Here is my journalctl. Thanks ShiftPlusOne.
-- Logs begin at Fri 2016-11-04 00:16:42 +07, end at Mon 2017-11-27 10:23:25 +07. --
Nov 04 00:16:42 raspberrypi kernel: Booting Linux on physical CPU 0x0
Nov 04 00:16:42 raspberrypi kernel: Linux version 4.9.41-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1023 SMP Tue Aug 8 16:00:15 BST 2017
Nov 04 00:16:42 raspberrypi kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Nov 04 00:16:42 raspberrypi kernel: CPU: div instructions available: patching division code
Nov 04 00:16:42 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Nov 04 00:16:42 raspberrypi kernel: OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
Nov 04 00:16:42 raspberrypi kernel: cma: Reserved 8 MiB at 0x3ac00000
Nov 04 00:16:42 raspberrypi kernel: Memory policy: Data cache writealloc
Nov 04 00:16:42 raspberrypi kernel: On node 0 totalpages: 242688
Nov 04 00:16:42 raspberrypi kernel: free_area_init_node: node 0, pgdat 80c6eec0, node_mem_map ba3a1000
Nov 04 00:16:42 raspberrypi kernel: Normal zone: 2133 pages used for memmap
Nov 04 00:16:42 raspberrypi kernel: Normal zone: 0 pages reserved
Nov 04 00:16:42 raspberrypi kernel: Normal zone: 242688 pages, LIFO batch:31
Nov 04 00:16:42 raspberrypi kernel: percpu: Embedded 14 pages/cpu @ba35b000 s25600 r8192 d23552 u57344
Nov 04 00:16:42 raspberrypi kernel: pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
Nov 04 00:16:42 raspberrypi kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Nov 04 00:16:42 raspberrypi kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 240555
Nov 04 00:16:42 raspberrypi kernel: Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=020c3677-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
Nov 04 00:16:42 raspberrypi kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
Nov 04 00:16:42 raspberrypi kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Nov 04 00:16:42 raspberrypi kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Nov 04 00:16:42 raspberrypi kernel: Memory: 940356K/970752K available (7168K kernel code, 484K rwdata, 2012K rodata, 1024K init, 778K bss, 22204K reserved, 8192K cma-reserved)
Nov 04 00:16:42 raspberrypi kernel: Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c79094 ( 485 kB)
.bss : 0x80c7b000 - 0x80d3da64 ( 779 kB)
Nov 04 00:16:42 raspberrypi kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Nov 04 00:16:42 raspberrypi kernel: Hierarchical RCU implementation.
Nov 04 00:16:42 raspberrypi kernel: Build-time adjustment of leaf fanout to 32.
Nov 04 00:16:42 raspberrypi kernel: NR_IRQS:16 nr_irqs:16 16
Nov 04 00:16:42 raspberrypi kernel: arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
Nov 04 00:16:42 raspberrypi kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Nov 04 00:16:42 raspberrypi kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Nov 04 00:16:42 raspberrypi kernel: Switching to timer-based delay loop, resolution 52ns
Nov 04 00:16:42 raspberrypi kernel: Console: colour dummy device 80x30
Nov 04 00:16:42 raspberrypi kernel: console [tty1] enabled
Nov 04 00:16:42 raspberrypi kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Nov 04 00:16:42 raspberrypi kernel: pid_max: default: 32768 minimum: 301
Nov 04 00:16:42 raspberrypi kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Nov 04 00:16:42 raspberrypi kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Nov 04 00:16:42 raspberrypi kernel: Disabling cpuset control group subsystem
Nov 04 00:16:42 raspberrypi kernel: CPU: Testing write buffer coherency: ok
Nov 04 00:16:42 raspberrypi kernel: ftrace: allocating 22396 entries in 66 pages
Nov 04 00:16:42 raspberrypi kernel: CPU0: update cpu_capacity 1024
Nov 04 00:16:42 raspberrypi kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Nov 04 00:16:42 raspberrypi kernel: Setting up static identity map for 0x100000 - 0x100034
Nov 04 00:16:42 raspberrypi kernel: CPU1: update cpu_capacity 1024
Nov 04 00:16:42 raspberrypi kernel: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Nov 04 00:16:42 raspberrypi kernel: CPU2: update cpu_capacity 1024
Nov 04 00:16:42 raspberrypi kernel: CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Nov 04 00:16:42 raspberrypi kernel: CPU3: update cpu_capacity 1024
Nov 04 00:16:42 raspberrypi kernel: CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Nov 04 00:16:42 raspberrypi kernel: Brought up 4 CPUs
Nov 04 00:16:42 raspberrypi kernel: SMP: Total of 4 processors activated (153.60 BogoMIPS).
Nov 04 00:16:42 raspberrypi kernel: CPU: All CPU(s) started in HYP mode.
Nov 04 00:16:42 raspberrypi kernel: CPU: Virtualization extensions available.
