W6JHB
How to make icon to launch an app?
Tue Mar 06, 2018 1:27 am
Hi - running Raspian on a Pi 3 and have a relatively newbie question. I have an app along with a folder containing several required files residing in another folder in my home directory. If I double click the app from within the File Manager, it works great. However, I don’t want to have to fire up File Manager just to run this program. I tried copying the app to the desktop, but when I try to run it from the icon on the desktop, it doesn’t run. Apparently it has to be in the same location as the folder with those required files. Copying and pasting that folder to the desktop results in the app working when run from the desktop.
However, I don’t want to clutter up my desktop with folders up the wazoo every time one of those apps comes along. How can I create an icon, a Script, or whatever it takes to be able to click on ONE thing on the desktop that will execute the app in the folder in my home directory where it sits?
Tnx, Jim
Jim Bennett / W6JHB
Folsom, CA
USA
KLL
Re: How to make icon to launch an app?
Tue Mar 06, 2018 2:00 am
these ICONs are .desktop files
nano /home/pi/Desktop/myprog.desktop
you can start a bash script or app
[Desktop Entry]
Type=Application
Name=speed test start
Exec=/home/pi/projects/speedtestnet/speedtest.sh
Icon=network
Comment=start python speedtest-cli
Terminal=true
X-KeepTerminal=false
Categories=Network;
or a URL
nano /home/pi/Desktop/gmail.desktop
[Desktop Entry]
Type=Link
URL=https://mail.google.com/mail/?tab=wm#inbox
Name=GMAIL
Comment=start browser gmail
klricks
Tue Mar 06, 2018 2:33 am
Another way...
[Menu] -> [Preferences] -> [Main Menu Editor]
Select the menu that you want and click [New Item]
Fill in fields
If needed select Launch in terminal.
[OK] to exit editor
Now go [Menu] and find the new menu item and RIGHT click on it, then click [Add to Desktop]
Now if you want to make changes such as changing the icon file, the new desktop entry can be found here:
~/.local/share/applications/alacarte-made.desktop
If you make a second or more desktop icon the it will look like this:
~/.local/share/applications/alacarte-made-1.desktop
W6JHB
Tue Mar 06, 2018 9:28 pm
Thanks folks - I got it to work using a combination of the answers above. Much appreciated!
Jim Bennett / W6JHB
Folsom, CA
USA
Techster14
Wed Sep 04, 2019 2:46 am
so, i tried the first responce and i get an error:
Invalid desktop entry file: '/home/pi/Desktop/myprogram.desktop'
Why is it saying this?
