I carefully read the official Raspberry Pi 3 Model B+ announcement – and all 450+ comments at the time of this writing. I am fully aware that the 3B+ requires the latest "firmware" and boot code – with a fully updated and current copy of Raspbian Stretch. Otherwise, it will simply not work.
Therefore, in preparation for the arrival of my brand-new 3B+, I updated a completely pristine and unmodified copy of Raspbian Stretch (with Desktop) on my existing 3B. I did that by running the following two commands in Terminal – followed by a reboot:
sudo apt-get update
sudo apt-get dist-upgrade
Yet no matter what, my new 3B+ would not boot from my newly-updated SD card. Instead, it locked up within one second of being turned on – forever stuck at the "rainbow" screen with a yellow lightning bolt in the upper-right corner. Here's an actual picture of what it looked like on my 1080p monitor (red arrow magnification superimposed):
TECHNICAL DETAILS: When I say I used an "unmodified" and "pristine" copy of Stretch, I mean that literally – no software of any kind had been installed on the system. It was a completely fresh copy straight from NOOBS – running on a high-end "known good" Samsung 32 GB SD card in the standard internal SD card slot. I'm the author of the Raspberry's gigantic FFmpeg / mpv tutorial, so I have several testing cards on hand.
For reference, my pristine operating system was created by what was, until just 7 days ago, the most recent version of NOOBS – NOOBS v2.4.5 (released on 2017-11-29). A few weeks ago, I had installed this version of NOOBS (2.4.5) onto a blank SD card from the official NOOBS image at raspberrypi.org/downloads/noobs.
The following is "before and after" data on my operating system, Linux kernel, and OS image – just BEFORE I ran "dist-upgrade" and just AFTER I ran "dist-upgrade" (on March 20):
OPERATING SYSTEM VERSION – GENERATED BY: lsb_release -a
BEFORE DIST-UPGRADE:
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.3 (stretch)
Release: 9.3
Codename: stretch
AFTER DIST-UPGRADE:
Description: Raspbian GNU/Linux 9.4 (stretch)
Release: 9.4
Codename: stretch
LINUX KERNEL VERSION – GENERATED BY: uname -a
Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
AFTER DIST-UPGRADE:
Linux raspberrypi 4.9.80-v7+ #1098 SMP Fri Mar 9 19:11:42 GMT 2018 armv7l GNU/Linux
RASPBIAN IMAGE VERSION – GENERATED BY: cat /etc/rpi-issue
Raspberry Pi reference 2017-11-29
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, b71bf3179310aadf9aaf2ffcdf094a88e488dce8, stage5
AFTER DIST-UPGRADE:
TECHNICAL SUMMARY: As you can see, "dist-upgrade" correctly updated my version of Raspbian Stretch from 9.3 to 9.4. It also updated the Linux kernel from October 29, 2017 to March 9, 2018. And, as one would expect, my Raspbian image version did NOT change. At this point, the SD card had a fully updated and current copy of Raspbian Stretch – as of March 20, 2018. But keep in mind that the underlying version of NOOBS was still 2.4.5 – not 2.7.0. In other words, my NOOBS image was still from November 29 – not March 14.
Given the deployed base of several million 3Bs, this would be a very common scenario. Running "dist-upgrade" or "upgrade" only takes a few minutes. But installing a brand-new copy of NOOBS from scratch, from a fresh image, can easily take several hours – especially if you've customized your system and need to get everything back to the way it was. Since there was no mention that I had to install an entirely new image of NOOBS all over again from scratch, it made perfect sense to simply run "dist-upgrade".
Realize also that after fully updating my system (except NOOBS), everything worked perfectly on my existing 3B. It booted normally from the SD card and behaved in a perfectly normal fashion.
So when my 3B+ arrived in the mail a few hours later, I simply put the newly-updated SD card into the internal SD card slot, plugged it in to the official power supply (5V, 2.5A), and attached it to my monitor via an HDMI cable. No other devices, USB or otherwise, were attached to my new Raspberry.
I then turned it on and it almost immediately locked up at the "rainbow" screen with the lightning bolt (see image above).
So there you go: I think I've made it abundantly clear that I did everything in a completely standard fashion on a completely standard set-up – both at the hardware and software level.
Yet my new 3B+ would simply not boot!
HOW DID I SOLVE THIS VEXING PROBLEM? My solution was time-consuming but effective:
I installed the latest version of NOOBS and everything worked!
