Custom Splash Screen
I followed this guide https://yingtongli.me/blog/2016/12/21/splash.html to create a custom splash screen and for the most part it works. My image loads for about one second and then i get the "Welcome to the Raspberry Pi Desktop Powered by Raspbian". is there a way to get rid of this screen on boot and show my image instead?
- DougieLawson
Re: Custom Splash Screen
Try changing the image at: /usr/share/plymouth/themes/pix/splash.png
The splash.png image is located at:
You can rename or delete the default image (splash.png) then copy your image to /usr/share/plymouth/themes/pix/ and then rename your image as splash.png
Note that your image is likely to be overwritten on a future update(s).
Since the splash screen is only displayed for a couple of seconds you might want to change the wallpaper image to your own image as well.
perfect. just what i was looking for. Thanks!
Rather than overwrite the existing splash screen, which might be overwritten with the original again when there are updates, I think it best to create a new theme and switch Plymouth to using that. AFAIK, updates don't tend to delete anything in /usr/share (only overwrite) and not mess with changed files in /etc unless you ask them to. The themes are in /usr/share/plymouth/themes and are chosen in /etc/plymouth/plymouthd.conf - it's fairly self explanatory therefore how to create a new theme and use that.
In our case I need to be able to quickly set up a new Pi at any time so after creating the 1024x768 PNG and uploading it to some webspace (you could also use imgur) I have this script in my notes that I paste into Putty to quickly do all the changes. You'd just have to update the URL of the image, or transfer it across some other way.
Basically you're just creating a new theme directory for "mytheme" based on the default "pix" theme, renaming the various files to match, changing the description from "Raspberry Pi Desktop Splash" to "My Desktop Splash" and updating the conf file to use it.
cd /usr/share/plymouth/themes
sudo cp -a pix mytheme
cd mytheme
sudo mv pix.plymouth mytheme.plymouth
sudo mv pix.script mytheme.script
sudo wget http://example.com/images/splash.png
sudo sed -i 's/pix/mytheme/g; s/Raspberry Pi/My/g' mytheme.plymouth
sudo sed -i 's/pix/mytheme/g' /etc/plymouth/plymouthd.conf
I'm using the latest Rasbian x86.
I changed /usr/share/plymouth/themes/pix/splash.png with another 1024x768 png image but it does not change the startup splash screen at all.
Did I miss something ?
Thanks in advance for your help !
I am having the same issue where the new splash image does not load at all. its the same size, file format, and almost identical file size. Did they change something with Raspbian Stretch on the RPi 3B+?
I find it easier to leave the original, & just copy png's to the folder, as per screenshot.
Next edit
pix.script
to activate the png required, commenting out any others, as in the other screenshot.
It doesn't matter what size png (within reason) as it will be scaled as can be seen by reading the rest of the file.
It works fine on a 3b+ so no changes required there.
Next edit
pix.script
- Attachments
- pix.script2.png (30.26 KiB) Viewed 65431 times
- pix.script.png (51.79 KiB) Viewed 65431 times
Thank you, but did you try that on the latest Debian Stretch ?
I just tried, and I get the same result as before. I still got the "Welcome to raspberry pi desktop" splash screen, not my new image.
I'm using it on various RPi boards, the latest which reports:
pi@s3:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
pi@s3:~ $ uname -a
Linux s3 4.14.33-v7+ #1108 SMP Mon Apr 9 17:42:29 BST 2018 armv7l GNU/Linux
pi@s3:~ $ vcgencmd version
Apr 9 2018 17:50:55
Copyright (c) 2012 Broadcom
version fd11c813c25906736dafc419898c082356d535cf (clean) (release)
pi@s3:~ $
Well I have the same version.
I searched for any other splash.png or similar size file on the system, and nothing... /usr/share/plymouth/themes/pix/splash.png seems to be the source.
It seems the splash screen is compiled in plymouth or something like that. Is there something else to perform after changing the image or editing the conf file ?
I thought my png was not in the right format (alpha channel or dpi...) so I just installed gimp, opened the /usr/share/plymouth/themes/pix/splash.png, painted over it, saved the image. on reboot I still have the clean 'Welcome to pi desktop image'
I don't understand how it's working on your system and not mine...
hello guys the problem is that your splash display is disabled in your cmdline.txt file in the boot directory. open the cmdline file
sudo nano /boot/cmdline.txt
change 'console=tty1' to 'console=tty3,
and then add this line to the end, make sure everything is on the same line and the commands are seperated by space
splash quiet plymouth.ignore-serial-consoles logo.nologo vt.global_cursor_default=0
Hello ! And thank you for your suggestion.
I had no cmdline.txt in my /boot directory.
I created one based on a pi filesystem containing :
It still didn't take into account my new png file.
Then I integrated it to /etc/default/grub :
I ran update-grub
I checked that it was really in the boot options upon restart.
I still get that damn raspberry on my splash screen !
dwc_otg.lpm_enable=0 console=tty3 root=/dev/sda1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait splash quiet plymouth.ignore-serial-consoles logo.nologo vt.global_cursor_default=0
GRUB_CMDLINE_LINUX_DEFAULT="splash quiet plymouth.ignore-serial-consoles logo.nologo vt.global_cursor_default=0"
You and other posters here are very confused....
The OP asked about Raspbian on a RASBERRY PI.
You are asking about the Raspbery Pi Desktop OS for PC and MAC. (Debian x86)
They are different OS.
There is a sub forum for Debian x86 where you should be asking... viewforum.php?f=116
