ALM865
Issues with Script
Sat Dec 09, 2017 9:46 am
Hi All,
I have a service that I've created that worked fine on wheezy but I've just updated to the lastest RPi image and it no longer works.
My script is "/etc/init.d/vncboot" and looks like this:
### BEGIN INIT INFO
# Provides: vncboot
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start VNC Server at boot time
# Description: Start VNC Server at boot time.
### END INIT INFO
#! /bin/sh
# /etc/init.d/vncboot
USER=root
HOME=/root
export USER HOME
case "$1" in
 start)
   echo "Starting VNC Server"
   #Insert your favoured settings for a VNC session
   #/usr/bin/vncserver :1 -geometry 1280x800 -depth 16 -pixelformat rgb565
   /usr/bin/vncserver :1 -geometry 1920x1080 -depth 24
 stop)
   echo "Stopping VNC Server"
   /usr/bin/vncserver -kill :1
   echo "Usage: /etc/init.d/vncboot {start|stop}"
   exit 1
esac
exit 0
Then as root I run "chmod 755 /etc/init.d/vncboot", "chmod +x /etc/init.d/vncboot" and "update-rc.d vncboot defaults"
I have no idea what's wrong, if I run the script as is it works flawlessly. If I run it using 'service vncboot start' it fails. See below:
root@rpi:/home/pi# service vncboot start
Job for vncboot.service failed because the control process exited with error code.
See "systemctl status vncboot.service" and "journalctl -xe" for details.
root@rpi:/home/pi# systemctl status vncboot.service
● vncboot.service - LSB: Start VNC Server at boot time
   Loaded: loaded (/etc/init.d/vncboot; generated; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2017-12-09 20:39:47 AEDT; 11s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 1152 ExecStart=/etc/init.d/vncboot start (code=exited, status=203/EXEC)
Dec 09 20:39:47 rpi systemd[1]: Starting LSB: Start VNC Server at boot time...
Dec 09 20:39:47 rpi systemd[1]: vncboot.service: Control process exited, code=exited status=203
Dec 09 20:39:47 rpi systemd[1]: Failed to start LSB: Start VNC Server at boot time.
Dec 09 20:39:47 rpi systemd[1]: vncboot.service: Unit entered failed state.
Dec 09 20:39:47 rpi systemd[1]: vncboot.service: Failed with result 'exit-code'.
root@rpi:/home/pi# /etc/init.d/vncboot start
Starting VNC Server
New 'X' desktop is rpi:1
Starting applications specified in /root/.vnc/xstartup
Log file is /root/.vnc/rpi:1.log
Does anyone know what's going on here?
ALM865
Re: Issues with Script
Sat Dec 09, 2017 11:31 am
So added ". /lib/lsb/init-functions" and moved "#! /bin/sh" to the start and it now works.
Pretty annoying that it worked fine on wheezy though.
NotRequired
Sat Dec 09, 2017 12:29 pm
On Wheezy the SysV style init scripts was how services was started but since Jessie this has been taken over by SystemD. Even though init scripts work fine on >= Jessie, you should (if possible) create a systemd service instead. The "shebang" line (#! ...) must be the first line in a shell script in order to work properly :)
Glowing in the dark!
Heater
Sat Dec 09, 2017 6:16 pm
The modern way to get things started is to use systemd. It's pretty simple.
Create a systemd service file, "vnc.service", like so:
    [Unit]
    Description= VNC Server
    After=network.target
    [Service]
    ExecStart=/usr/bin/vncserver :1 -geometry 1920x1080 -depth 24
    WorkingDirectory=/root
    StandardOutput=syslog
    StandardError=syslog
    SyslogIdentifier=vncserver
    User=root
    Group=root
    Restart=always
    [Install]
    WantedBy=multi-user.target
Put it in the right place with right permissions
    $ sudo cp vnc.service /etc/systemd/system
Now you can start the service like so:
    $ sudo systemctl start vnc
Stop it like so:
    $ sudo systemctl stop vnc
Enable it to run at boot time:
    $ sudo systemctl enable vnc
Disable it from running at boot time:
    $ sudo systemctl disable vnc
Lot's of people complain about systemd for whatever reasons but I have been using it on Pi, PC and cloud servers for ages and it has worked very well. I find it easier than messing with a bunch of init scripts.
No need for any "shebang" line :)
Slava Ukrayini.
ALM865
Sun Dec 10, 2017 1:56 am
Thanks for the replies.
@NotRequired, I'm not sure why the script has been fine with the shebang line after the init info all this time. I've used the init script fine for many years until yesterday when my SD got shagged and I had to do a complete rebuild of my Pi setup. I'm guessing it was always documented that way and never enforced until recently?
The Pi box isn't doing much these days, it just sits there until I have something big I want to download or download something off a slow server so I don't have to leave my laptop on. It sits there idling 99.9% of the time.
@Heater, yeah I did see the new way using systemd when I was googling but I wasn't 100% sure how to "convert" my init.d script. Thanks for the example, I'll give it a go at some point out of interest. It does look a fair bit easier than an init.d script.
Heater
Sun Dec 10, 2017 7:59 am
If you have a bash script without the shebabg line (hash bang bin bash) you can run it as a bash script using the bash command:
$ bash myscript
If you have the hash bang bin bash then you can run it:
$ ./myscript
In the latter case the hash bang bin bash line tells your shell which interpreter to use to run the script (There are many command line shells in Unix/Linux)
I'm guessing this is the difference between running your script from the old and new init schemes.
Slava Ukrayini.
NotRequired
Sun Dec 10, 2017 9:45 am
This is pure speculation: Linux can detect content type / mime type of most files by examining a part of the files content. If your file with the ill placed shebang is detected as a shell script, it may function properly as a such with older versions of Linux or even from a command line in newer versions. SystemD may disregard the mime-type and purely rely on the shebang because this is faster than analyzing file content and this difference may be the cause of your "problem" (in fact you script has always been malformed so it was just dumb luck it worked).
I hope you get your Pi up & running as you want to! :)
Heater
Sun Dec 10, 2017 10:25 am
That's right.
The "file" command does a very good job of identifying file types.
$ file certs/ca.crt
certs/ca.crt: PEM certificate
Even without the extension:
$ file ca
ca: PEM certificate
But it needs the #!/bin/sh to identify shell scripts.
$ cat junk1
echo Hello
$ file1 junk
junk: ASCII text
$ cat junk2
#!/bin/bash
echo Hello
$ file junk2
junk: Bourne-Again shell script, ASCII text executable
Slava Ukrayini.
