Jun 5 11:38:04 saeb-pi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Jun 5 11:38:08 saeb-pi dnsmasq[515]: dnsmasq: syntax check OK.
Jun 5 11:38:09 saeb-pi dnsmasq[530]: dnsmasq: failed to create listening socket for 172.24.1.1: Cannot assign requested address
Jun 5 11:38:09 saeb-pi dnsmasq[530]: failed to create listening socket for 172.24.1.1: Cannot assign requested address
Jun 5 11:38:09 saeb-pi systemd[1]: dnsmasq.service: Control process exited, code=exited status=2
Jun 5 11:38:09 saeb-pi dnsmasq[530]: FAILED to start up
Jun 5 11:38:09 saeb-pi systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Jun 5 11:38:09 saeb-pi systemd[1]: dnsmasq.service: Unit entered failed state.
Jun 5 11:38:09 saeb-pi systemd[1]: dnsmasq.service: Failed with result 'exit-code'.
Jun 5 11:40:20 saeb-pi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Jun 5 11:40:20 saeb-pi dnsmasq[537]: dnsmasq: syntax check OK.
Jun 5 11:40:20 saeb-pi dnsmasq[540]: dnsmasq: failed to create listening socket for 172.24.1.1: Cannot assign requested address
Jun 5 11:40:20 saeb-pi dnsmasq[540]: failed to create listening socket for 172.24.1.1: Cannot assign requested address
Jun 5 11:40:20 saeb-pi dnsmasq[540]: FAILED to start up
Jun 5 11:40:20 saeb-pi systemd[1]: dnsmasq.service: Control process exited, code=exited status=2
Jun 5 11:40:20 saeb-pi systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Jun 5 11:40:20 saeb-pi systemd[1]: dnsmasq.service: Unit entered failed state.
Jun 5 11:40:20 saeb-pi systemd[1]: dnsmasq.service: Failed with result 'exit-code'.
sudo service dnsmasq restart
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
cat /etc/hostapd/hostapd.conf
interface=wlan0
# Use the nl80211 driver with the brcmfmac driver
driver=nl80211
# This is the name of the network
ssid=Tor
# Use the 2.4GHz band
hw_mode=g
# Use channel 6
channel=6
# Enable 802.11n
ieee80211n=1
# Enable WMM
wmm_enabled=1
# Enable 40MHz channels with 20ns guard interval
ht_capab=[HT40][SHORT-GI-20][DSSS_CCK-40]
# Accept all MAC addresses
macaddr_acl=0
# Use WPA authentication
auth_algs=1
# Require clients to know the network name
ignore_broadcast_ssid=0
# Use WPA2
wpa=2
# Use a pre-shared key
wpa_key_mgmt=WPA-PSK
# The network passphrase
wpa_passphrase=1234567890-+
# Use AES, instead of TKIP
rsn_pairwise=CCMP
cat /etc/dnsmasq.conf
interface=wlan0 # Use interface wlan0
listen-address=172.24.1.1 # Explicitly specify the address to listen on
bind-interfaces # Bind to the interface to make sure we aren't sending things elsewhere
no-resolv
port=53
server=127.0.10.1 # Forward DNS requests to Google DNS
domain-needed # Don't forward short names
bogus-priv # Never forward addresses in the non-routed address spaces.
dhcp-range=172.24.1.50,172.24.1.150,12h # Assign IP addresses between 172.24.1.50 and 172.24.1.150 with a 12 hour lease time
My dhcpcd config:
cat /etc/dhcpcd.conf
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# Example static IP configuration:
interface wlan0
static ip_address=172.24.1.1/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
static routers=172.24.1.1
#static domain_name_servers=127.0.10.1 , 208.67.222.222
interface eth0
static ip_address=192.168.1.13/24
static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
# profile static_eth0
# static ip_address=192.168.1.23/24
# static routers=192.168.1.1
# static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
and my torrc :
Log notice file /var/log/tor/notices.log
VirtualAddrNetwork 10.192.0.0/10
AutomapHostsSuffixes .onion,.exit
AutomapHostsOnResolve 1
TransPort 9040
TransListenAddress 172.24.1.1
DNSPort 127.0.10.1:53
#DNSListenAddress 127.0.10.1
