I'm having difficulty with the code hanging or simply taking very variable amounts of time to complete the same task.
I have 4 load cells each connected to their own HX711 which then connects to a Raspberry Pi 3B+.
The HX711 module I use is immediately below.
#!/usr/bin/env python
# HX711.py
# 2018-03-05
# Public Domain
CH_A_GAIN_64 = 0 # Channel A gain 64
CH_A_GAIN_128 = 1 # Channel A gain 128
CH_B_GAIN_32 = 2 # Channel B gain 32
DATA_CLKS = 24
X_128_CLK = 25
X_32_CLK = 26
X_64_CLK = 27
PULSE_LEN = 15
# If the data line goes low after being high for at least
# this long it indicates that a new reading is available.
TIMEOUT = ((X_64_CLK + 3) * 2 * PULSE_LEN)
# The number of readings to skip after a mode change.
SETTLE_READINGS = 5
import time
import pigpio # http://abyz.co.uk/rpi/pigpio/python.html
class sensor:
A class to read the HX711 24-bit ADC.
def __init__(self, pi, DATA, CLOCK, mode=CH_A_GAIN_128, callback=None):
Instantiate with the Pi, the data GPIO, and the clock GPIO.
Optionally the channel and gain may be specified with the
mode parameter as follows.
CH_A_GAIN_64 - Channel A gain 64
CH_A_GAIN_128 - Channel A gain 128
CH_B_GAIN_32 - Channel B gain 32
Optionally a callback to be called for each new reading may be
specified. The callback receives three parameters, the count,
the mode, and the reading. The count is incremented for each
new reading.
self.pi = pi
self.DATA = DATA
self.CLOCK = CLOCK
self.callback = callback
self._paused = True
self._data_level = 0
self._clocks = 0
self._mode = CH_A_GAIN_128
self._value = 0
self._rmode = CH_A_GAIN_128
self._rval = 0
self._count = 0
self._sent = 0
self._data_tick = pi.get_current_tick()
self._previous_edge_long = False
self._in_wave = False
self._skip_readings = SETTLE_READINGS
pi.write(CLOCK, 1) # Reset the sensor.
pi.set_mode(DATA, pigpio.INPUT)
pi.wave_add_generic(
[pigpio.pulse(1<<CLOCK, 0, PULSE_LEN),
pigpio.pulse(0, 1<<CLOCK, PULSE_LEN)])
self._wid = pi.wave_create()
self._cb1 = pi.callback(DATA, pigpio.EITHER_EDGE, self._callback)
self._cb2 = pi.callback(CLOCK, pigpio.FALLING_EDGE, self._callback)
self.set_mode(mode)
def get_reading(self):
Returns the current count, mode, and reading.
The count is incremented for each new reading.
return self._count, self._rmode, self._rval
def set_callback(self, callback):
Sets the callback to be called for every new reading.
The callback can be cancelled by passing None.
def set_mode(self, mode):
Sets the mode.
self._mode = mode
if mode == CH_A_GAIN_128:
self._pulses = X_128_CLK
elif mode == CH_B_GAIN_32:
self._pulses = X_32_CLK
elif mode == CH_A_GAIN_64:
self._pulses = X_64_CLK
else:
raise ValueError
self.pause()
self.start()
def pause(self):
Pauses readings.
self._paused = True
self.pi.write(self.CLOCK, 1)
time.sleep(0.002)
self._clocks = DATA_CLKS + 1
def start(self):
Starts readings.
self._wave_sent = False
self.pi.write(self.CLOCK, 0)
self._value = 0
self._paused = False
def cancel(self):
Cancels the sensor and release resources.
