carriba
Raspbian systemd-timesyncd saving system time instead of using fake-hwclock
Wed Dec 20, 2017 1:38 pm
In my last article viewtopic.php?t=178763 I've shown how the NTP daemon can be replaced with the "systemd-timesyncd" service to synchronise the OS system time with an Internet clock source.
Here, I will show how the "fake-hwclock" service can be easly replaced with the "systemd-timesyncd" service in reading the last saved clock upon an OS reboot:
The "systemd-timesyncd" service keeps track of the system time and updates the file "/var/lib/systemd/clock" with the last time stamp. See also https://unix.stackexchange.com/question ... tp-syncing for more info.
The last updated time stamp of the file "/var/lib/systemd/clock" will be used when starting up the OS, and sets the system time accordingly. Thus, no need to have the "fake-hwclock" running in parallel and periodically store the OS running system time again.
The "fake-hwclock" package can be deinstalled as follows:
sudo systemctl stop fake-hwclock
sudo apt-get -y remove fake-hwclock
sudo apt-get -y purge fake-hwclock
More details about the deinstallation of the fake-hwclock service can be read under https://www.howtoinstall.co/en/debian/s ... ion=remove.
Next, we will upate the respective configuration file for the "systemd-timesyncd" service with the following commands:
sudo cp /etc/systemd/timesyncd.conf /etc/systemd/timesyncd.bak
sudo sed -i '/^\[Time/,+2d' /etc/systemd/timesyncd.conf
Then, for Raspbian Stretch confirm the NTP sources with the following command:
sudo sh -c 'cat >> /etc/systemd/timesyncd.conf' << EOF
[Time]
NTP=0.pool.ntp.org 1.pool.ntp.org 2.pool.ntp.org 3.pool.ntp.org
FallbackNTP=0.pool.ntp.org 1.pool.ntp.org 2.pool.ntp.org 3.pool.ntp.org
EOF
Or, for Raspbian Jessie confirm the NTP sources with the following command:
[Time]
Servers=0.pool.ntp.org 1.pool.ntp.org 2.pool.ntp.org 3.pool.ntp.org
EOF
Reinitialise and activate the time services with the following commands:
sudo systemctl restart systemd-timesyncd
sudo systemctl daemon-reload
Once the "systemd" dameon has been reloaded, the status of the system time and its syncronisation with an NTP source can be queried by firing the command:
timedatectl
Optionally, you may add the following commands in the "/etc/rc.local" file to ensure that the "systemd-timesyncd" service synchonises with an NTP source during bootup and creates the /var/lib/systemd/clock file, if non-existant:
sudo sed -i '/^exit 0/d' /etc/rc.local
sudo sh -c 'cat >> /etc/rc.local' << EOF
[ ! -e /var/lib/systemd/clock -a "\`systemctl is-active systemd-timesyncd | grep -i active\`" ] && timedatectl set-ntp 1 > /dev/null 2>&1
sleep 2
EOF
Hope this helps! And maybe with the next update of the Raspbian image, the "fake-hwclock" package can be excluded ;-)
n67
Re: Raspbian systemd-timesyncd saving system time instead of using fake-hwclock
Wed Dec 20, 2017 1:44 pm
Hope this helps!
Just out of curiosity, how would it help? What change/improvement would the user see having done this procedure?
I.e., what would be the motivation for doing this?
(I'm not saying there isn't. I'm saying it would be more complete if there was a "And this is how you benefit!" section at the end of your post.)
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
ShiftPlusOne
Wed Dec 20, 2017 1:55 pm
Oh, interesting. By the sounds of it, we can just remove fake-hwclock altogether, since we're already using systemd-timesyncd in stretch.
carriba
Wed Dec 20, 2017 2:15 pm
Hope this helps!
With "Hope this helps!", I mean the instructions provided ;-)
This said, regarding the technical benefits you may get with this setup, simply refer to the article https://help.ubuntu.com/lts/serverguide/NTP.html, and there may be other related articles available regarding "ntp vs timesyncd".
Hope this (reference provided) helps!
n67
Wed Dec 20, 2017 3:05 pm
It doesn't. I tend not to follow random URLs.