Nov 04 00:16:42 raspberrypi kernel: devtmpfs: initialized
Nov 04 00:16:42 raspberrypi kernel: VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Nov 04 00:16:42 raspberrypi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Nov 04 00:16:42 raspberrypi kernel: futex hash table entries: 1024 (order: 4, 65536 bytes)
Nov 04 00:16:42 raspberrypi kernel: pinctrl core: initialized pinctrl subsystem
Nov 04 00:16:42 raspberrypi kernel: NET: Registered protocol family 16
Nov 04 00:16:42 raspberrypi kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
Nov 04 00:16:42 raspberrypi kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Nov 04 00:16:42 raspberrypi kernel: hw-breakpoint: maximum watchpoint size is 8 bytes.
Nov 04 00:16:42 raspberrypi kernel: Serial: AMBA PL011 UART driver
Nov 04 00:16:42 raspberrypi kernel: bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Nov 04 00:16:42 raspberrypi kernel: uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Nov 04 00:16:42 raspberrypi kernel: bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
Nov 04 00:16:42 raspberrypi kernel: SCSI subsystem initialized
Nov 04 00:16:42 raspberrypi kernel: usbcore: registered new interface driver usbfs
Nov 04 00:16:42 raspberrypi kernel: usbcore: registered new interface driver hub
Nov 04 00:16:42 raspberrypi kernel: usbcore: registered new device driver usb
Nov 04 00:16:42 raspberrypi kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2017-08-08 12:01
Nov 04 00:16:42 raspberrypi kernel: clocksource: Switched to clocksource arch_sys_counter
Nov 04 00:16:42 raspberrypi kernel: VFS: Disk quotas dquot_6.6.0
Nov 04 00:16:42 raspberrypi kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 04 00:16:42 raspberrypi kernel: FS-Cache: Loaded
Nov 04 00:16:42 raspberrypi kernel: CacheFiles: Loaded
Nov 04 00:16:42 raspberrypi kernel: NET: Registered protocol family 2
Nov 04 00:16:42 raspberrypi kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Nov 04 00:16:42 raspberrypi kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Nov 04 00:16:42 raspberrypi kernel: TCP: Hash tables configured (established 8192 bind 8192)
Nov 04 00:16:42 raspberrypi kernel: UDP hash table entries: 512 (order: 2, 16384 bytes)
Nov 04 00:16:42 raspberrypi kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Nov 04 00:16:42 raspberrypi kernel: RPC: Registered named UNIX socket transport module.
Nov 04 00:16:42 raspberrypi kernel: RPC: Registered udp transport module.
Nov 04 00:16:42 raspberrypi kernel: RPC: Registered tcp transport module.
Nov 04 00:16:42 raspberrypi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov 04 00:16:42 raspberrypi kernel: hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Nov 04 00:16:42 raspberrypi kernel: workingset: timestamp_bits=14 max_order=18 bucket_order=4
Nov 04 00:16:42 raspberrypi kernel: FS-Cache: Netfs 'nfs' registered for caching
Nov 04 00:16:42 raspberrypi kernel: NFS: Registering the id_resolver key type
Nov 04 00:16:42 raspberrypi kernel: Key type id_resolver registered
Nov 04 00:16:42 raspberrypi kernel: Key type id_legacy registered
Nov 04 00:16:42 raspberrypi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Nov 04 00:16:42 raspberrypi kernel: io scheduler noop registered
Nov 04 00:16:42 raspberrypi kernel: io scheduler deadline registered (default)
Nov 04 00:16:42 raspberrypi kernel: io scheduler cfq registered
Nov 04 00:16:42 raspberrypi kernel: BCM2708FB: allocated DMA memory fad10000
Nov 04 00:16:42 raspberrypi kernel: BCM2708FB: allocated DMA channel 0 @ bb80f000
Nov 04 00:16:42 raspberrypi kernel: Console: switching to colour frame buffer device 160x45
Nov 04 00:16:42 raspberrypi kernel: bcm2835-rng 3f104000.rng: hwrng registered
Nov 04 00:16:42 raspberrypi kernel: vc-cma: Videocore CMA driver
Nov 04 00:16:42 raspberrypi kernel: vc-cma: vc_cma_base = 0x00000000
Nov 04 00:16:42 raspberrypi kernel: vc-cma: vc_cma_size = 0x00000000 (0 MiB)
Nov 04 00:16:42 raspberrypi kernel: vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
Nov 04 00:16:42 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Nov 04 00:16:42 raspberrypi kernel: brd: module loaded
Nov 04 00:16:42 raspberrypi kernel: loop: module loaded
Nov 04 00:16:42 raspberrypi kernel: Loading iSCSI transport class v2.0-870.