FINAL NOTE: I saw a few comments that implied success with "dist-upgrade" or "upgrade" – but none of them explicitly mentioned NOOBS! I suspect they had skipped the NOOBS image and were instead running off a "pure" Raspbian image (without NOOBS). Hopefully, the Raspberry Pi Foundation can address this situation – without requiring a complete "NUKE" of the Raspberry!
UPDATE – APRIL 30, 2018: I have now created an entirely new solution that updates NOOBS without re-installing it. That way, your system won't get "nuked". Please see my brand-new tutorial here:
TUTORIAL: Update NOOBS without Re-Installing It (When Your Raspberry Pi 3B+ Won't Boot!)
SOLVED: Raspberry Pi 3 Model B+ Will Not Boot!
Re: SOLVED: Raspberry Pi 3 Model B+ Will Not Boot!
One problem with NOOBS is that apt doesn't upgrade the NOOBS system as well as Raspbian. You need to do some awkward dance steps to update NOOBS as well. Your Raspbian is most certainly fine, but it needs to boot into NOOBS first, then reboot into Raspbian and it is NOOBS that is failing.
I'm afraid I cant tell you how to update NOOBS, I tried using it once and went back to straight Raspbian images. I think it involves downloading the latest NOOBS Lite and copying some of the files over to your current system.
rpdom wrote: ↑Wed Mar 21, 2018 7:32 amOne problem with NOOBS is that apt doesn't upgrade the NOOBS system as well as Raspbian. You need to do some awkward dance steps to update NOOBS as well. Your Raspbian is most certainly fine, but it needs to boot into NOOBS first, then reboot into Raspbian and it is NOOBS that is failing.
Your observations make perfect sense.
Fortunately, as you saw, I was able to get everything working – but it definitely took a good chunk of time to re-load NOOBS from scratch.
Ultimately, I wanted to thoroughly document this significant issue and put it out there. I also wanted to share my solution with the rest of the community.
My hope is that in the near future, the Raspberry Pi Foundation can resolve this matter. A lot of existing customers will buy a 3B+ – so this one issue could easily result in hundreds of thousands or even millions of frustrated people!
- DougieLawson
The RPF folks have already fixed it. Use NOOBS 2.7 or NOOBS lite 2.7 and it just works.
You may be able to copy stuff from NOOBS Lite 2.7 to the unbootable card. The RPF folks won't do that for you.
There's instructions out on t'internets for doing that from last time when NOOBS needed an upgrade.
DougieLawson wrote: ↑Thu Mar 22, 2018 12:41 amThe RPF folks have already fixed it. Use NOOBS 2.7 or NOOBS lite 2.7 and it just works.
Where do I even begin Dougie?
As I clearly explained in my original post, there was no mention of any need for a complete "nuke and reload" of NOOBS in the official Raspberry Pi 3 Model B+ announcement.
That's a multi-hour project and it's not trivial – it's also a very unfortunate "first experience" for any existing NOOBS user who doesn't just happen to have the very latest version of NOOBS just laying around on an SD card.
The latest version of NOOBS was only published 7 days ago! What percent of existing Raspberry users would meet that requirement? Very few.
Yet you make it sound like "duhhh – the RPF already has a fix for that!"
In fact, all that's been said by the RPF is that you need to update the "firmware" (which occurs automatically during a standard upgrade of Raspbian) – without any mention that a complete overhaul of NOOBS may also be required. Just to make it clear I know what I'm talking about, here's what a leading RPF engineer said just 2 days ago in a posting to the official announcement page:
The full reality, of course, is a bit more complicated: A simple Raspbian upgrade is necessary but NOT sufficient to get a 3B+ to boot IF YOU'RE USING NOOBS AND IT'S MORE THAN 7 DAYS OLD!
Now back to your claim that it's been "fixed". It ain't a "fix" if the so-called "fix" has never been published and the customers have not been informed of this show-stopping issue. That was the significant contribution of my post, however much you wish to dismiss it.
Of course, having to completely re-load NOOBS from a new image is far from a "fix" – instead, it's a complete re-creation of the entire SD card from scratch. That takes hours. It's the equivalent of eviscerating an entire car and then re-building a new one in order to "fix" a broken muffler. Will that "fix" the problem? Yes it will. But a true "fix" would mean just replacing the muffler. Ideally, a downloadable patch or some other simple method would make existing recent copies of NOOBS "3B+ ready". Keep in mind, my existing NOOBS was far from old – it was, in fact, the very latest version until just 8 days ago! And thanks to "dist-upgrade", my version of Raspbian was 0 days old! Yet that was still not enough for my 3B+ to boot.
