[Sorry if this is a thread hijack, but the partial fix below might help someone.]
I'm getting the same behavior after a successful copy by SD CARD COPIER.
A banner on the Panel:
Drive was removed without ejecting
Please use menu to eject before removal
Checking with File Manager shows nothing mounted, so I don't think it is real; perhaps the unmounting by SD Card Copier did not get communicated? I think it might be intermittent too.
The banner is quite persistent, but running this clears it (and other panel bugs such as 100%
pcmanfm seen on Panel as >24% cpu and 100% single core
htop ):
Is there is a better way to handle
Working via TightVnc client to RealVNC on RPi 4B (I believe both my Rev 1.1 and 1.2). I think it might happen when directly on the machines too sometime, but I don't usually work that way. The TightVNC sessions attach to the same screen as a live session rather than spawn a new one.
Slightly annoying, but ...
cheers
