greenlantern23
waveshare 1.44" tft lcd HAT (st7735s) (Solved)[obsolete]
Sun Mar 11, 2018 9:59 pm
Hi. i bought 1.44inch LCD HAT from Waveshare. The screen has a driver st7735s. I have difficulties installing this screen on the raspberry PI.
For installation, I used this manual.
Then, in the file: /etc/modprobe.d/fbtft.conf, i use:
options fbtft_device name=fb_st7735r gpios=reset:27,dc:25,led:18 speed=16000000 bgr=1 custom=1 width=128 height=128
And, unfortunately, it does not work quite correctly.
As a result, after starting, the screen shows two bars of pixels that are not defective screen or damage.
How to fix these pixel frames?
Last edited by greenlantern23 on Mon Mar 12, 2018 8:43 pm, edited 1 time in total.
greenlantern23
Re: waveshare 1.44" tft lcd HAT (st7735s)
Mon Mar 12, 2018 8:38 pm
with the help of user moosepr from this site. the solution to the problem was quickly found.
Please read to the end before you start.
1. You must follow the instruction in this page.
(It is better to perform all operations via SSH. I am using PuTTY)
2. When it comes to the step:
sudo nano /etc/modprobe.d/fbtft.conf
Paste these settings into the file:
options fbtft_device name=adafruit18_green gpios=reset:27,dc:25,cs:8,led:24 speed=40000000 bgr=1 fps=60 custom=1 height=128 width=128 rotate=180
3. After completing step 2. simply continue with the instructions in step 1.
4. Carefully read about the configuration of the buttons in the instructions in step 1, everything is quite simple.
Screen button pins can be found here.
I tried to describe everything as simple as possible. Good luck to everyone.
code_inc_
Re: waveshare 1.44" tft lcd HAT (st7735s) (Solved)
Sat Mar 31, 2018 2:11 am
hello i already made a retropie image of it and i have a download link on my video about it too. https://drive.google.com/file/d/13V5js_ ... sp=sharing
have fun with the mini boy image.
snakewa
Fri Jun 15, 2018 3:53 pm
miniboy image from google drive seems to be invalid. Etcher cannot write this image to SD card.
JohnAo
Wed Aug 22, 2018 1:45 pm
Hi! Thank you for your instructions on configuring files. Mine is working fine except the 'A' and 'B' buttons.
I set the "/boot/retrogame.sh" file as:
LEFT       5  # Joypad left
RIGHT     26  # Joypad right
UP         6  # Joypad up
DOWN      19  # Joypad down
LEFTCTRL  21  # 'A' button
LEFTALT   20  # 'B' button
#Z         21  # 'X' button
#X         20  # 'Y' button
SPACE     13  # 'Select' button
ENTER     16  # 'Start' button
#A        12  # Left shoulder button
#S        13  # Right shoulder button
#ESC      17  # Exit ROM; PiTFT Button 1
#1        22  # PiTFT Button 2
#2        23  # PiTFT Button 3
#3        27  # PiTFT Button 4
and the LEFTCTRL and LEFTALT buttons won't work while others work well.
I tried to alter the pins for LEFTCTRL and LEFTALT but the problem remains, so it's not about the pins.
What should I do?
iwilliams89
Thu Jan 17, 2019 6:48 pm
How can I go about mapping the keys for this in Raspbian.
I have attempted to build out an overlay and started it upon boot.
I have 2 of the directions on the Joystick functioning via this but it appears the others are having issues here is what my GPIO and overlay currently looks like.
GPIO Readall
and
Overlay code
/dts-v1/; /plugin/; / { compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
fragment@0 {
target-path = "/";
__overlay__ {
keypad: waveshare_keys {
compatible = "gpio-keys";
#address-cells = <1>;
#size-cells = <0>;
#autorepeat;
button@5 {
label = "JOYSTICK UP"; ----------Works Outputs in evtest
linux,code = <103>;
gpios = <&gpio 5 1>;
button@6 {
label = "JOYSTICK RIGHT"; -------------- Works Outputs in evtest
linux,code = <106>;
gpios = <&gpio 6 1>;
------------------Everything Below Fails-------------------------- And doesnt output in evtest
button@19 {
label = "JOYSITCK LEFT";
linux,code = <105>;
gpios = <&gpio 19 1>;
button@
button@13 {
label = "JOYSTICK PRESS";
linux,code = <28>;
gpios = <&gpio 13 1>;
button@21 {
label = "KEY 1";
linux,code = <38>;
gpios = <&gpio 21 1>;
button@20 {
label = "KEY 2";
linux,code = <56>;
gpios = <&gpio 20 1>;
button@16 {
label = "KEY 3";
linux,code = <54>;
gpios = <&gpio 16 1>;
cuestix
Thu Mar 28, 2019 1:03 am
It may be a little late but I believe your problem has to do with a typo,
Should be
label = "JOYSTICK LEFT";
Hope this helps!
tiz.io
Mon Apr 15, 2019 12:22 am
For the next person with this problem, here is the exact link to the fix
TL, DR:
This is a sort of rotation off-by-one issue that happens when the fb0 and fb1 settings aren't aligned.
Set rotate to 180 in /etc/modprobe.d/fbtft.conf
Set display_rotate to 1 in /boot/config.txt
cruce
Tue Oct 22, 2019 4:32 pm
Does anyone have any suggestions for someone still having garbled pixels along the left side? It looks to be 3 pixels wide. I am using a Raspberry Pi Zero W with 2019-06-20-raspbian-buster-full image. I am booting into console and not desktop. Everything looks great except that it appears the display is shifted to the right by 3 pixels and resulting in garbled pixels along the left.
And, yes I have followed the above solution as well as what was documented here, https://sudomod.com/forum/viewtopic.php ... 7&start=10.
Thanks for your assistance.
bfg-e
Sun Feb 23, 2020 3:56 pm
I tryed this and i dont get any picture at all , i modifyed the dc and rst gpios to 24 and 25
radiohands
Sun Apr 05, 2020 4:50 am
Haven't tracked down why yet, but this no longer works on a fresh install of raspbian or retropie. If you download and install the "TinyPi-Retropie-v4.3" and change the modeprobe and rotation info it will work. In my case I wasn't able to connect it to wifi until I hardwired the pi with a usb ethernet adapter and ssh'd in.
