MMBASIC Home Page - http://mmbasic.com
MMBASIC Overview - http://mmbasic.com/overview.html
The Back Shed - Raspberry Pi development and downloads
http://www.thebackshed.com/forum/forum_ ... PN=1&TPN=1
http://www.thebackshed.com/forum/forum_ ... p?TID=9487
http://www.thebackshed.com/forum/forum_ ... ?TID=10164
Astronomy, Aeronautics and Other MMBASIC Computer Programs
https://drive.google.com/open?id=0Bx2YP ... zUwQU5GUFk
Re: MMBASIC - A BASIC interpreter for the Raspberry Pi
On the one hand:
"MMBasic is a free and open BASIC interpreter for 32 bit microcontrollers."
On the other hand:
"The files may not be distributed or made available to others without specific written permission.
Object files (ie, .o, .exe, .hex files) generated using one or more of the source files (modified or not) are for personal use only and may not be distributed without written permission.
The files are provided without any warranty; without even the implied warranty of merchantability or fitness for a particular purpose."
So not "open" at all then.
Think I'll give it a miss thanks.
On the other hand:
Slava Ukrayini.
No ARM version, so this will not run on a PI unless you can obtain the source code and recompile it for the ARM.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
I do not see ARM or Raspberry Pi. But one can obtain the source code.DOS MMBasic Version (includes documentation)
PIC32-Generic MMBasic (includes documentation)
Maximite Version
DuinoMite Version
UBW32 Version
Micromite MkII
The RPF will not do this because this software is not open source or public license. There is nothing preventing an individual from downloading and compiling the source code to an executable format as long at that individual abides by and follows the agreed upon terms.
From the forum links: http://www.thebackshed.com/forum/upload ... mbasic.zipgkaiseril wrote: ↑Sun Apr 29, 2018 8:57 pmI do not see ARM or Raspberry Pi. But one can obtain the source code.DOS MMBasic Version (includes documentation)
Maximite Version
DuinoMite Version
UBW32 Version
Micromite MkII
(No, I haven't tried it, but it is ARM code and Pi is mentioned)
Thank you. This looks like fun. Unfortunately, on both a Zero W and a 3B+ (both running Stretch) all I get from running the 2018-01-12_224620_mmbasicstretch.zip binary is:
«timestamp» gpioTick: pigpio uninitialised, call gpioInitialise
pauses only to read manual …
- “In order for the firmware to work pigpio software version 64 must be installed …” — ah, it is, via the pigpio package
- “The firmware requires privileged access to the Pi hardware and so must be run using the sudo command sudo ./mmbasic” — eww, really? That's a bit 2014.
- “The Pi-cromite firmware sits in a tight loop polling for input and so will use 100% of one CPU. It is running at priority zero most of the time so the operating system is able to time-slice processor access. During time-sensitive I/O operations the priority will be raised and other processes locked out.” — aaaaiiiiiiiiiiiiiiiieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!111!!!!!!!!!!!! (FX; runs away screaming, optional Goons-style splosh indicating having run off the end of Canada)
‘Remember the Golden Rule of Selling: “Do not resort to violence.”’ — McGlashan.
Pronouns: he/him
Pronouns: he/him