Nov 04 00:16:42 raspberrypi kernel: usbcore: registered new interface driver smsc95xx
Nov 04 00:16:42 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Nov 04 00:16:42 raspberrypi kernel: Core Release: 2.80a
Nov 04 00:16:42 raspberrypi kernel: Setting default values for core params
Nov 04 00:16:42 raspberrypi kernel: Finished setting default values for core params
Nov 04 00:16:42 raspberrypi kernel: Using Buffer DMA mode
Nov 04 00:16:42 raspberrypi kernel: Periodic Transfer Interrupt Enhancement - disabled
Nov 04 00:16:42 raspberrypi kernel: Multiprocessor Interrupt Enhancement - disabled
Nov 04 00:16:42 raspberrypi kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
Nov 04 00:16:42 raspberrypi kernel: Dedicated Tx FIFOs mode
Nov 04 00:16:42 raspberrypi kernel: WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
Nov 04 00:16:42 raspberrypi kernel: FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
Nov 04 00:16:42 raspberrypi kernel: dwc_otg: Microframe scheduler enabled
Nov 04 00:16:42 raspberrypi kernel: WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058f7fc
Nov 04 00:16:42 raspberrypi kernel: WARN::hcd_init_fiq:460: FIQ ASM at 0x8058fb6c length 36
Nov 04 00:16:42 raspberrypi kernel: WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87a000
Nov 04 00:16:42 raspberrypi kernel: dwc_otg 3f980000.usb: DWC OTG Controller
Nov 04 00:16:42 raspberrypi kernel: dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Nov 04 00:16:42 raspberrypi kernel: dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
Nov 04 00:16:42 raspberrypi kernel: Init: Port Power? op_state=1
Nov 04 00:16:42 raspberrypi kernel: Init: Power Port (0)
Nov 04 00:16:42 raspberrypi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Nov 04 00:16:42 raspberrypi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 04 00:16:42 raspberrypi kernel: usb usb1: Product: DWC OTG Controller
Nov 04 00:16:42 raspberrypi kernel: usb usb1: Manufacturer: Linux 4.9.41-v7+ dwc_otg_hcd
Nov 04 00:16:42 raspberrypi kernel: usb usb1: SerialNumber: 3f980000.usb
Nov 04 00:16:42 raspberrypi kernel: hub 1-0:1.0: USB hub found
Nov 04 00:16:42 raspberrypi kernel: hub 1-0:1.0: 1 port detected
Nov 04 00:16:42 raspberrypi kernel: dwc_otg: FIQ enabled
Nov 04 00:16:42 raspberrypi kernel: dwc_otg: NAK holdoff enabled
Nov 04 00:16:42 raspberrypi kernel: dwc_otg: FIQ split-transaction FSM enabled
Nov 04 00:16:42 raspberrypi kernel: Module dwc_common_port init
Nov 04 00:16:42 raspberrypi kernel: usbcore: registered new interface driver usb-storage
Nov 04 00:16:42 raspberrypi kernel: mousedev: PS/2 mouse device common for all mice
Nov 04 00:16:42 raspberrypi kernel: bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
Nov 04 00:16:42 raspberrypi kernel: bcm2835-cpufreq: min=600000 max=1200000
Nov 04 00:16:42 raspberrypi kernel: sdhci: Secure Digital Host Controller Interface driver
Nov 04 00:16:42 raspberrypi kernel: sdhci: Copyright(c) Pierre Ossman
Nov 04 00:16:42 raspberrypi kernel: sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
Nov 04 00:16:42 raspberrypi kernel: mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
Nov 04 00:16:42 raspberrypi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Nov 04 00:16:42 raspberrypi kernel: ledtrig-cpu: registered to indicate activity on CPUs
Nov 04 00:16:42 raspberrypi kernel: hidraw: raw HID events driver (C) Jiri Kosina
Nov 04 00:16:42 raspberrypi kernel: usbcore: registered new interface driver usbhid
Nov 04 00:16:42 raspberrypi kernel: usbhid: USB HID core driver
Nov 04 00:16:42 raspberrypi kernel: vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
Nov 04 00:16:42 raspberrypi kernel: Initializing XFRM netlink socket
Nov 04 00:16:42 raspberrypi kernel: NET: Registered protocol family 17
Nov 04 00:16:42 raspberrypi kernel: Key type dns_resolver registered
Nov 04 00:16:42 raspberrypi kernel: Registering SWP/SWPB emulation handler
Nov 04 00:16:42 raspberrypi kernel: registered taskstats version 1
Nov 04 00:16:42 raspberrypi kernel: vc-sm: Videocore shared memory driver
Nov 04 00:16:42 raspberrypi kernel: [vc_sm_connected_init]: start
Nov 04 00:16:42 raspberrypi kernel: [vc_sm_connected_init]: end - returning 0
Nov 04 00:16:42 raspberrypi kernel: 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
Nov 04 00:16:42 raspberrypi kernel: sdhost: log_buf @ bad07000 (fad07000)
Nov 04 00:16:42 raspberrypi kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Nov 04 00:16:42 raspberrypi kernel: mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
Nov 04 00:16:42 raspberrypi kernel: mmc-bcm2835 3f300000.mmc: DMA channel allocated
Nov 04 00:16:42 raspberrypi kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Nov 04 00:16:42 raspberrypi kernel: mmc0: new high speed SD card at address b368
Nov 04 00:16:42 raspberrypi kernel: mmcblk0: mmc0:b368 SMISD 1.86 GiB
Nov 04 00:16:42 raspberrypi kernel: mmcblk0: p1
Nov 04 00:16:42 raspberrypi kernel: of_cfs_init
Nov 04 00:16:42 raspberrypi kernel: of_cfs_init: OK
Nov 04 00:16:42 raspberrypi kernel: Waiting for root device PARTUUID=020c3677-02...
