dcs3spp
Asus BT-400 Broadcom BCM20702A0 Bluetooth - Controller Not Found on Arch Linux ARM, kernel 4.14.32-1-ARCH
Sun Apr 08, 2018 5:49 pm
I have bluetooth dongle (Asus Bt-400 ) that I am using on a Raspberry Pi Model B (v1). I cannot seem to get bluetooth working. I am running kernel 4.14.32-1, with Arch Linux ARM installed. I am using Bluez 5.49. The bluetooth dongle is connected to a USB hub, LOGIK - L4THUB10. The details for the bluetooth usb dongle when I run lsusb is given as:
Bus 001 Device 006: ID 0b05:17cb ASUSTek Computer, Inc. Broadcom BCM20702A0 Bluetooth
When I run the following bluetoothctl commands no controller is found.
    bluetoothctl
    Agent registered
    [bluetooth]# agent on
    Agent is already registered
    [bluetooth]# default-agent
    Default agent request successful
    [bluetooth]# list
    [bluetooth]#
I have to shutdown the raspberry pi, power off the usb usb, power on again and hope that the controller device is recognised by bluetoothctl. Sometimes this works, sometimes it doesn't.
I have tried the following:
1. Installed the firmware file, BCM20702A1-0b05-17cb.hcd, for the device, available from community Arch Packages. This is installed at /usr/lib/firmware/brcm.
2. Downloaded the Asus windows driver and inspected the inf file to identify the correct hex driver file for the device. Subsequently I used hex2hcd for my device and installed the firmware file (BCM20702A1-0b05-17cb.hcd) at /usr/lib/firmware/brcm
3. Built bluez-utils-compat 5.49-1 from Arch community repository to test with deprecated bluetooth toolset.
When I run
dmesg | egrep -i 'blue|firm'
I get the following dmesg output....
    [    1.816784] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-03-16 16:17
    [   25.250290] Bluetooth: Core ver 2.22
    [   25.301799] Bluetooth: HCI device and connection manager initialized
    [   25.432350] Bluetooth: HCI socket layer initialized
    [   25.539945] Bluetooth: L2CAP socket layer initialized
    [   25.657534] Bluetooth: SCO socket layer initialized
    [   26.034466] Bluetooth: hci0: BCM: chip id 63
    [   26.138468] Bluetooth: hci0: BCM: features 0x07
    [   26.276530] Bluetooth: hci0: BCM20702A
    [   26.291533] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
    [   28.889841] Bluetooth: hci0 command 0xfc4c tx timeout
    [   36.230097] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   36.244019] Bluetooth: BNEP filters: protocol multicast
    [   36.470289] Bluetooth: BNEP socket layer initialized
    [   36.970529] Bluetooth: hci0: BCM: Patch command fc4c failed (-110)
    [   39.209790] Bluetooth: hci0 command 0x1001 tx timeout
    [   39.537967] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
    [   39.844410] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
    [   47.209794] Bluetooth: hci0: BCM: Reading local version info failed (-110)
Sometimes I also get the following...
    [    1.816785] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-03-16 16:17
    [   25.002668] Bluetooth: Core ver 2.22
    [   25.066306] Bluetooth: HCI device and connection manager initialized
    [   25.189457] Bluetooth: HCI socket layer initialized
    [   25.289129] Bluetooth: L2CAP socket layer initialized
    [   25.397880] Bluetooth: SCO socket layer initialized
    [   25.793880] Bluetooth: hci0: BCM: chip id 63
    [   27.908806] Bluetooth: hci0 command 0xfc6e tx timeout
    [   35.353127] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   35.353140] Bluetooth: BNEP filters: protocol multicast
    [   35.353177] Bluetooth: BNEP socket layer initialized
    [   36.329932] Bluetooth: hci0: BCM: Read controller features failed (-110)
    [   37.389283] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
    [   37.453147] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
When I plug the bluetooth dongle into the usb hub, many instances of the message below is logged. This only happens when I plug the bluetooth dongle into the USB hub. The hub is running other USB devices. The message is not logged when I remove the bluetooth device from the hub.
