PiN00B1611
[SOLVED} Pi zero analog video output
Thu Jan 18, 2018 8:15 pm
Is it possible to convert the video output of the pi zero w like this :
Mini hdmi -> hdmi
Hdmi -> vga
Vga -> rca
Or
Mini hdmi -> hdmi
Hdmi -> vga and RCA
Using this cable: http://www.dx.com/p/hdmi-to-vga-3-rca-c ... mEADyu0vYU
Thanks in advanced.
Re: Pi zero video output
Thu Jan 18, 2018 9:24 pm
How about bare wires connected to the TV pin holes on the Zero -> RCA
That cable is unlikely to work. The TV connections already provide composite video output which should be compatible with RCA video inputs.
mahjongg
Fri Jan 19, 2018 11:39 am
Mini hdmi -> hdmi
Hdmi -> vga
Vga -> rca
Or
Mini hdmi -> hdmi
Hdmi -> vga and RCA
Thanks in advanced.
No!
No mere cable can convert HDMI to composite video.
Besides, the PI Zero already produces composite video.
PiN00B1611
Tue Feb 06, 2018 7:34 pm
Mini hdmi -> hdmi
Hdmi -> vga
Vga -> rca
Or
Mini hdmi -> hdmi
Hdmi -> vga and RCA
Thanks in advanced.
No!
Hi, thanks for your response. what is the easiest way to get RCA out on the zero? (i want analog audio too)
PiN00B1611
Tue Feb 06, 2018 7:35 pm
mattmiller wrote:
Thu Jan 18, 2018 10:00 pm
A fuller explanation is here https://www.modmypi.com/blog/how-to-add ... ry-pi-zero
i 've seen that already but i want analog audio too
Tue Feb 06, 2018 7:38 pm
Analogue audio will require additional circuitry. Either the equivalent to the PWM driven analogue audio circuit on the other models, a USB audio adaptor or an I2S interface device.
W. H. Heydt
Tue Feb 06, 2018 7:43 pm
Or, alternatively, use a Pi Model A+ rather than a Pi0. The A+ has a 4-pole 1/8" jack that provides composite video and stereo audio output. All you need is a simple, readily available, cable.
PiN00B1611
Tue Feb 06, 2018 7:50 pm
Another pi is not an option since i want to make something like this https://www.youtube.com/watch?v=j5dXx0NhLxg but than RCA instead of HDMI but if it needs all those extra modules it wont fit anyway so... do you have any suggestions how it would still be possible? otherwise I will just give it up .
Tue Feb 06, 2018 7:55 pm
https://learn.adafruit.com/introducing- ... y-pi-zero/
PiN00B1611
Tue Feb 06, 2018 7:58 pm
i ve already seen that too, i just hooped there was an more compact way. so i can fit it in to a nintendo controller like here https://www.youtube.com/watch?v=j5dXx0NhLxg
PiN00B1611
Wed Feb 07, 2018 3:15 pm
Thank you for your responses i will shut this thread down
edit: is there even a way to set this topic as solved?
W. H. Heydt
Wed Feb 07, 2018 3:23 pm
As the OP you can change the title to add "[SOLVED]" as you've seen in other threads. Only the moderators can lock/move/delete threads.
PiGraham
Wed Feb 07, 2018 3:32 pm
You should be able to pack the few components needed for the Pwm audio into that controller.
ere's another take on the circuit:
https://sudomod.com/forum/viewtopic.php?t=480
You don't have to put all the components on a flat board and some could mount directly on the Pi0.
