serekzolty
No wireless interfaces found
Wed Jan 24, 2018 5:26 pm
Hi guys
I just installed the newest rasbian on my PI 3 and I'm facing some issues with WLAN. The WLAN itself works and connects to my home network, but the icon on the systembar is two red X's and I can't see my signal, nor scan for other networks.
Here's my /etc/network/interfaces file
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
iface default inet dhcp
And here's my wpa_suplicant.conf file
country=GB
update_config=1
network={
        ssid="xxxxxxxx	"
        psk="xxxxxxxxxx"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        auth_alg=OPEN
Like I said..i got internet/wlan connection it's just this icon on the bar that seems to be broken. As soon as I get my mouse over it a balloon tip appears "Connection to dhcpcd lost" and when I actually click on it it says "No Wireless interfaces found"
Any ideas on that ?
MrEngman
Re: No wireless interfaces found
Wed Jan 24, 2018 5:48 pm
With the latest versions of Raspbian, Raspbian Stretch, you should not edit file /etc/network/interfaces to configure your wifi. You only need to set up the wifi using /etc/wpa_supplicant/wpa_supplicant.conf.
The problem with the wifi icon is probably down to that.
Put file /etc/network/interfaces back to its default state.
# Include files from /etc/network/interfaces.d:
and reboot. You should get a wifi connection and maybe your wifi icon will now work as expected.
serekzolty
Wed Jan 24, 2018 5:53 pm
It works now ! :)
Thank you very much, the case is closed.
MrEngman
Wed Jan 24, 2018 6:40 pm
It works now ! :)
Good to hear your problem is now sorted.
Wasn't sure my suggestion would work but nice to find out it fixed your problem.
pandakoon
Mon May 18, 2020 4:00 pm
Hi, I have the same exact problem. I open the /etc/network/interfaces file and it says
# This file is auto-generated by openmediavault (https://www.openmediavault.org)
# WARNING: Do not edit this file, your changes will get lost.
# Better use netplan.io or systemd-networkd to configure additional interface stanzas.
Of course I use the Pi4 as a NAS, and I installed OMV and set an static IP. Should I edit the file? THere is also another file calle "interfaces.bak"
I don`t know if I should edit the file, I can´t even edit it with Mousepad.
I´m a noob, thanks for your understanding and patience.
