Funguss3000
Send a file from my PC through LAN to a HDD connected to my Raspberry
Mon Jun 11, 2018 8:29 am
Hello!
I would like to know how to send files from my PC to the HDD I have connected to the Raspberry. I usually copy the file from the PC directly to the HDD connected via USB. But I know that it has to be possible to send files from PC to the HDD via LAN or something.
Thanks you!
Re: Send a file from my PC through LAN to a HDD connected to my Raspberry
Mon Jun 11, 2018 9:49 am
Get Samba/CIFS running on your Raspberry. Mount the Raspberry share on Windows (net use command or network neighbourhood). Write files to it. Job done.
There's a million and one tutorials for that on the internets.
thagrol
Mon Jun 11, 2018 7:14 pm
Or try scp, though you may have to enable ssh first.
One windows app that supports it (there are others) is winscp
JJL1
Tue Jun 12, 2018 8:05 pm
I did it with VNC Lots of tutorials for that too. Adafruit.com has lessons. I played with Rasbian light on PI 0. I'm pretty sure I sent files to it. I'm sure you could navigate to a HD that's mounted. It's been at least 6 months since I played with it. I definitely used VNC to do that in Win.