Don't get me wrong – there may be perfectly valid technical reasons why NOOBS can't be easily updated. So the RPF may have a very good rationale for not addressing this in a simple way. Like many things in life, it may just be an unfortunate reality. It may just be that the only "official" way this can be resolved is by installing the latest version of NOOBS from scratch. And that indeed is what I explained in my posting. It's what I did and it worked!
But at a minimum, this critical information should be included in the official announcement and marketing materials for the 3B+.
Otherwise, there will be a TON of frustrated customers who will wonder why their brand-new Raspberry won't even boot!
- HawaiianPi
This is exactly why NOOBS should be done away with. In the early days of the Pi it did have its place, but now it just causes more problems than it solves. Stop using NOOBS and start using Raspbian images. They are actually easier to install than NOOBS now (using Etcher), and they can be easily updated for newer systems (provided you are using a current release version, which is Stretch at the time of this post).
HawaiianPi wrote: ↑Thu Mar 22, 2018 4:14 amThis is exactly why NOOBS should be done away with. In the early days of the Pi it did have its place, but now it just causes more problems than it solves. Stop using NOOBS and start using Raspbian images. They are actually easier to install than NOOBS now (using Etcher), and they can be easily updated for newer systems (provided you are using a current release version, which is Stretch at the time of this post).
Perhaps you're right – perhaps NOOBS should be done away with! Or improved to make it easily updatable.
There is one nice thing about NOOBS, however – the ability to "nuke and reload" the operating system is completely self-contained within the SD card.
In other words, if things go completely haywire with your OS, NOOBS by itself can usually reconstitute everything and give the user a clean, brand-new OS without requiring any external resources. I realize that one can also reconstitute things if they have access to another computer – or a separate, cloned SD card with a working OS. But not everyone has those luxuries.
Nonetheless, rightly or wrongly, the RPF continues to present NOOBS as "an easy operating system installer for beginners" – and beginners are clearly encouraged to use it. So the NOOBS user base would tend to be less technically sophisticated than those who install "pure" Raspbian without NOOBS.
That only makes the complications I identified even more concerning!
- HawaiianPi
That's true, but NOOBS also reduces the capacity of your SD card by more than a gig (something like 1.3GB) for that functionality. And how many people don't have another computer, or at least a spare SD card and card reader? You can even write Raspberry Pi SD cards with a smartphone now (there's an app for that).
Spoken like a true First Worlder! :-)
Although I have multiple computers, NOOBS has been a handy testing vehicle for my giant FFmpeg / mpv tutorial – because it allows me to quickly start from a fresh OS anytime I make a minor tweak to my instructions. That way, I can absolutely verify that I'm not making any false assumptions. In other words, it lets me know that my tutorial didn't "accidentally" work because of some other package or alteration I made to an existing system.
I realize I could keep a pristine OS copy sitting around on a separate cloned SD card, but then I'd have to "waste" another card by devoting it to that one purpose.
With NOOBS, I've got a self-contained testing card that will "reset" itself from scratch – giving me a brand-new testing OS in minutes. My whole philosophy is to replicate what a total beginner would start from.
Nonetheless, if an easy NOOBS updater can't be created, I would agree with you – the RPF should probably consider abandoning NOOBS.
RPi_Mike wrote: ↑Thu Mar 22, 2018 7:32 am
PiNN should replace NoobS if we have / need / want something like this:
viewtopic.php?t=142574
Though Raspbian and Etcher should be touted as best fit for newcomers.....
- DougieLawson
Just for completeness (so I can easily find the URL next time)RPi_Mike wrote: ↑Thu Mar 22, 2018 3:15 amDougieLawson wrote: ↑Thu Mar 22, 2018 12:41 amThe RPF folks have already fixed it. Use NOOBS 2.7 or NOOBS lite 2.7 and it just works.
https://thepihut.com/blogs/raspberry-pi ... berry-pi-2
Same process for getting old NOOBS working for RPi3B+ and it is a pain in the tail.
The most important piece of that is
If you copy recovery.cmdline you will completely break your existing NOOBS installation.Copy everything from the extracted ZIP EXCEPT for 'recovery.cmdline' to the top directory of your microSD card.
Had the same issue - I was not going to spend hours to reconfigure all the repos and libs. Tried on old pi but the kernel was still v4.9 17th July 2017 and the latest raspbian is v4.9 18th March 2018. Looks like the kernel is not updating to latest.
