your quick replies. I do not have access to my raspberry pi at the moment but
I will try all your suggestions tomorrow evening and will report back about the results.
Kind regards and have a nice weekend,
EmaU
EmaU
Mon Oct 02, 2017 9:49 pm
Thanks a lot to klricks
Adding
@xset s noblank
@xset s off
@xset -dpms
to
/home/pi/.config/lxsession/LXDE-pi/autostart worked in Debian Stretch.
Even after 30 minutes no blank monitor, therefore my question is solved.
re: fruitoftheloom
I am sorry, but I did not try your suggestion because I did not want to install another software.
Thanks a lot for your help to all of you.
Kind regards,
EmaU
mikevanis
Tue Oct 02, 2018 10:32 am
The above did not work for me. I think it's because the X session is spawned from lightdm. What DID work for me was modifying the x-server command options in /etc/lightdm/lightdm.conf to:
aBUGSworstnightmare
Tue Oct 02, 2018 11:35 am
install xscreensaver and deactivate Screen blanking.
sudo apt install xscreensaver
