Borner
raspi-config command line parameter
Tue Oct 30, 2012 7:27 pm
is there a way to use the raspi-config utility in an non-interactive mode? For example with command line parameters to set / enable some parameters.
I like to use the raspi-config in installation scripts.
Borner
Joe Schmoe
Re: raspi-config command line parameter
Tue Oct 30, 2012 7:40 pm
Borner wrote:Hi,
Borner
1) "raspi-config" is a shell script, so it is inspectable. I took a brief look through, and found...
2) It looks like there is some effort to making it command-line-drivable, but it didn't actually get implemented (yet). Take a look at the script (at the end) and you'll see what I mean.
3) If you really wanted to, you could probably drive it with Expect. That's what I always do in these sorts of situations.
bredman
Tue Oct 30, 2012 7:41 pm
Short answer: no this is not possible.
Long answer: raspi-config is just a script, so you can examine what it does when an option is selected. You can copy the relevant instructions into your installation script.
bamartin125
Wed Apr 05, 2017 2:46 am
I realize this is an old thread, but I wanted to share my recent success with calling particular routines out of raspi-config from the command line.
Essentially, I found that I could source the raspi-config script like so:
$ . raspi-config nonint
The 'nonint' argument there tells the script to run in non-interactive mode which looks like it allows the script to define all of its internal functions, but not actually run anything.
At this point, I can then call functions from inside the script. For example, to enable i2c I can run:
$ do_i2c 0
RichardBronosky
Thu May 11, 2017 2:21 am
This is still not documented anywhere, but the rc_gui tool (I'm assuming it would be a graphical user interface to the raspi-config if I were to ever install the full desktop) uses command line options to the raspi-config bash script. You can see the full list of options in the C source code https://github.com/raspberrypi-ui/rc_gu ... .c#L23-L70
/* Command strings */
#define GET_CAN_EXPAND  "sudo raspi-config nonint get_can_expand"
#define EXPAND_FS       "sudo raspi-config nonint do_expand_rootfs"
#define GET_HOSTNAME    "sudo raspi-config nonint get_hostname"
#define SET_HOSTNAME    "sudo raspi-config nonint do_hostname %s"
#define GET_BOOT_CLI    "sudo raspi-config nonint get_boot_cli"
#define GET_AUTOLOGIN   "sudo raspi-config nonint get_autologin"
#define SET_BOOT_CLI    "sudo raspi-config nonint do_boot_behaviour B1"
#define SET_BOOT_CLIA   "sudo raspi-config nonint do_boot_behaviour B2"
#define SET_BOOT_GUI    "sudo raspi-config nonint do_boot_behaviour B3"
#define SET_BOOT_GUIA   "sudo raspi-config nonint do_boot_behaviour B4"
#define GET_BOOT_WAIT   "sudo raspi-config nonint get_boot_wait"
#define SET_BOOT_WAIT   "sudo raspi-config nonint do_boot_wait %d"
#define GET_SPLASH      "sudo raspi-config nonint get_boot_splash"
#define SET_SPLASH      "sudo raspi-config nonint do_boot_splash %d"
#define GET_OVERSCAN    "sudo raspi-config nonint get_overscan"
#define SET_OVERSCAN    "sudo raspi-config nonint do_overscan %d"
#define GET_CAMERA      "sudo raspi-config nonint get_camera"
#define SET_CAMERA      "sudo raspi-config nonint do_camera %d"
#define GET_SSH         "sudo raspi-config nonint get_ssh"
#define SET_SSH         "sudo raspi-config nonint do_ssh %d"
#define GET_VNC         "sudo raspi-config nonint get_vnc"
#define SET_VNC         "sudo raspi-config nonint do_vnc %d"
#define GET_SPI         "sudo raspi-config nonint get_spi"
#define SET_SPI         "sudo raspi-config nonint do_spi %d"
#define GET_I2C         "sudo raspi-config nonint get_i2c"
#define SET_I2C         "sudo raspi-config nonint do_i2c %d"