So instead tried. Got the latest kernel (v4.14) . Removed this sd card from the old RPI 3 to the RPi 3 B+. All is working now
Note: if rpi-update method is not installed then you will need to do
So instead tried
sudo rpi-update
sudo apt-get install rpi-update
Which is more or less the result of an updated ThreadX contained in the raspberrypi-bootloader package and not the raspberrypi-kernel package (the latter is important too of course since otherwise network won't function)
ThreadX is just a bunch of files on the FAT partition...
Note to DougieLawson: I give you quarter-credit for your answer on how to update NOOBS. The "instructions" you recommend at The Pi Hut might point an advanced user in the right direction, but it's woefully incomplete and just plain wrong in several critical ways. Here's why:
1: Raspbian, by default, does NOT mount partition #1 – whether the SD card is in an external USB adapter or in the internal SD card slot. For an advanced user like you, that of course is no big deal – you live and breath this stuff 24/7. For all but the most advanced users, however, the entire partition is completely INVISIBLE and UNTOUCHABLE. Neither you nor The Pi Hut makes any mention of this critical fact.
2: The Pi Hut directions you reference claim that you MUST update NOOBS on a separate computer – "a PC or Mac, I'm afraid." They apparently think that some of the files on partition #1 are "locked" or somehow inaccessible on a live system. This is not true.
3: The Pi Hut also says to copy all the new NOOBS files to "the top directory of your microSD card". To almost everyone – including advanced users – "top directory" means the "/" directory. Unfortunately, that would cause them to destroy the core of their system which resides on partition #7. What The Pi Hut probably meant to say is "the top directory of partition #1". But remember – partition #1, by default, DOES NOT EXIST in the eyes of Raspbian! Without issuing explicit commands to mount the partition, it's invisible to the user – and to Terminal and File Manager as well.
4: The Pi Hut makes no distinction between those with full NOOBS and NOOBS Lite.
5: There's yet another problem with your advice. That's because the content of partition #6 – the /boot partition – looks almost IDENTICAL to the content of partition #1. Making things even worse, Raspbian DOES mount partition #6 by default – making it even more likely that a beginner or intermediate-level user will destroy their entire system by damaging their critical boot files. To borrow a term you've personally used on this forum in the past, some would say your advice is "irresponsible".
Fortunately, I have now published a new tutorial that addresses all these issues – and much, much more (see link below).
Note to jigneshkerai89: Although you didn't fully describe your system configuration, your boot problem appears to be due to your use of an old operating system – not NOOBS itself. In fact, I suspect you were not even using NOOBS. So although you had the "same issue" superficially, you probably didn't have the same issue!
Running sudo rpi-update, as you did, will probably get Raspbian Jessie – the old and no-longer-supported Raspberry operating system – to successfully boot on the new Raspberry Pi 3 Model B+ – WITH ONE GIANT EXCEPTION (which I'll explain in a moment). I have not personally tested your method – simply because I'm not interested in old operating systems – but other reports suggest that your approach will probably work by updating the essential boot code that the 3B+ needs. However, that won't do anything to help people with NOOBS. Although it will update Raspbian's boot code, it will not update the "boot code" used by NOOBS. It's probably no coincidence that you didn't mention anything about NOOBS – so almost certainly, you have a "pure" copy of Raspbian Jessie (or Wheezy) without NOOBS! If someone has Raspbian Jessie with NOOBS, your method will not work – because it will do nothing to update the critical NOOBS files that are specific to partition #1. As a result, those people will still have an unbootable Raspberry.
As a separate matter, I personally don't have any issue with people using rpi-update – just as long as they back up their operating system and data. But it should be pointed out to less experienced users that the rpi-update command places EXPERIMENTAL Linux kernel and boot code on their system. The developers generally do a good job at testing this developmental code, but the potential still exists that it could cause a system to become unbootable – at least until the user can get their hands on a new, bootable SD card.
BOTTOM LINE: For people that want to get the new Raspberry Pi 3 Model B+ to boot from a "pure", non-NOOBS copy of Raspbian Jessie – an old operating system – running rpi-update is basically the only option available. But if they have Raspbian Jessie with NOOBS – they'll either have to completely "nuke" their system and install Raspbian Stretch with NOOBS from scratch – or, if they don't want to lose their existing system – they could theoretically try a whole bunch of complicated stuff that may or may not work (again, as I mentioned, I'm simply not interested in old operating systems – so that's territory I won't bother to explore). Finally, if they already have Raspbian Stretch with NOOBS – and they don't want to completely re-install NOOBS from scratch and lose everything on their existing SD card – they're in luck! Why? Because my brand-new tutorial explains exactly how to "non-destructively" update NOOBS without losing anything on your existing system!