Nov 04 00:16:42 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Nov 04 00:16:42 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 04 00:16:42 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Nov 04 00:16:42 raspberrypi kernel: Indeed it is in host mode hprt0 = 00021501
Nov 04 00:16:42 raspberrypi kernel: random: fast init done
Nov 04 00:16:42 raspberrypi kernel: mmc1: new high speed SDIO card at address 0001
Nov 04 00:16:42 raspberrypi kernel: usb 1-1: new high-speed USB device number 2 using dwc_otg
Nov 04 00:16:42 raspberrypi kernel: Indeed it is in host mode hprt0 = 00001101
Nov 04 00:16:42 raspberrypi kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Nov 04 00:16:42 raspberrypi kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov 04 00:16:42 raspberrypi kernel: hub 1-1:1.0: USB hub found
Nov 04 00:16:42 raspberrypi kernel: hub 1-1:1.0: 5 ports detected
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov 04 00:16:42 raspberrypi kernel: smsc95xx v1.0.5
Nov 04 00:16:42 raspberrypi kernel: smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a5:e2:71
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.3: new high-speed USB device number 4 using dwc_otg
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.3: New USB device found, idVendor=0781, idProduct=5530
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.3: Product: Cruzer
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.3: Manufacturer: SanDisk
Nov 04 00:16:42 raspberrypi kernel: usb 1-1.3: SerialNumber: 200535506311D321DF21
Nov 04 00:16:42 raspberrypi kernel: usb-storage 1-1.3:1.0: USB Mass Storage device detected
Nov 04 00:16:42 raspberrypi kernel: scsi host0: usb-storage 1-1.3:1.0
Nov 04 00:16:42 raspberrypi kernel: scsi 0:0:0:0: Direct-Access SanDisk Cruzer 1.00 PQ: 0 ANSI: 2
Nov 04 00:16:42 raspberrypi kernel: sd 0:0:0:0: [sda] 31250432 512-byte logical blocks: (16.0 GB/14.9 GiB)
Nov 04 00:16:42 raspberrypi kernel: sd 0:0:0:0: [sda] Write Protect is off
Nov 27 10:21:57 raspberrypi kernel: sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
Nov 27 10:21:57 raspberrypi kernel: sd 0:0:0:0: [sda] No Caching mode page found
Nov 27 10:21:57 raspberrypi kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Nov 27 10:21:57 raspberrypi kernel: sda: sda1 sda2
Nov 27 10:21:57 raspberrypi kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Nov 27 10:21:57 raspberrypi kernel: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Nov 27 10:21:57 raspberrypi kernel: VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
Nov 27 10:21:57 raspberrypi kernel: devtmpfs: mounted
Nov 27 10:21:57 raspberrypi kernel: Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
Nov 27 10:21:57 raspberrypi systemd[1]: System time before build time, advancing clock.
Nov 27 10:21:57 raspberrypi systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
Nov 27 10:21:57 raspberrypi systemd[1]: Detected architecture arm.
Nov 27 10:21:57 raspberrypi systemd[1]: Set hostname to <raspberrypi>.
Nov 27 10:21:57 raspberrypi systemd[1]: Listening on Journal Socket.
Nov 27 10:21:57 raspberrypi systemd[1]: Listening on udev Control Socket.
Nov 27 10:21:57 raspberrypi systemd[1]: Listening on fsck to fsckd communication Socket.
Nov 27 10:21:57 raspberrypi systemd[1]: Created slice User and Session Slice.
Nov 27 10:21:57 raspberrypi systemd[1]: Created slice System Slice.
Nov 27 10:21:57 raspberrypi systemd[1]: Created slice system-autologin.slice.
Nov 27 10:21:57 raspberrypi systemd[1]: Starting Restore / save the current clock...
Nov 27 10:21:57 raspberrypi systemd-journald[124]: Journal started
Nov 27 10:21:57 raspberrypi systemd-journald[124]: Runtime journal (/run/log/journal/28a3f56e669e4806afc628802a4f753f) is 11.5M, max 46.3M, 34.7M free.
Nov 27 10:21:57 raspberrypi systemd-modules-load[117]: could not open moddep file '/lib/modules/4.9.41-v7+/modules.dep.bin'
Nov 27 10:21:57 raspberrypi systemd-modules-load[117]: Failed to lookup alias 'i2c-dev': Function not implemented
Nov 27 10:21:57 raspberrypi fake-hwclock[114]: Mon 27 Nov 03:21:57 UTC 2017
Nov 27 10:21:57 raspberrypi systemd-fsck[115]: e2fsck 1.43.4 (31-Jan-2017)
Nov 27 10:21:57 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Nov 27 10:21:57 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Nov 27 10:21:57 raspberrypi systemd-fsck[115]: /dev/sda2: clean, 136151/955808 files, 1198854/3894528 blocks
Nov 27 10:21:57 raspberrypi systemd[1]: Started File System Check on Root Device.