WARN::dwc_otg_handle_mode_mismatch_intr:68: Mode Mismatch Interrupt: currently in Host mode
I have also tried modifying the systemd bluetooth.service to be configured and run before the networking service as suggested at https://wiki.archlinux.org/index.php/Bl ... leshooting. Furthermore, if I run rfkill the device is listed as unblocked.
    sudo rfkill list
    [sudo] password for alarm:
    0: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
    1: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
Modules listed by lsmod are included below:
Module Size Used by
ccm 20480 3
bnep 20480 2
arc4 16384 2
rt2800usb 28672 0
rt2800lib 110592 1 rt2800usb
rt2x00usb 20480 1 rt2800usb
rt2x00lib 53248 3 rt2800lib,rt2800usb,rt2x00usb
mac80211 647168 3 rt2800lib,rt2x00lib,rt2x00usb
btusb 40960 0
btrtl 16384 1 btusb
btbcm 16384 1 btusb
btintel 16384 1 btusb
cfg80211 577536 2 rt2x00lib,mac80211
bluetooth 356352 12 btrtl,btintel,bnep,btbcm,btusb
crc_ccitt 16384 1 rt2800lib
ecdh_generic 28672 1 bluetooth
bcm2835_rng 16384 0
rng_core 16384 1 bcm2835_rng
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 16384 1 uio_pdrv_genirq
sch_fq_codel 20480 5
snd_bcm2835 32768 0
snd_pcm 94208 1 snd_bcm2835
snd_timer 32768 1 snd_pcm
snd 65536 3 snd_timer,snd_bcm2835,snd_pcm
crypto_user 16384 0
ip_tables 24576 0
x_tables 24576 1 ip_tables
ipv6 434176 40
Upon inspecting the code for the [btusb](https://github.com/raspberrypi/linux/bl ... th/btusb.c) driver I notice the following at lines 156-158:
    /* ASUSTek Computer - Broadcom based */
    { USB_VENDOR_AND_INTERFACE_INFO(0x0b05, 0xff, 0x01, 0x01),
    .driver_info = BTUSB_BCM_PATCHRAM },
There does not appear to be an individual usb device configuration for the bluetooth dongle, e.g.
{ USB_DEVICE(0x0b05, 0x17cb) }
Is this a bluetooth driver issue or an issue with usb hub driver?
Kind Regards
dcs3spp
dcs3spp
Re: Asus BT-400 Broadcom BCM20702A0 Bluetooth - Controller Not Found on Arch Linux ARM, kernel 4.14.32-1-ARCH
Mon Apr 09, 2018 11:56 am
Apologies for posting this response, I am new to this.....
Have just received an email notification that a response has been posted to this topic.
I have clicked the links in email and visited the topic, but cannot see the reply anywhere online. Would be interested to hear from you if you have any suggestions, regarding the bluetooth issue outlined in the post.....
Kind regards
dcs3spp
Mon Apr 09, 2018 12:08 pm
Kind regards
dcs3spp
The response was mine stating that yet again you have another live post, this was done as over the weekend there are usually less Moderators and to save volunteers trying to answer multiple identicle posts.
This morning a Moderator removed your duplicate post, so I removed my post as it was no longer relevant.
Multiple Posting is not welcome or needed and I believe this was you third
Anyway as you are not running Raspbian may I suggest you ask the Arch Community to help with your issue as well ??
Just to re-iterate we responders are ALL volunteers.
dcs3spp
Mon Apr 09, 2018 2:21 pm
Apologies for the duplicate posting.
Yes. Can confirm that have already posted to Arch Linux *ARM* community as well as the Arch forum on this site.
Apologies again.
dcs3spp
Tue Apr 10, 2018 10:09 am
For info, have also logged an issue at Raspberry Pi Kernel github site. The issue number is #2494 and link is https://github.com/raspberrypi/linux/issues/2494.
dcs3spp
Tue Apr 10, 2018 11:16 am
Some further information. For those running kernel 4.14.x on Arch, Raspian etc. this issue could occur. Please refer to https://github.com/raspberrypi/linux/issues/2408. It is suggested that an issue has been introduced with dwc_otg, with kernel 4.14.x versions. Going to try the tests listed in #2408.
Return to “Arch”
