Alexmilk
Open a fullscreen terminal window at start
Fri Jun 22, 2018 9:56 am
Hi!
I try to open a fullscreen terminal window at start. (should be simple no? :? )
I am new in raspberry, but I have a python file that use Lxterminal window as visualization.
> /home/pi/morse/code/morse.py
I can not open it from this command line:
sudo python /home/pi/morse/code/morse.py
So I created a command file that open it (not in fullscreen...anyway :roll: ) : startup.sh
#! /bin/bash
cd /home/pi/morse/code
 ./morse.py
And then I tried to call it at start from /etc/rc.local: (before the IP adress)
sudo bash /etc/startup.sh
It was not working
So I tried with Crontab method. I put this code line inside:
@reboot ( sleep 90 ; bash /etc/startup.sh )
It was also not working
If you have an idea of what kind of stupid mistake I did!
Thank you :D
Best,
Alex
topguy
Re: Open a fullscreen terminal window at start
Fri Jun 22, 2018 1:40 pm
Probably safer to use LXDE own autostart featur.
A bit old this thread so you may want to look for a newer guide, but this should give you the keywords to search for.
viewtopic.php?p=1001600
Alexmilk
Tue Jun 26, 2018 1:46 pm
Thank you very much topguy, this really help me !
I found this solution:
lxTerminal
$ sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
#add this at the end
#for running a python program:
@lxterminal -e python /home/pi/morse_code.py
#for running a command:
@lxterminal --command /bin/bash --init-file /home/pi/startup.sh
