Shahriar Al Rabbi
"sudo ifup wlan0" shows "unknown interface wlan0"
Mon May 14, 2018 10:00 am
In the desktop, the internet connectivity logo, ethernet works fine but shows "no wireless device detected.
I installed the April 2018 raspbian stretch properly and still doesn't work.
If there is a solution, please let me know.
Or the product might have been damaged before it came to me.
"ifconfig" shows "eth0", "lo" as well as "wlan0" .
So, there might be a solution.
copperly
RE: "sudo ifup wlan0" shows "unknown interface wlan0"
Mon May 14, 2018 12:45 pm
I second that motion
mahjongg
Re: "sudo ifup wlan0" shows "unknown interface wlan0"
Mon May 14, 2018 12:52 pm
Split off from topic marked [SOLVED]
MrEngman
Mon May 14, 2018 1:39 pm
Try these
sudo ip link set wlan0 down
sudo ip link set wlan0 up
PeterO
Mon May 14, 2018 1:54 pm
Try running "ifconfig" to see
a) if the interfaces exist
b) What they are called.
PeterO
Interests: C,Python,PICO,Electronics,Ham Radio (G0DZB),1960s British Computers.
Cowpoke
Sun Jul 08, 2018 2:20 pm
Finally, are the ifup and ifdown commands obsolete?
SurferTim
Sun Jul 08, 2018 2:21 pm
Yes.
My advice applies to RaspiOS only. Please mention if you use another OS.
rohtua
Mon Jul 09, 2018 10:02 am
Hi, I had some similar problems a while ago on a fresh raspbian install I think what sorted it for me in the end was the Wi-Fi localisation options in raspi-config, when I looked I'd set the timezone options but now you get separate options for setting your Wi-Fi country. Might not do a lot but if I remember rightly it did help with the issues I was having at the time.
HermannSW
Fri Sep 07, 2018 2:56 pm
Try these
Thank you, that worked for me while ifup did not.
Pi ZeroW was connected to ESP-01s module access point. For some reason the connection dropped and "ip link show" showed wlan0 in DORMANT state. First I tried only your 2nd command, that did not help. But running both did work!
OutsourcedGuru
Wed Dec 18, 2019 9:26 pm
If both ifup and ifdown are now obsolete, you might consider removing their respective man pages and executables so that you don't fool someone like myself. As it is, the command is present and indicates:
ifup: unknown interface wlan0
...rather than the expected:
sudo: ifup: command not found
Wed Dec 18, 2019 9:48 pm
The proper way to do that would be to remove the ifupdown package. I'm not sure why it is still installed. Perhaps something in it is still required?
Unreadable squiggle
SageDesign
Thu May 14, 2020 3:48 pm
I am trying to build a cluster of 5 Pis, 3 x 3B+ and 2 x Pi4, using a SKY SR102 wireless router to connect them. Not going smoothly: the 3Bs are happy and connect, but the 2 x 4s will not connect, even though their setups appear to be identical. I cannot persuade them to connect, using ifup (?) or "set wlan0 up". They will occasionally connect, for no known reason. Any ideas please?