HERE'S THE LINK TO MY BRAND-NEW TUTORIAL:
- HawaiianPi
Which means you are probably running Raspbian Jessie (not recommended for the new 3B+).jigneshkerai89 wrote: ↑Mon Mar 26, 2018 11:01 amHad the same issue - I was not going to spend hours to reconfigure all the repos and libs. Triedon old pi but the kernel was still v4.9 17th July 2017 and the latest raspbian is v4.9 18th March 2018. Looks like the kernel is not updating to latest.Code: Select all
Using rpi-update will seem to fix Jessie, but do note that rpi-update installs testing firmware that may have bugs and stability issues.
HawaiianPi wrote: ↑Tue May 01, 2018 5:49 pmWhich means you [jigneshkerai89] are probably running Raspbian Jessie (not recommended for the new 3B+). Using rpi-update will seem to fix Jessie, but do note that rpi-update installs testing firmware that may have bugs and stability issues.
My thoughts exactly. I wanted to point out, however, that I already went into great detail about jigneshkerai89's situation in the post right above yours. Please see the part that starts with Note to jigneshkerai89.
I'm hoping you can help me. I'm sure you'll see that the Raspberry Pi 3 model B+ and the entire use is new to me. I got as far as a B+ that shows me the rainbow, then the 4 Raspberries, but then a very long list of numbers such as 1.846309 followed by text that is of no use to me. I'm running an appropriate power supply, a 32gb microSD (Sandisk), and have simply extracted the Noob file on my laptop, then copied the files and folders over to the SD. I have a solid red light and a green that flashes several times, then quits. I don't even know what else to tell you. I'd appreciate your help. Thanks
- FTrevorGowen
- Forum Moderator
Are you seeing something like the first photo. of the "First Working Screen Photo's & VNC'c Screenshots:" section of my webpage here: http://www.cpmspectrepi.uk/raspberry_pi ... splay.html ? If so that suggests that you have a Pi that is booting to the command line rather than the full desktop (and the NOOBS installer now offers Raspbian Lite as an install option which you selected "by accident" maybe?).jkck616 wrote: ↑Tue Jan 29, 2019 8:39 pmI'm hoping you can help me. I'm sure you'll see that the Raspberry Pi 3 model B+ and the entire use is new to me. I got as far as a B+ that shows me the rainbow, then the 4 Raspberries, but then a very long list of numbers such as 1.846309 followed by text that is of no use to me.
Trev.
NOTE TO ALL READERS: This entire thread, which I started, only pertains to those with a "legacy" version of NOOBS. By "legacy", I mean a version that was made prior to March 14, 2018. That's almost a year ago at this point, so if you just got a brand-new Raspberry Pi 3B+ kit that came with a pre-installed copy of NOOBS on a microSD card, it's extremely unlikely that any of this pertains to you!
Likewise, if you have a 3B+ without a kit – and have just downloaded a fresh copy of NOOBS from this website and burned it onto a microSD card – this topic would also NOT pertain to you.
But if you're a "veteran" user of NOOBS and need to migrate a legacy installation of NOOBS from an older model of the Raspberry to the 3B+, my instructions are still very relevant. If this pertains to you, however, be sure to check out my other post which explains how to non-destructively update NOOBS without nuking your SD card and having to start all over again from scratch:
STICKY: TUTORIAL: Update NOOBS without Re-Installing It (When Your Raspberry Pi 3B+ Will Not Boot!)
NOTE TO jkck616: I tend to agree with FTrevorGowen's speculation that you might have unintentionally chosen the lite "command line only" version of Raspbian. So if you're looking for a "normal" windowed experience that looks similar to Mac or Windows, you'll definitely want one of the "Desktop" versions of Raspbian (either with or without NOOBS).
Whatever the case, seeing the "rainbow" screen briefly flash by during the boot process is perfectly normal. So the fact my post happens to mention the rainbow screen is MERE COINCIDENCE.
[For those with an unmodified legacy copy of NOOBS on the 3B+, the rainbow screen will get PERMANENTLY STUCK. That did not happen in your case, so none of my writings on this topic are relevant to your problem.]