Can you say a bit here about the benefits?
Note: This is not just for me - but for anyone else who happens to read this thread and may be asking themselves (as I am) "Why bother???"
Epmu Sn!
Wed Dec 20, 2017 3:13 pm
Just follow the link and save our bandwidth.
n67
Wed Dec 20, 2017 3:28 pm
OK, I just won't bother with this.
No worries.
Epmu Sn!
carriba
Mon Apr 23, 2018 8:28 am
Since on many deployments of a Raspberry Pi device, I have re-applied on new SD cards flashed Raspbian Stretch the same steps as described with the original post "Raspbian systemd-timesyncd saving system time instead of using fake-hwclock", and am wondering what could be the use (or even benefit) of still using fake-hwclock alongside with systemd-timesyncd?
Upon a reboot, the systemd-timesyncd daemon takes care of restoring the OS system time...
ShiftPlusOne
Mon Apr 23, 2018 8:40 am
Probably none
fred44nl
Mon Apr 23, 2018 8:45 am
Oh, interesting. By the sounds of it, we can just remove fake-hwclock altogether, since we're already using in stretch.
I have updated Jessie to Stretch and I have a file "/lib/systemd/systemd-timesyncd", but fake-hwclock is still running.
headless RPi 3B running from usbhdd.
alberg
Wed Nov 21, 2018 5:20 am
Many thanks for the detailed and useful article!
I have just one little qustion. In 239 systemd there are parameters PollIntervalMinSec and PollIntervalMaxSec to regulate the frequency of synchronizations. Is there any way to set sync interval in the Stretch's 232 systemd?
/Al
alberg
Fri Nov 23, 2018 7:19 am
I just set up a timer which runs systemd-timesyncd once a day. I think it would be worthile to mention in the article that systemd-timesyncd in 232 systemd will be writing to their storage every 5 minutes or so. (The strangeness of such choice seems to be the cause of subsequential adding the possibility for systemd users to change the frequency of syncs.)
kolsi
Sat Feb 22, 2020 9:08 am
While optimizing boot process for our device with Raspberry Pi4 (+Buster), I came across this older topic.
I like the idea of removing all unneeded services, especially when their task is already doubled by another existing service.
I'm not sure if I haven't forgotten something, but although systemd-timesyncd restores last known system time on boot, the simply removing fake-hwclock service is not correct. The problem is that systemd-timesyncd executes too late in boot process and thus systemd-fsck-root.service will complain about wrong time and will perform complete file system check on every boot.
The solution would be modifying systemd-timesyncd.service to execute earlier before systemd-fsck-root.service but I'm not sure about the correct steps. Simple adding "Before=systemd-fsck-root.service" completely messes up the boot process.
ShiftPlusOne
Sat Feb 22, 2020 11:28 am
Since we don't use initramfs, systemd just doesn't work properly in this regard. They said it would be too tricky to fix.
kolsi
Sat Feb 22, 2020 4:46 pm
So we should rather stay with fake-hwclock for saving/loading last system time on boot before systemd-fsck-root.service and use systemd-timesyncd.service for network time synchronization only?
Then it could be better to change systemd-timesyncd.service dependencies to load after network-online.target only to save some time during the boot.
[Unit]
DefaultDependencies=no
#After=systemd-remount-fs.service systemd-sysusers.service
#Before=time-sync.target sysinit.target shutdown.target
After=network-online.target
Before=shutdown.target
Conflicts=shutdown.target
#Wants=time-sync.target
[Install]
#WantedBy=sysinit.target
WantedBy=multi-user.target
Yosef
Sun Oct 25, 2020 8:18 am
IMO fake-hwclock cannot be replaced by systemd-timesyncd in an embedded system whithout internet connection.
Without internet connection, /var/lib/systemd/timesync/clock, the timestamp of the last successful synchronization,
would never be updated.
See manpages of fake-hwclock and systemd-timesyncd.
ShiftPlusOne
Mon Dec 07, 2020 11:35 am
That mechanism of systemd-timesyncd is broken on systems without initramfs
dickon
Mon Dec 07, 2020 12:53 pm
You can stop there.