#define GET_SERIAL      "sudo raspi-config nonint get_serial"
#define GET_SERIALHW    "sudo raspi-config nonint get_serial_hw"
#define SET_SERIAL      "sudo raspi-config nonint do_serial %d"
#define GET_1WIRE       "sudo raspi-config nonint get_onewire"
#define SET_1WIRE       "sudo raspi-config nonint do_onewire %d"
#define GET_RGPIO       "sudo raspi-config nonint get_rgpio"
#define SET_RGPIO       "sudo raspi-config nonint do_rgpio %d"
#define GET_PI_TYPE     "sudo raspi-config nonint get_pi_type"
#define GET_OVERCLOCK   "sudo raspi-config nonint get_config_var arm_freq /boot/config.txt"
#define SET_OVERCLOCK   "sudo raspi-config nonint do_overclock %s"
#define GET_GPU_MEM     "sudo raspi-config nonint get_config_var gpu_mem /boot/config.txt"
#define GET_GPU_MEM_256 "sudo raspi-config nonint get_config_var gpu_mem_256 /boot/config.txt"
#define GET_GPU_MEM_512 "sudo raspi-config nonint get_config_var gpu_mem_512 /boot/config.txt"
#define GET_GPU_MEM_1K  "sudo raspi-config nonint get_config_var gpu_mem_1024 /boot/config.txt"
#define SET_GPU_MEM     "sudo raspi-config nonint do_memory_split %d"
#define GET_HDMI_GROUP  "sudo raspi-config nonint get_config_var hdmi_group /boot/config.txt"
#define GET_HDMI_MODE   "sudo raspi-config nonint get_config_var hdmi_mode /boot/config.txt"
#define SET_HDMI_GP_MOD "sudo raspi-config nonint do_resolution %d %d"
#define GET_WIFI_CTRY   "sudo raspi-config nonint get_wifi_country"
#define SET_WIFI_CTRY   "sudo raspi-config nonint do_wifi_country %s"
#define CHANGE_PASSWD   "(echo \"%s\" ; echo \"%s\" ; echo \"%s\") | passwd"
-- Bruno Bronosky
1x RPi 1 (B)
1x RPi 1+ (B)
2x RPi 2
11x RPi 3
4x RPi Zero W
2x RPi camera module
3x AIY Voice kits
https://github.com/RichardBronosky/pi-gen-extender
https://github.com/RichardBronosky/raspbian-boot-setup
mrmuu
Fri Aug 02, 2019 9:16 am
Thank you very much @RichardBronosky!
this is realy usefull for automating Image builds :D
Daddyfix
Mon Mar 30, 2020 9:13 pm
Raspberry Pi raspi-config cli Commands
Find raspi-config source here
https://github.com/RPi-Distro/raspi-con ... spi-config
# 1|0 -> 1=false/off 0=true/on
raspi-config nonint do_hostname "yourhostname"
raspi-config nonint do_boot_wait 1|0
raspi-config nonint do_boot_splash 1|0
raspi-config nonint do_overscan 1|0
raspi-config nonint get_pixdub
raspi-config nonint do_pixdub 1|0
raspi-config nonint do_camera 1|0
raspi-config nonint do_ssh 1|0
raspi-config nonint do_vnc 1|0
raspi-config nonint do_spi 1|0
raspi-config nonint do_i2c 1|0
raspi-config nonint do_serial 1|0
raspi-config nonint do_onewire 1|0
raspi-config nonint do_rgpio 1|0
raspi-config nonint get_blanking
raspi-config nonint do_blanking 1|0
raspi-config nonint is_pi
raspi-config nonint is_pifour
raspi-config nonint is_fkms
raspi-config nonint do_overclock None|Modest|Medium|High|Turbo
raspi-config nonint do_memory_split 16|32|64|128|256
# find wifi countries here /usr/share/zoneinfo/iso3166.tab
raspi-config nonint do_wifi_country "yourcountry"
raspi-config nonint do_pi4video V1
raspi-config nonint do_pi4video V2
raspi-config nonint do_pi4video V3
raspi-config nonint get_pi4video
raspi-config nonint get_overlay_now
raspi-config nonint get_overlay_conf
raspi-config nonint get_bootro_conf
raspi-config nonint enable_overlayfs
raspi-config nonint disable_overlayfs
raspi-config nonint enable_bootro
raspi-config nonint disable_bootro
raspi-config nonint is_uname_current
raspi-config nonint list_wlan_interfaces
raspi-config nonint is_installed realvnc-vnc-server
raspi-config nonint is_installed xscreensaver
vcgencmd get_mem gpu | cut -d = -f 2 | cut -d M -f 1
echo \"$SUDO_USER:%s\" | chpasswd
MaccyC
Mon Jun 01, 2020 1:14 am
$ do_i2c 0
Like it. Thank you.
