Hello Guys!
My Pi connects to wrong Wifi-network at startup.
How do I make it to be an other that is the default wifi-network?
Best regards
Fredrik
Re: How to forget a Wifi-network?
Open the file /etc/wpa_supplicant/wpa_supplicant.conf and remove the offending network entry.
sudo nano /etc/wpa_supplicant/wpa_supplicant.confMy advice applies to RaspiOS only. Please mention if you use another OS.
Hello!
Thanks a lot!
Worked perfect!
Best regards
Fredrik
Thanks a lot!
Worked perfect!
Best regards
Fredrik