Nov 27 10:21:57 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Nov 27 10:21:57 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Nov 27 10:21:57 raspberrypi kernel: EXT4-fs (sda2): re-mounted. Opts: (null)
Nov 27 10:21:57 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Nov 27 10:21:57 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Nov 27 10:21:57 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Nov 27 10:21:57 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Nov 27 10:21:57 raspberrypi systemd[1]: Started Load/Save Random Seed.
Nov 27 10:21:57 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Nov 27 10:21:57 raspberrypi systemd[1]: Started Set the console keyboard layout.
Nov 27 10:21:57 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Nov 27 10:21:57 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Nov 27 10:21:57 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Nov 27 10:21:57 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Nov 27 10:21:57 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Nov 27 10:21:57 raspberrypi systemd[1]: Reached target Paths.
Nov 27 10:21:57 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Nov 27 10:21:57 raspberrypi systemd[1]: Found device /dev/serial1.
Nov 27 10:21:58 raspberrypi mtp-probe[247]: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Nov 27 10:21:58 raspberrypi mtp-probe[254]: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
Nov 27 10:21:58 raspberrypi mtp-probe[254]: bus: 1, device: 4 was not an MTP device
Nov 27 10:21:58 raspberrypi mtp-probe[247]: bus: 1, device: 3 was not an MTP device
Nov 27 10:21:58 raspberrypi systemd-udevd[196]: could not open moddep file '/lib/modules/4.9.41-v7+/modules.dep.bin'
Nov 27 10:21:58 raspberrypi systemd[1]: Found device Cruzer boot.
Nov 27 10:21:58 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/020c3677-01...
Nov 27 10:21:58 raspberrypi systemd-fsck[268]: fsck.fat 4.1 (2017-01-24)
Nov 27 10:21:58 raspberrypi systemd-fsck[268]: /dev/sda1: 145 files, 42657/84273 clusters
Nov 27 10:21:58 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/020c3677-01.
Nov 27 10:21:58 raspberrypi systemd[1]: Mounting /boot...
Nov 27 10:21:58 raspberrypi systemd[1]: Mounted /boot.
Nov 27 10:21:58 raspberrypi systemd[1]: Reached target Local File Systems.
Nov 27 10:21:58 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Nov 27 10:21:58 raspberrypi systemd[1]: Starting Set console font and keymap...
Nov 27 10:21:58 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Nov 27 10:21:58 raspberrypi systemd[1]: Starting Raise network interfaces...
Nov 27 10:21:58 raspberrypi kernel: random: crng init done
Nov 27 10:21:58 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Nov 27 10:21:58 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Nov 27 10:21:58 raspberrypi systemd[1]: Started Set console font and keymap.
Nov 27 10:21:58 raspberrypi systemd[1]: Reached target NFS client services.
Nov 27 10:21:58 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Nov 27 10:21:58 raspberrypi systemd[1]: Reached target Remote File Systems.
Nov 27 10:21:58 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Nov 27 10:21:58 raspberrypi systemd[1]: Starting Network Time Synchronization...
Nov 27 10:21:58 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Nov 27 10:21:58 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Nov 27 10:21:59 raspberrypi systemd[1]: Started Network Time Synchronization.
Nov 27 10:21:59 raspberrypi systemd[1]: Reached target System Time Synchronized.
Nov 27 10:21:59 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 217 (plymouthd).
Nov 27 10:22:00 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Nov 27 10:22:00 raspberrypi systemd[1]: Reached target System Initialization.
Nov 27 10:22:00 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Nov 27 10:22:00 raspberrypi systemd[1]: apt-daily.timer: Adding 2h 4min 3.116548s random time.
Nov 27 10:22:00 raspberrypi systemd[1]: Started Daily apt download activities.
Nov 27 10:22:00 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 44min 24.395839s random time.
Nov 27 10:22:00 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Nov 27 10:22:00 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Nov 27 10:22:00 raspberrypi systemd[1]: Reached target Timers.
Nov 27 10:22:00 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Nov 27 10:22:00 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Nov 27 10:22:00 raspberrypi systemd[1]: Reached target Sockets.
Nov 27 10:22:00 raspberrypi systemd[1]: Reached target Basic System.
Nov 27 10:22:00 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Nov 27 10:22:00 raspberrypi systemd[1]: Started Regular background program processing daemon.
Nov 27 10:22:00 raspberrypi systemd[1]: Starting Login Service...
Nov 27 10:22:00 raspberrypi cron[331]: (CRON) INFO (pidfile fd = 3)
Nov 27 10:22:00 raspberrypi systemd[1]: Starting System Logging Service...
Nov 27 10:22:00 raspberrypi systemd[1]: Starting Check for v3d driver...
