LeeMcL
Raspbian change may increase wear on SD
Wed Nov 29, 2017 11:09 am
I think as part of a patch in September 2016 the default value for vm.swappiness was changed from 1 (almost always avoid using swap) to 60 (OK to use swap) which means its possible that your Pi will now use swap space a lot more often. If you are using the default 100M swap on your SD and are pushing your Pi hard you should probably reset this back to 1 to avoid undue wear on your SD.
You can easily check swappiness with:
sysctl vm.swappiness
And check if swap is being used with:
free -h
or with:
vmstat 10
Note that I found this issue while tracking down some odd MMC errors being reported by the kernel on a few Pi running Chromium continuously showing a series of slides:
Workqueue: events_freezable mmc_rescan
and
Workqueue: kmmcd mmc_rescan
I'd ruled out problems with the Pis, power supplies, and SD cards... and found the swappiness change while searching possible causes of high disk usage. I'm still not sure changing swappiness back to 1 will help with this particular issue - time will tell.
(Nov 30 2017 - changed Subject)
chuck07
Re: Raspbian change may increase wear on SD
Thu Jan 11, 2018 3:52 pm
I also noticed that swap was being utilized even though there was plenty of free ram on my Pi. This is how I changed the swappiness:
pi@pi:~$sudo nano /etc/sysctl.conf
A swappiness value wasn't defined in there, so I added the following lines to the end of sysctl.conf:
# Changed swappiness from a default of 60 to 10 to decrease swap usage
vm.swappiness = 10
Save the file, then reboot or turn swap off and back on.
More information in the answer here: https://askubuntu.com/questions/103915/ ... swappiness