self.pause()
if self._cb1 is not None:
self._cb1.cancel()
self._cb1 = None
if self._cb2 is not None:
self._cb2.cancel()
self._cb2 = None
if self._wid is not None:
self.pi.wave_delete(self._wid)
self._wid = None
def _callback(self, gpio, level, tick):
current_edge_long = False #I corrected this not surre tis is correct
if gpio == self.CLOCK:
if level == 0:
self._clocks += 1
if self._clocks <= DATA_CLKS:
self._value = (self._value << 1) + self._data_level
if self._clocks == DATA_CLKS:
if self._value & 0x800000: # unsigned to signed
self._value |= ~0xffffff
if not self._paused:
if self._skip_readings <= 0:
self._count = self._sent
self._rmode = self._mode
self._rval = self._value
if self.callback is not None:
self.callback(self._count, self._rmode, self._rval)
else:
self._skip_readings -= 1
else:
self._data_level = level
if self._data_tick is not None:
current_edge_long = pigpio.tickDiff(
self._data_tick, tick) > TIMEOUT
if current_edge_long and not self._previous_edge_long:
if not self._in_wave:
self._in_wave = True
self.pi.wave_chain(
[255, 0, self._wid, 255, 1, self._pulses, 0])
self._clocks = 0
self._value = 0
self._sent += 1
self._data_tick = tick
self._previous_edge_long = current_edge_long
if __name__ == "__main__":
import time
import pigpio
import HX711
def cbf(count, mode, reading):
print(count, mode, reading)
pi = pigpio.pi()
if not pi.connected:
exit(0)
s = HX711.sensor(
pi, DATA=20, CLOCK=21, mode=HX711.CH_B_GAIN_32, callback=cbf)
try:
print("start with CH_B_GAIN_32 and callback")
time.sleep(2)
s.set_mode(HX711.CH_A_GAIN_64)
print("Change mode to CH_A_GAIN_64")
time.sleep(2)
s.set_mode(HX711.CH_A_GAIN_128)
print("Change mode to CH_A_GAIN_128")
time.sleep(2)
s.pause()
print("Pause")
time.sleep(2)
s.start()
print("Start")
time.sleep(2)
s.set_callback(None)
print("Cancel callback and read manually")
c, mode, reading = s.get_reading()
stop = time.time() + 3600
while time.time() < stop:
count, mode, reading = s.get_reading()
if count != c:
c = count
print("{} {} {}".format(count, mode, reading))
time.sleep(0.05)
except KeyboardInterrupt:
pass
s.pause()
s.cancel()
pi.stop()
This is my main code:
import time
import pigpio
import HX711
pipette = pigpio.pi("192.168.1.208")
if not pipette.connected:
exit(0)
sensor1 = HX711.sensor(pipette, DATA=6, CLOCK=5, mode=HX711.CH_A_GAIN_128, callback=None)
sensor2 = HX711.sensor(pipette, DATA=17, CLOCK=15, mode=HX711.CH_A_GAIN_128, callback=None)
sensor3 = HX711.sensor(pipette, DATA=4, CLOCK=14, mode=HX711.CH_A_GAIN_128, callback=None)
sensor4 = HX711.sensor(pipette, DATA=27, CLOCK=18, mode=HX711.CH_A_GAIN_128, callback=None)
all_sensors = [sensor1, sensor2, sensor3, sensor4]
try:
for sens in all_sensors:
sens.start()
print("Start")
time.sleep(2)
t1 = time.perf_counter()
for x in range(10):
result = sens.get_reading()
while result[0] == sens.get_reading()[0]:
pass
t2 = time.perf_counter()
print(f"Sensor: {sens} result: {result[2]} time taken:{t2-t1}")
sens.pause()
sens.cancel()
pass
pipette.stop()
The following is an example of a result I get.
Start
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 0 time taken:0.9955373000000001
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 129535 time taken:10.4054165
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 127231 time taken:10.4671392
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 129023 time taken:10.5555238
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 130303 time taken:10.7426572
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 126463 time taken:11.0009446
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 126927 time taken:11.159071899999999
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 127807 time taken:11.4898796
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 126735 time taken:12.5092944
Sensor: <HX711.sensor object at 0x000001FDCC7ADB20> result: 130175 time taken:12.555926
Start
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: -319911 time taken:0.8414417000000007
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: 5435 time taken:5.383816299999999
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: -319894 time taken:5.4353561
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: -318908 time taken:5.536401100000003
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: -319795 time taken:5.658232000000002
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: -319575 time taken:5.702394900000002
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: -114905 time taken:7.158136600000002
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: 4975 time taken:7.665401200000002
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: -160705 time taken:16.160488200000003
Sensor: <HX711.sensor object at 0x000001FDCC7ADAC0> result: -319750 time taken:16.2340569
Start
Why does it seem to hang? Why is there such variation between the time taken for each reading?
Any help would be much appreciated.