Nov 27 10:22:00 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Nov 27 10:22:00 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Nov 27 10:22:00 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Nov 27 10:22:00 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Nov 27 10:22:00 raspberrypi cron[331]: (CRON) INFO (Running @reboot jobs)
Nov 27 10:22:00 raspberrypi kernel: uart-pl011 3f201000.serial: no DMA platform data
Nov 27 10:22:00 raspberrypi liblogging-stdlog[334]: [origin software="rsyslogd" swVersion="8.24.0" x-pid="334" x-info="
http://www.rsyslog.com"] start
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: Successfully dropped root privileges.
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: avahi-daemon 0.6.32 starting up.
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: Successfully called chroot().
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: Successfully dropped remaining capabilities.
Nov 27 10:22:00 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Nov 27 10:22:00 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: No service file found in /etc/avahi/services.
Nov 27 10:22:00 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Nov 27 10:22:00 raspberrypi systemd[1]: Started System Logging Service.
Nov 27 10:22:00 raspberrypi systemd[1]: Started Check for v3d driver.
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: socket() failed: Address family not supported by protocol
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: Failed to create IPv6 socket, proceeding in IPv4 only mode
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: Network interface enumeration completed.
Nov 27 10:22:00 raspberrypi avahi-daemon[336]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 3117520522.
Nov 27 10:22:00 raspberrypi thd[376]: Found socket passed from systemd
Nov 27 10:22:00 raspberrypi dhcpcd[375]: dev: loaded udev
Nov 27 10:22:00 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Nov 27 10:22:00 raspberrypi dhcpcd[375]: all: IPv6 kernel autoconf disabled
Nov 27 10:22:00 raspberrypi dhcpcd[375]: forked to background, child pid 382
Nov 27 10:22:00 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Nov 27 10:22:00 raspberrypi systemd[1]: Started Login Service.
Nov 27 10:22:00 raspberrypi systemd-logind[333]: New seat seat0.
Nov 27 10:22:00 raspberrypi dphys-swapfile[329]: Starting dphys-swapfile swapfile setup ...
Nov 27 10:22:00 raspberrypi raspi-config[340]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Nov 27 10:22:00 raspberrypi systemd[1]: Started Raise network interfaces.
Nov 27 10:22:00 raspberrypi systemd[1]: Reached target Network.
Nov 27 10:22:00 raspberrypi systemd[1]: Starting Permit User Sessions...
Nov 27 10:22:00 raspberrypi raspi-config[340]: No. Switching to ondemand scaling governor.
Nov 27 10:22:00 raspberrypi systemd[1]: Started VNC Server in Service Mode daemon.
Nov 27 10:22:00 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Nov 27 10:22:00 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Nov 27 10:22:00 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Nov 27 10:22:00 raspberrypi systemd[1]: Started Permit User Sessions.
Nov 27 10:22:00 raspberrypi systemd[1]: Starting Light Display Manager...
Nov 27 10:22:00 raspberrypi dhcpcd[382]: eth0: waiting for carrier
Nov 27 10:22:00 raspberrypi dhcpcd[382]: eth0: carrier acquired
Nov 27 10:22:00 raspberrypi dhcpcd[382]: all: IPv6 kernel autoconf disabled
Nov 27 10:22:00 raspberrypi kernel: smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Nov 27 10:22:00 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Nov 27 10:22:00 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Nov 27 10:22:00 raspberrypi dhcpcd[382]: DUID 00:01:00:01:21:44:2c:51:b8:27:eb:f0:b7:24
Nov 27 10:22:00 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Nov 27 10:22:00 raspberrypi dhcpcd[382]: eth0: IAID eb:a5:e2:71
Nov 27 10:22:00 raspberrypi dhcpcd[382]: eth0: adding address fe80::45da:cb7:cc42:b8bc
Nov 27 10:22:00 raspberrypi dhcpcd[382]: if_addaddress6: Operation not supported
Nov 27 10:22:00 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 217 (plymouthd).
Nov 27 10:22:00 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Nov 27 10:22:00 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Nov 27 10:22:00 raspberrypi systemd[1]: Started Getty on tty1.
Nov 27 10:22:00 raspberrypi systemd[1]: Reached target Login Prompts.
Nov 27 10:22:00 raspberrypi dphys-swapfile[329]: want /var/swap=100MByte, checking existing: keeping it
Nov 27 10:22:00 raspberrypi dphys-swapfile[329]: done.
Nov 27 10:22:00 raspberrypi kernel: Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k FS
Nov 27 10:22:00 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Nov 27 10:22:01 raspberrypi sshd[414]: Server listening on 0.0.0.0 port 22.
Nov 27 10:22:01 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Nov 27 10:22:01 raspberrypi vncserver-x11[434]: ServerManager: Server started
Nov 27 10:22:01 raspberrypi lightdm[422]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Nov 27 10:22:01 raspberrypi dhcpcd[382]: eth0: rebinding lease of 192.168.1.190
Nov 27 10:22:01 raspberrypi systemd[1]: Started Light Display Manager.
