seanspotatobusiness
Where are python libraries installed to?
Mon May 14, 2018 10:55 pm
When I use pip to install python libraries, where in the folder hierarchy do they go?
Raspberry Pi 3 B and B+
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
Paeryn
Re: Where are python libraries installed to?
Tue May 15, 2018 1:57 am
For a single user (i.e. not using sudo), usually in
~/.local/lib/python2.7
For system-wide (i.e. using sudo pip) then usually in
/usr/local/lib/python2.7
And for Python packages installed by apt then they usually go in
/usr/lib/python2.7
Normally Python then uses the sub-directory site-packages but Debian based installs (of which Raspbian is) use the sub-directory dist-packages.
So if you do
sudo pip install mylib
then mylib should end up in
/usr/local/lib/python2.7/dist-packages
For pip3 then substitute python2.7 with python3.5
seanspotatobusiness
Tue May 15, 2018 8:57 am
Perfect. Thanks very much!
VERSION_ID="10"
scotty101
Tue May 15, 2018 3:17 pm
A recent XKCD explains the python environment 'spaghetti' quite well
https://m.xkcd.com/1987/
n67
Tue May 15, 2018 3:27 pm
Excellent!
There's a lot to be said for the concept that when you create a new language, you should name it something different from previous (ancestral) languages.
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
Return to “Python”
