tjohnson
GUIDE: Google Assistant on Raspbian
Thu Feb 08, 2018 12:10 pm
I know there are already a number of guides online for this, but after setting it up myself and needing to search for information across multiple sites, I thought it would be helpful to have a consolidated guide. Here it is.
To set up Google Assistant on Raspbian, the only things you need are a Pi 2 or 3, a speaker, and a microphone. You can optionally wire an LED to GPIO pin 25 to add a visual status indicator.
NOTE: As of 2018-08-03, these instructions no longer work because Google has changed the installation process for the Assistant SDK. I have created a GitHub repo with new instructions, please try them instead: https://github.com/t1m0thyj/AssistantPi
  1. Follow these steps to add a Google Assistant device to your Google account:
    https://developers.google.com/assistant ... nd-account
    Step 4 is confusing and can be ignored (step 2 below replaces it).
  2. The JSON file that you downloaded needs to be copied to your Pi. Copy it to the /home/pi directory and rename it to assistant.json.
  3. Open a terminal on the Pi and run these commands:
    git clone https://github.com/google/aiyprojects-raspbian.git ~/AIY-projects-python
    cd ~/AIY-projects-python
    wget https://raw.githubusercontent.com/google/aiyprojects-raspbian/voicekit/scripts/install-deps.sh -nc -P scripts
    chmod +x scripts/install-deps.sh
    sudo scripts/install-services.sh
    echo "$HOME/AIY-projects-python/src" > $HOME/AIY-projects-python/env/lib/python3.5/site-packages/aiy.pth
    ln -s examples/voice/assistant_library_with_local_commands_demo.py src/main.py
    sudo systemctl enable voice-recognizer.service
    The last two commands set up the voice recognizer service, which runs Assistant when the Pi boots.
  4. If you are using a USB microphone, some audio settings on the Pi must be changed for it to work with Assistant. Follow steps 2 and 3 here to fix it:
    https://developers.google.com/assistant ... ware/audio
    The (card number, device number) values that you want will likely be 1,0 for the mic and 0,0 for the speaker.
  5. Open a terminal window and run these commands:
    source env/bin/activate
    python3 src/main.py
    If there is a web link in the terminal, click it to grant the necessary permissions to your Google account.
  6. You should now be able to say "OK Google" and have a conversation with your Pi. Try rebooting your Pi (saying "OK Google reboot" should do this), and test that Assistant still works after booting without having to start it manually.
  7. If you want to code custom actions for Google Assistant, they can easily be added in the Python script src/main.py. Details about how to do this can be found in Google's Maker's Guide for this project: https://aiyprojects.withgoogle.com/voice#makers-guide
Resources How to Update
To update the Assistant API on Raspbian to a newer version, run these commands:
git checkout aiyprojects
git pull origin aiyprojects
rm -rf ~/AIY-projects-python/env
sudo systemctl restart voice-recognizer.service
Neavvy
Re: GUIDE: Google Assistant on Raspbian
Wed Feb 21, 2018 3:02 pm
https://drive.google.com/file/d/1tyTla5 ... sp=sharing
I got error as you can see at the photo. What am I doing wrong?
tjohnson
Wed Feb 21, 2018 6:23 pm
Based on the error, it seems like the Assistant SDK is not finding valid credentials in the file /home/pi/assistant.json. Have you created an OAuth Client ID as explained here, downloaded the client secret JSON file to your Pi, and renamed it to "assistant.json"?
Also, it looks like you're running Ubuntu with GNOME on your Pi. I've considered doing that too, I'm curious how resource intensive it is. Does it run fast?
Neavvy
Sat Feb 24, 2018 9:20 am
Thanks for your reply, I solved my problem.
Yes, this works fast.
loefkvist
Mon Mar 05, 2018 11:02 pm
I keep getting an exception when running the install-deps.sh script:
Exception:
File "/home/pi/voice-recognizer-raspi/env/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
chunked=chunked)
File "/home/pi/voice-recognizer-raspi/env/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 391, in _make_request
six.raise_from(e, None)
Full exception text here:
https://docs.google.com/document/d/1Qud ... sp=sharing
Seems like it is trying to get something from a server which does not respond correctly.
Any idea how to fix this?
tjohnson
Tue Mar 06, 2018 3:14 am
Exception:
chunked=chunked)
Judging by the full exception text, it seems like pip gets disconnected in the middle of downloading dependencies. I've experienced the same problem before, and unfortunately don't know how to fix it, I just had to keep retrying and it worked for me after a few tries. Sorry I can't be more helpful.
loefkvist
Tue Mar 06, 2018 11:24 pm
...removed content...
Ok - after running the script a several times it finally succeded.
Thanks for the input.
Now when actually running the thing I end up with this:
pi@KAssistant:~/voice-recognizer-raspi $ source env/bin/activate
(env) pi@KAssistant:~/voice-recognizer-raspi $ python3 src/main.py
File "src/main.py", line 35, in <module>
from google.assistant.library import Assistant
ImportError: No module named 'google.assistant.library'
Sooo.... had to (re-)install the google.assistant.library:
$> env/bin/pip install google-assistant-library==0.0.2
Running main.py again then asks me to authorize and blah - did this and ended up with:
[2018-03-06 23:14:25,909] INFO:root:OAuth credentials initialized: /home/pi/.cache/voice-recognizer/assistant_credentials.json
File "src/main.py", line 101, in <module>
main()
File "src/main.py", line 95, in main
with Assistant(credentials, model_id) as assistant:
TypeError: __init__() takes 2 positional arguments but 3 were given
__init__() must be called from the Assistant code I guess but this is within the lib itself?
Any ideas?
tjohnson
Wed Mar 07, 2018 1:03 am
main()
Any ideas?