Based on your somewhat vague description, you system appears to be booting just fine for at least the first few seconds. So if you continue to have problems, despite the above advice, my suggestion is to simply go back to the Raspberry's main download page and re-burn your SD card – with a Desktop version of Raspbian, if that's what you actually want. If that still doesn't work, start from a truly clean slate by using a new SD card!
NOTE TO THE RASPBERRY PI FOUNDATION + GENERAL COMMENTARY ON LINUX CULTURE: In case anyone from the RPF is reading this, it would be helpful if the wording on the NOOBS download page made it clear that installing NOOBS automatically gives you "Raspbian with desktop and recommended software (plus LibreELEC)". At the moment, it only says that NOOBS "contains Raspbian" – which of course could mean any one of 3 different things:
1: Raspbian Lite
2: Raspbian with desktop and recommended software
3: Raspbian with desktop (without the "recommended" software)
It would also be good if there were at least a sentence that explains what this extra "LibreELEC" thing actually is. Yes, the word "LibreELEC" on the NOOBS download page comes in the form of a link that would presumably tell a beginner what LibreELEC does. But that doesn't work either because the LibreELEC page hits the reader with a bunch of technical mumbo jumbo that wouldn't mean anything to a beginner – or even a PhD in computer science who just got a Raspberry! For example, the very first thing you see is their tag line: "LibreELEC – Just enough OS for KODI".
Huh? What? What's a KODI? [99% of their page calls it "Kodi", but their very prominent tag line and the browser title bar call it "KODI"]
However it's spelled, I certainly know what Kodi is – I even wrote a giant tutorial on how to automatically build GPU-accelerated versions of FFmpeg and mpv. But none of that is relevant because it only proves that I'm a Raspberry nerd!
Even their "about" page – which should begin with a general, plain-English introduction – starts off like this:
LibreELEC is a lightweight ‘Just enough OS’ Linux distribution purpose-built for Kodi on current and popular mediacentre hardware. We forked from the OpenELEC project...
Huh? What? What's this Kodi thing again? OpenELEC project? Huh? What's that? Fork? Is that like a spoon?
Although I'm a huge fan of Linux, this kind of technical "nerd-to-nerd" talk that speaks over the heads of even the most educated general audience is precisely the kind of thing that justifiably turned people off to Linux and made Bill Gates laugh every day!
He's still laughing – and has every right to – because the "Linux culture" has barely changed in this regard since its inception more than a quarter-century ago.
There are many reasons for this never-ending state of affairs, but the curse of knowledge is surely one of them!
1: Raspbian Lite
issue solved
Update kernel to version 4.14.37 and injoy :
use from this Link: https://www.raspberrypi.org/documentati ... pdating.md
Mohsen
my Gmail address: bahrami.mbi.k@gmail.com
Mohsen
mohsen-mbi wrote: ↑Mon Feb 04, 2019 1:17 pmissue solved
use from this Link: https://www.raspberrypi.org/documentation/linux/kernel/updating.md
Mohsen
This entire thread, which I started, is all about systems with "legacy" versions of NOOBS — so I have no idea what issue you've supposedly "solved".
Your advice is not appropriate, nor is it relevant to this thread.
For those who would like to know more about getting older versions of NOOBS to work on the model 3B+, please see my sticky at the top of the General Discussion room:
hi all,
I'm new to this kind of stuff and programing and etc. and just got myself a Raspberry pi3B+, also had the boot problem, but the only way I got it to work, that after it updated, it would not start, so I restarted it, pressed SHIFT, and reinstalled the OS, after that it booted up all the way, and after going through the standart procedures, I just skipped the last part where it wants to check for update's, now all good and working
gues I'll have to wait till new update arrives, to see if they fixed this problem
hope my method helps for someone
I'm a new user and really green on the whole programing stuff, but am willing to learn
I can't help but point out that much of computing is just a simple matter of critical reasoning — broad principles of logic that apply to many things in life.
For example, if someone gets hit by an asteroid and someone else steps on a land mine, they might both have the same "death problem".
But just because they might have the same "death problem" doesn't at all mean the underlying cause was the same! They might, in fact, be vastly different.
In this case, your "boot problem" had nothing to do with my post — even though my post was indeed about a "boot problem". Instead, it sounds like you had some kind of "whatever" that prevented your system from booting — and then you eventually stumbled across the handy feature in NOOBS that allows users to automatically re-install their operating system from scratch (thus fixing your problem — whatever it was).
