paolojo
RTOS on raspberry pi3
Thu Jan 04, 2018 3:33 pm
hi everybody and happy new year!!!
2018 starts with a great question: does exist a real time OS for raspberry pi3?
My aim is to develop an agricultural application able to read some sensor outputs and able to drive some motors/valves in the tractors.
Could you give me some suggestions?
Thanks in advance
Paolo
Re: RTOS on raspberry pi3
Thu Jan 04, 2018 3:40 pm
Thanks in advance
Paolo
viewtopic.php?f=56&t=201447
joan
Thu Jan 04, 2018 3:43 pm
Are you sure you need a RTOS?
A RTOS is not needed to read most sensors or drive most motors. Do you have a particular problem sensor or problem motor in mind?
topguy
FreeRTOS was ported some years ago: viewtopic.php?t=22423
But I dont know the current status of it.
How "hard" are your RT requirements really ? Are you sure they would not be fulfilled by standard Linux ?
paolojo
Thu Jan 04, 2018 4:49 pm
Thanks for your replays.
My need is very easy: have a routine which reads the sensor output every 1ms or 5ms depend on the sensor without lags/delays.
Do you think raspbian is good for this type of need?
mattmiller
Thu Jan 04, 2018 5:44 pm
Probably better sticking to using an Arduino type device for that sort of RT application
joan
Thu Jan 04, 2018 5:52 pm
What sensors are you talking about. Why do they need reading at such precise intervals?
paolojo
Thu Jan 04, 2018 9:22 pm
At the moment i don't know exactly which sensor..but in general i have the need to work without lags
mattmiller
Thu Jan 04, 2018 10:30 pm
Stick with Arduino just to be safe then
paolojo
Thu Jan 04, 2018 10:55 pm
Why Arduino?
mahjongg
Thu Jan 04, 2018 10:59 pm
Why Arduino?
arduino doesn't run a multi-tasking multi-user operating system, so doesn't have task switching pauses where it doesn't run your code.
murtaza
Thu Oct 04, 2018 5:56 pm
For sophisticated real time application, you can use ROS(robot operating system). It is a framework works stably over UBUNTU.
softweyr
Sun Dec 23, 2018 12:02 am
There was not a lot o real information shed in this thread, so I'll try to add some.
Some of the architectural decisions that went into the Rapsberry Pi family, that helped keep the functionality high and the price low, make it somewhat less than idea for a simple real-time OS. As an example, consider the ethernet interface out there in USB land. This requires a fairly sophisticated USB stack (which Linux of course has) to be apple to support an ethernet driver (already a fairly sophisticated driver) on top of it. A lot of small, free-ish RTOSes don't have sophisticated USB stacks, if any, so if you want to port your RTOS to the Pi, you have to become a USB expert too.
I would dare say if you can't find an existing, well-support port of whatever RTOS you are looking at already on whichever Raspberry Pi you want, doing so is going to be way beyond a hobby or even a junior professional programmer task. Someone suggested Arduino, which is completely orthogonal to the question at hand. If you think your task would be best accomplished using FreeRTOS or RTEMS, to name a couple, your search should start with boards that are known to work well with FreeRTOS or RTEMS and meet your goals.
If you don't know, and are just poking around trying to figure things out, you may want to look at the Arduino world. There are Arduinon (ish) that have, for instance, Ethernet, WiFi, or Bluetooth interfaces, and at least parts of a TCP/IP stack. The Adafruit Feather M0 Wifi, for instance.
Best of luck, if OP ever happens to come back here. :)
kosrodman
Thu Feb 07, 2019 12:32 am
Hello forum. I have a similar problem. I use raspberry pi with MCC118 HAT on it to read sensors. In particular I am trying to read laser emitted binary code(light ON on 1 and OFF on 0) with known frequency. It starts well, as i am able to read exactly what I send to it from separate mcu, but then it drifts and "skips" one number and basically all prints shifted, and then more and more drift. And frequency is very little like 10Hz :oops: it reads signal from sensor and prints 1 or 0 on display in 32 number long lines.
MCC118 has its own crystal and so It should be reading it with good timing, yet it doesn't. I think it is my code inefficiency or it is a pi messing it up.
Also i tried to clock MCC118 with from other MCU(TIVA launchpad) and i am able to push up to 200 hz signal with code and everything remaining same. What baffles me is that TIVA has exactly the same crystal but on TIVA i use interrupt and it does much better job timing it.
I am a nubbie so any advice will help.
How would you suggest me to tackle this issue? I need it to be on a microcomputer and for it to be precise like mcu.
#include "../../daqhats_utils.h"
#include <stdio.h>
#include <wiringPi.h>
int main(void)
    int result = RESULT_SUCCESS;
    uint8_t address = 0;
    char c;
    char display_header[512];
    int i;
    char channel_string[512];
    char options_str[512];
    // Set the channel mask which is used by the library function
    // mcc118_a_in_scan_start to specify the channels to acquire.