Version 0.0.2 of the Google Assistant library won't work with the latest version of the code on GitHub. Try installing a newer version:
pip3 install google-assistant-library==0.1.0
EchoTecho
Wed Mar 07, 2018 8:11 pm
Currently getting this error running python3 src/main.py
File "src/main.py", line 31, in <module>
import aiy.assistant.auth_helpers
File "/home/UserNameIsNotPi/voice-recognizer-raspi/src/aiy/assistant/auth_helpers.py", line 24, in <module>
import google_auth_oauthlib.flow
ImportError: No module named 'google_auth_oauthlib'
Currently trying this on Ubuntu Mate 16.04.4 on Raspberry Pi 3 Model B
Anyone know how to fix this?
tjohnson
Thu Mar 08, 2018 12:15 pm
The Assistant SDK needs to be run in a virtual environment in order to find the Google libraries. Try running:
in the terminal before launching the Python script. This enables the virtual environment that has the Google packages installed, so every time you want to run the Python script it needs to be activated first.
Thu Mar 08, 2018 2:18 pm
You need to install the pre-requisites for Google assistant.
See https://github.com/google/aiyprojects-raspbian
Specifically: https://github.com/google/aiyprojects-r ... ements.txt
EchoTecho
Thu Mar 08, 2018 3:09 pm
After installing those, the script worked and I authorized the application.
chaosjester
Sat Mar 24, 2018 8:59 am
I have followed this guide and have everything working, however I have 2 issues.
1 is that the reply volume is really low, lower than my system settings and lower than any other applications that make noise.
2 is that when I say OK Google, my screen connected via GPIO pins goes white and stays white.
Does anyone have any ideas what I can do?
TIA
tjohnson
Sat Mar 24, 2018 3:47 pm
TIA
Regarding the volume, unfortunately Google Assistant doesn't seem to be controlled by system volume on the Pi. Try saying "OK Google, set volume to max" and that should fix it.
Regarding the screen, what GPIO pin(s) is it connected to? The Assistant SDK uses pin 25 by default to flash an LED when you say "OK Google". Perhaps that's messing with your screen, I don't know what to suggest otherwise.
chaosjester
Sun Mar 25, 2018 3:50 am
Thanks, the volume command did the trick.
My LCD is connected to pin 25, have checked if there is any way to disable the LED, but so far nothing has done the job, will keep investigating that though, thank you :)
tjohnson
Sun Mar 25, 2018 4:26 am
If changing the GPIO pin used by the LED is sufficient, I think it should be possible to do so by changing the _GPIO_LED constant at the top of /src/aiy/voicehat.py. If you need to disable the LED completely, that would be significantly more difficult as you mentioned.
DrJohnW
Sat Mar 31, 2018 2:55 pm
When it comes to registering a device, it asks for a device type. I did not see "computer", but saw other devices like Vacuum, Thermostat, Scene, Camera and the like. I tried selecting "Scene", but when it comes to running the code, I get:
main()
File "src/main.py", line 94, in main
model_id, device_id = aiy.assistant.device_helpers.get_ids(credentials)
File "/home/pi/voice-recognizer-raspi/src/aiy/assistant/device_helpers.py", line 98, in get_ids
model_id = model_id or _get_model_id(credentials, session, project_id)
File "/home/pi/voice-recognizer-raspi/src/aiy/assistant/device_helpers.py", line 79, in _get_model_id
r.raise_for_status()
File "/home/pi/voice-recognizer-raspi/env/lib/python3.5/site-packages/requests/models.py", line 928, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: https://embeddedassistant.googleapis.co ... viceModels
Is there a different device type I should select or is there a way around selecting a device type? Thanks in advance!
tjohnson
Tue Apr 10, 2018 2:26 pm
main()
Sorry for the delay in replying, I've been extremely busy with school recently. It's been a while since I've registered my device, so I might be wrong about this, but I don't think it should be necessary to select a device type following these instructions: https://aiyprojects.withgoogle.com/voic ... d-platform
If it still requires selecting a device type I would suggest trying Light, but I believe the Assistant SDK should automatically handle the device type.
Ryan780
Sat Apr 14, 2018 4:04 pm
I was wondering if this version of the Assistant supported the new Broadcasts feature because I can't seem to get it to receive broadcasts that other home devices are receiving.
Alimismail30
Sun Apr 15, 2018 2:39 pm
Good day.
I ran into a issue which I can’t seem to fix.
When I paste source env/bin/activate
It say “bash: env/bin/activate: No Such File or Directory”
Could you please help me. Thanks :oops:
brunoholanda
Sat May 05, 2018 8:00 pm
How did you solve this problem?
oss001
Fri May 11, 2018 4:27 am
When running install-deps.sh I am getting the following error output...
google-api-core 0.1.4 has requirement requests<3.0.0dev,>=2.18.0, but you'll have requests 2.14.2 which is incompatible.
Anyone know what I can do to resolve?
WINNPC
Wed May 16, 2018 9:31 am
Dear friend , i have the same problem with you. Could you kindly help me how to fix its step by step . Many thanks in advance .
WINNPC
Wed May 16, 2018 3:45 pm
main()
requests.exceptions.HTTPError: 429 Client Error: Too Many Requests for url: https://embeddedassistant.googleapis.co ... viceModels
Dear friend , I got this error --- how can I fix its. Many thanks in advance @EchoTecho @DrJohnW
tjohnson
Sun May 20, 2018 12:42 am
Good day.
Make sure that in your terminal the current directory is ~/voice-recognizer-raspi (if not you can cd to it). If you ran all the commands in step 3 and they completed without errors, then the env/bin/activate file should exist.