Nov 27 10:22:01 raspberrypi vncserver-x11[434]: ConsoleDisplay: Cannot find a running X server on vt1
Nov 27 10:22:01 raspberrypi vncserver-x11[434]: AgentInitCheck: agent comms failure
Nov 27 10:22:01 raspberrypi vncserver-x11[434]: ConsoleDisplay: Found running X server (pid=447)
Nov 27 10:22:02 raspberrypi kernel: smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
Nov 27 10:22:04 raspberrypi btuart[339]: Can't set line discipline: Invalid argument
Nov 27 10:22:04 raspberrypi btuart[339]: Can't initialize device: Invalid argument
Nov 27 10:22:04 raspberrypi btuart[339]: bcm43xx_init
Nov 27 10:22:04 raspberrypi btuart[339]: Flash firmware /lib/firmware/BCM43430A1.hcd
Nov 27 10:22:04 raspberrypi btuart[339]: Set BDADDR UART: b8:27:eb:0f:48:db
Nov 27 10:22:04 raspberrypi btuart[339]: Set Controller UART speed to 921600 bit/s
Nov 27 10:22:04 raspberrypi systemd[1]: hciuart.service: Control process exited, code=exited status=1
Nov 27 10:22:04 raspberrypi systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
Nov 27 10:22:04 raspberrypi systemd[1]: hciuart.service: Unit entered failed state.
Nov 27 10:22:04 raspberrypi systemd[1]: hciuart.service: Failed with result 'exit-code'.
Nov 27 10:22:04 raspberrypi systemd[1]: Reached target Multi-User System.
Nov 27 10:22:04 raspberrypi systemd[1]: Started BluezALSA proxy.
Nov 27 10:22:04 raspberrypi systemd[1]: Reached target Graphical Interface.
Nov 27 10:22:04 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Nov 27 10:22:04 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Nov 27 10:22:04 raspberrypi systemd[1]: Startup finished in 3.705s (kernel) + 8.749s (userspace) = 12.455s.
Nov 27 10:22:04 raspberrypi bluealsa[465]: /usr/bin/bluealsa: No HCI device available
Nov 27 10:22:04 raspberrypi systemd[1]: bluealsa.service: Main process exited, code=exited, status=1/FAILURE
Nov 27 10:22:04 raspberrypi systemd[1]: bluealsa.service: Unit entered failed state.
Nov 27 10:22:04 raspberrypi systemd[1]: bluealsa.service: Failed with result 'exit-code'.
Nov 27 10:22:05 raspberrypi login[432]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Nov 27 10:22:05 raspberrypi systemd[1]: Created slice User Slice of pi.
Nov 27 10:22:05 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Nov 27 10:22:05 raspberrypi systemd-logind[333]: New session c1 of user pi.
Nov 27 10:22:05 raspberrypi systemd[1]: Started Session c1 of user pi.
Nov 27 10:22:05 raspberrypi systemd[491]: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Nov 27 10:22:05 raspberrypi systemd[491]: Listening on GnuPG cryptographic agent and passphrase cache.
Nov 27 10:22:05 raspberrypi systemd[491]: Reached target Timers.
Nov 27 10:22:05 raspberrypi systemd[491]: Starting D-Bus User Message Bus Socket.
Nov 27 10:22:05 raspberrypi systemd[491]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Nov 27 10:22:05 raspberrypi systemd[491]: Reached target Paths.
Nov 27 10:22:05 raspberrypi systemd[491]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Nov 27 10:22:05 raspberrypi systemd[491]: Listening on GnuPG cryptographic agent (access for web browsers).
Nov 27 10:22:05 raspberrypi systemd[491]: Listening on D-Bus User Message Bus Socket.
Nov 27 10:22:05 raspberrypi systemd[491]: Reached target Sockets.
Nov 27 10:22:05 raspberrypi systemd[491]: Reached target Basic System.
Nov 27 10:22:05 raspberrypi systemd[491]: Reached target Default.
Nov 27 10:22:05 raspberrypi systemd[491]: Startup finished in 198ms.
Nov 27 10:22:05 raspberrypi systemd[1]: Started User Manager for UID 1000.
Nov 27 10:22:05 raspberrypi lightdm[518]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Nov 27 10:22:05 raspberrypi lightdm[518]: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Nov 27 10:22:05 raspberrypi systemd[1]: Started Session c2 of user pi.
Nov 27 10:22:05 raspberrypi systemd-logind[333]: New session c2 of user pi.
Nov 27 10:22:05 raspberrypi lightdm[422]: Error opening audit socket: Protocol not supported
Nov 27 10:22:06 raspberrypi systemd[491]: Started D-Bus User Message Bus.
Nov 27 10:22:06 raspberrypi dbus-daemon[543]: Successfully activated service 'org.freedesktop.systemd1'
Nov 27 10:22:06 raspberrypi dhcpcd[382]: eth0: probing address 192.168.1.190/24
Nov 27 10:22:07 raspberrypi dbus-daemon[543]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Nov 27 10:22:07 raspberrypi systemd[491]: Starting Virtual filesystem service...