    // The functions below, will parse the channel mask into a
    // character string for display purposes.
    uint8_t channel_mask = {/*CHAN0 | CHAN1 | CHAN2 |*/ CHAN3};
    convert_chan_mask_to_string(channel_mask, channel_string);
    uint32_t samples_per_channel = 1000000;
    int max_channel_array_length = mcc118_info()->NUM_AI_CHANNELS;
    int channel_array[max_channel_array_length];
    uint8_t num_channels = convert_chan_mask_to_array(channel_mask,
        channel_array);
    uint32_t internal_buffer_size_samples = 0;
    uint32_t user_buffer_size = 1000 * num_channels;
    double read_buf[user_buffer_size];
    int total_samples_read = 0;
    int32_t read_request_size = READ_ALL_AVAILABLE;
    // When doing a continuous scan, the timeout value will be ignored in the
    // call to mcc118_a_in_scan_read because we will be requesting that all
    // available samples (up to the default buffer size) be returned.
    double timeout = 5;
    double scan_rate = 10.0;
    double actual_scan_rate = 0.0;
    mcc118_a_in_scan_actual_rate(num_channels, scan_rate, &actual_scan_rate);
    uint32_t options = OPTS_CONTINUOUS | OPTS_EXTTRIGGER | OPTS_EXTCLOCK;
    uint16_t read_status = 0;
    uint32_t samples_read_per_channel = 0;
    // Select an MCC118 HAT device to use.
    if (select_hat_device(HAT_ID_MCC_118, &address))
        // Error getting device.
        return -1;
    printf ("\nSelected MCC 118 device at address %d\n", address);
    // Open a connection to the device.
    result = mcc118_open(address);
    STOP_ON_ERROR(result);
    convert_options_to_string(options, options_str);
    convert_chan_mask_to_string(channel_mask, channel_string) ;
    printf("\nMCC 118 continuous scan example\n");
    printf("    Functions demonstrated:\n");
    printf("        mcc118_a_in_scan_start\n");
    printf("        mcc118_a_in_scan_read\n");
    printf("        mcc118_a_in_scan_stop\n");
    printf("    Channels: %s\n", channel_string);
    printf("    Requested scan rate: %-10.2f\n", scan_rate);
    printf("    Actual scan rate: %-10.2f\n", actual_scan_rate);
    printf("    Options: %s\n", options_str);
    printf("\nPress ENTER to continue ...\n");
    scanf("%c", &c);
    // Configure and start the scan.
    // Since the continuous option is being used, the samples_per_channel
    // parameter is ignored if the value is less than the default internal
    // buffer size (10000 * num_channels in this case). If a larger internal
    // buffer size is desired, set the value of this parameter accordingly.
    result = mcc118_a_in_scan_start(address, channel_mask, samples_per_channel,
        scan_rate, options);
    STOP_ON_ERROR(mcc118_a_in_scan_buffer_size(address,
        &internal_buffer_size_samples));
    printf("Internal data buffer size:  %d\n", internal_buffer_size_samples);
    printf("\nStarting scan ... Press ENTER to stop\n\n");
	printf("\nPress Trigger\n");
    // Create the header containing the column names.
    strcpy(display_header, "Samples Read    Scan Count    ");
    for (i = 0; i < num_channels; i++)
        sprintf(channel_string, "Channel %d   ", channel_array[i]);
        strcat(display_header, channel_string);
    strcat(display_header, "\n");
    printf("%s", display_header);
 int j=0,p=0,l=0,sum=0,code_array[1000];
    // Continuously update the display value until enter key is pressed
    do
        // Since the read_request_size is set to -1 (READ_ALL_AVAILABLE), this
        // function returns immediately with whatever samples are available (up
        // to user_buffer_size) and the timeout parameter is ignored.
        result = mcc118_a_in_scan_read(address, &read_status, read_request_size,
            timeout, read_buf, user_buffer_size, &samples_read_per_channel);
        if (read_status & STATUS_HW_OVERRUN)
            printf("\n\nHardware overrun\n");
            break;
        else if (read_status & STATUS_BUFFER_OVERRUN)
            printf("\n\nBuffer overrun\n");
            break;
        total_samples_read += samples_read_per_channel;
        // Display the last sample for each channel.
    //    printf("\r%12.0d    %10.0d ", samples_read_per_channel,
    //        total_samples_read);
  //   printf("%d",samples_read_per_channel);
        if (samples_read_per_channel > 0)
            int index = samples_read_per_channel * num_channels - num_channels;
// printf("Check");
            //    printf("%10.5f V", read_buf[index + i]);
               if((read_buf[index+i]*100)<1)
	{l=1;
	else{l=0;}
	sum=sum+l;
	// delay(100);
	if(sum>4){
	if (sum==5)
	{sum++;
	break;}
	{l=1;
	else{l=0;}
	   // delay(120);
	code_array[j]=l;
	printf("%d",code_array[j]);
	j++;
	if(j==32)
	{p++;
	printf("\n");
	j=0;
   if ((j==0) && (p==4))
   {printf("\n");
	   p=0;}
          //  fflush(stdout);
       // usleep(500000);
    while ((result == RESULT_SUCCESS) &&
           ((read_status & STATUS_RUNNING) == STATUS_RUNNING) &&
           !enter_press());
    printf("\n");
stop:
    print_error(mcc118_a_in_scan_stop(address));
    print_error(mcc118_a_in_scan_cleanup(address));
    print_error(mcc118_close(address));
    return 0;
timrowledge
Thu Feb 07, 2019 4:48 am
I’d consider using an ESP8266 to actually do your time-sensitive readings and them connect it to a Pi.
The nice thing about the esp is you can program it with the Arduino IDE (amongst other things) and it has WiFi built in. Treat it as a much faster Arduino. They’re very cheap too - $5 will get you one delivered to your door.
Connect to the Pi via mqtt, for example.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
rompelstilchen
Wed Jun 24, 2020 7:39 pm
Why Arduino?
if you just need sensors reading, why raspberry pi ?
rompelstilchen
Wed Jun 24, 2020 7:40 pm
nothing to do with real time
topguy
Thu Jun 25, 2020 12:01 am
Why answer a 16 months old thread...
Return to “Raspberry Pi OS”