Nov 27 10:22:07 raspberrypi dbus-daemon[543]: Successfully activated service 'org.gtk.vfs.Daemon'
Nov 27 10:22:07 raspberrypi systemd[491]: Started Virtual filesystem service.
Nov 27 10:22:07 raspberrypi gvfsd[588]: fuse: device not found, try 'modprobe fuse' first
Nov 27 10:22:08 raspberrypi dbus[341]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Nov 27 10:22:08 raspberrypi systemd[1]: Starting Authorization Manager...
Nov 27 10:22:08 raspberrypi polkitd[619]: started daemon version 0.105 using authority implementation `local' version `0.105'
Nov 27 10:22:08 raspberrypi dbus[341]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Nov 27 10:22:08 raspberrypi systemd[1]: Started Authorization Manager.
Nov 27 10:22:08 raspberrypi polkitd(authority=local)[619]: Registered Authentication Agent for unix-session:c2 (system bus name :1.9 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Nov 27 10:22:09 raspberrypi systemd[491]: Starting Virtual filesystem service - disk device monitor...
Nov 27 10:22:09 raspberrypi dbus[341]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Nov 27 10:22:09 raspberrypi systemd[1]: Starting Disk Manager...
Nov 27 10:22:09 raspberrypi udisksd[656]: udisks daemon version 2.1.8 starting
Nov 27 10:22:09 raspberrypi dbus[341]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Nov 27 10:22:09 raspberrypi udisksd[656]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 27 10:22:09 raspberrypi systemd[1]: Started Disk Manager.
Nov 27 10:22:09 raspberrypi udisksd[656]: Cleaning up mount point /media/pi/BOOT (device 179:1 is not mounted)
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Nov 27 10:22:09 raspberrypi systemd[491]: Started Virtual filesystem service - disk device monitor.
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Nov 27 10:22:09 raspberrypi systemd[491]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Nov 27 10:22:09 raspberrypi systemd[491]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Nov 27 10:22:09 raspberrypi systemd[491]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Nov 27 10:22:09 raspberrypi systemd[491]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Nov 27 10:22:09 raspberrypi systemd[491]: Starting Virtual filesystem service - digital camera monitor...
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Nov 27 10:22:09 raspberrypi systemd[491]: Started Virtual filesystem service - digital camera monitor.
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Nov 27 10:22:09 raspberrypi systemd[491]: Starting Virtual filesystem service - Apple File Conduit monitor...
Nov 27 10:22:09 raspberrypi gvfs-afc-volume-monitor[680]: Volume monitor alive
Nov 27 10:22:09 raspberrypi dbus-daemon[543]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Nov 27 10:22:09 raspberrypi systemd[491]: Started Virtual filesystem service - Apple File Conduit monitor.
Nov 27 10:22:10 raspberrypi kernel: FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Nov 27 10:22:10 raspberrypi udisksd[656]: Mounted /dev/mmcblk0p1 at /media/pi/BOOT on behalf of uid 1000
Nov 27 10:22:11 raspberrypi dhcpcd[382]: eth0: leased 192.168.1.190 for infinity
Nov 27 10:22:11 raspberrypi dhcpcd[382]: eth0: adding route to 192.168.1.0/24
Nov 27 10:22:11 raspberrypi dhcpcd[382]: eth0: adding default route via 192.168.1.1
Nov 27 10:22:11 raspberrypi avahi-daemon[336]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.190.
Nov 27 10:22:11 raspberrypi avahi-daemon[336]: New relevant interface eth0.IPv4 for mDNS.
Nov 27 10:22:11 raspberrypi avahi-daemon[336]: Registering new address record for 192.168.1.190 on eth0.IPv4.
Nov 27 10:22:22 raspberrypi vncserver-x11[434]: Connections: connected: 192.168.1.102::50186
Nov 27 10:22:23 raspberrypi vncserver-x11[434]: session started: user pi permissions f
Nov 27 10:22:23 raspberrypi vncserver-x11[434]: Connections: authenticated: 192.168.1.102::50186, as pi (f permissions)
Nov 27 10:22:23 raspberrypi vncserver-x11[434]: SPrintConnMgr: Failed to add printer: server-error-service-unavailable
Nov 27 10:22:42 raspberrypi systemd[491]: Time has been changed
Nov 27 10:22:42 raspberrypi systemd-timesyncd[299]: Synchronized to time server 210.245.100.39:123 (2.debian.pool.ntp.org).
Nov 27 10:22:42 raspberrypi systemd[1]: Time has been changed
Nov 27 10:22:42 raspberrypi systemd[1]: apt-daily.timer: Adding 11h 50min 42.880878s random time.
Nov 27 10:22:42 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 8min 29.990988s random time.
Nov 27 10:23:25 raspberrypi sudo[786]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl
Nov 27 10:23:25 raspberrypi sudo[786]: pam_unix(sudo:session): session opened for user root by (uid=0)
