Chandru42
Power on / off button for Pi
Thu Jul 05, 2018 7:57 am
Hello everyone,
I came across many articles to make a simple power on 7 off button for raspberry pi by connecting GPIO 3 and ground.
https://scribles.net/adding-power-switc ... pberry-pi/
https://howchoo.com/g/mwnlytk3zmm/how-t ... spberry-pi
I have also tried this and it works very well. But the problem is i am also using Adafruit ADS1015 analog to digital converter in my circuit which uses the GPIO 3(scl) for establishing i2c connection. It is not working when both are connected together.
i would like to know is is possible to use other GPIO pin to make this both working ? Or is there any other solution available?
wolf.z
Re: Power on / off button for Pi
Thu Jul 05, 2018 11:10 am
This issue has been discussed many times. The "off" functionality is easily moved to anther GPIO pin. It is controlled by a script as from linked example. The wakeup functionality is controlled by a binary system file. So pin5 appears to carry a hardwired function in means of wakeup (unless someone changes that file?)
The functionality you are using is not a true on/off. Rather, the Pi starts to boot after a halt command until the point waiting for pin5 to get enabled in a low power state. If depowered-repowered, the Pi will not wait for Pin5 enabled.
Thus, you could change to the situation
- halt-by-pushbutton on any GPIO
- boot by depower-repower.
Both actions on one pin is stuck to pin5.
klricks
Thu Jul 05, 2018 12:45 pm
You can make a shutdown button without the need for a running script by adding this to /boot/config.txt:
dtoverlay=gpio-shutdown
The default pin for the above is pin 5 (GPIO3).
If you plan to use I2C then you will need to change the shutdown pin to something else.
For example to change the shutdown pin from the default GPIO 3 to GPIO 26 (physical pin 37), add this to /boot/config.txt
dtoverlay=gpio-shutdown,gpio_pin=26
However you can't change the startup pin from GPIO 3 (physical pin 5). That always works regardless.
So changing from default will require 2 buttons.
Or you can use the RUN header to start.
Chandru42
Fri Jul 06, 2018 10:38 am
Thank you somuch.This helps me a lot. Also , Do you have any idea of how to power on the raspberry pi using a switch or button without removing the power supply and connecting it every time?
klricks
Fri Jul 06, 2018 12:08 pm
.... Also , Do you have any idea of how to power on the raspberry pi using a switch or button without removing the power supply and connecting it every time?
Use a multi outlet power strip with a power button.
Chandru42
Fri Jul 06, 2018 1:37 pm
Thank you!
Gautamk
Fri Jul 06, 2018 7:54 pm
Hello, i am using RPi Zero W but i don't know which GPIO pin i use for shutdown and power on functions can you please guide me?
petrockblog
Mon Nov 11, 2019 10:02 pm
The PowerBlock (powerblock.petrockblock.com) or the PowerBlockling (https://petrockblock.com/powerblockling) also might be just what you are looking for.
fun stuff for technics enthusiasts: www.petrockblock.com
Bope
Mon Nov 11, 2019 11:15 pm
Isn’t that powerblocking button still using GPIO 3?
Gautama, everything in this thread also pertains to your pi zero. Using the GPIO pins does not actually power up/down your pi, it just puts it in standby mode. To actually shutdown your pi go to the menu and select shutdown. When complete unplug the power supply. To boot plug the power supply back in.
Imperf3kt
Mon Nov 11, 2019 11:35 pm
Thank you!
Any reason to not simply momentarily short RUN to GND?
Your regular x86 PC works the same way, turning it off doesn't actually turn it off and shorting a certain pin to ground wakes the PC from its halt state.
55:55:44:44:4C
52:4C:52:42:41
Tue Nov 12, 2019 9:16 am
If the gpio_poweroff option is set, then shorting GPIO3 (pin 5) to ground/0V is exactly the same as the shutdown command. Both shutdown the OS and go into a low-power halt state.
To restart from that state you can disconnect/reconnect the power, connect the RUN connection to ground/0V or short GPIO3 to ground/0V again (on the Pi 4 you'll need to enable an option in the boot eeprom code to do that).
Unreadable squiggle
deepo
Tue Nov 12, 2019 10:03 am
gpio_poweroff is not what you think:
http://www.embeddedpi.com/documentation ... -gpio-line
Info:   Drives a GPIO high or low on poweroff (including halt)
Load:   dtoverlay=gpio-poweroff,=
Params: gpiopin                 GPIO for signalling (default 26)
        active_low              Set if the power control device requires a
                                high->low transition to trigger a power-down.
                                Note that this will require the support of a
                                custom dt-blob.bin to prevent a power-down
                                during the boot process, and that a reboot
                                will also cause the pin to go low.
/Mogens
Tue Nov 12, 2019 10:49 am
Apologies. I got the wrong option.
gpio-shutdown is the one I was thinking of.
Unreadable squiggle
alphanumeric
Tue Nov 12, 2019 12:46 pm
For me on my Pi 4B, if I enable i2c and reboot the dtoverlay=gpio-shutdown stops working. Pressing my button does nothing. Disable it and reboot and its working again. It still boots up when GPIO 3 in grounded.
alphanumeric
Tue Nov 12, 2019 1:02 pm
If I want to set an alternate GPIO say physical pin 11 is it as follows?
dtoverlay=gpio-shutdown,gpio_pin=11
And do I have to also set the pullup etc?
dtoverlay=gpio-shutdown,gpio_pin=11,active_low=1,gpio_pull=up
EDIT: neither one of the above works? I have i2c turned off again.
I have a fan shim which has a button wired to BCM 17 physical pin 11.
https://pinout.xyz/pinout/fan_shim#
EDIT: 2 dtoverlay=gpio-shutdown works with the fan shim button via GPIO 3 no problem. Until I enable i2c, which is an interface I use a quit often.
deepo
Tue Nov 12, 2019 5:18 pm
gpio_pin is actually not referring to pin numbers, but GPIO numbers (BCM numbers). Pin 11 is GPIO17, so try with gpio_pin=17
/Mogens
alphanumeric
Tue Nov 12, 2019 7:09 pm
Thanks for that,
dtoverlay=gpio-shutdown,gpio_pin=17,active_low=1,gpio_pull=up
worked. :D
Even works if i2c is enabled which is what I wanted. :D
I could have sworn I had tried that but I guess I didn't? Or I made a typo? Sorted now though.
danduran31
Tue Dec 10, 2019 1:59 pm
alphanumeric:
Could you please send the exact complete code using GPIO17 for the button. Im using 12C on my raspberry too.
alphanumeric
Tue Dec 10, 2019 8:27 pm
Open a terminal window and run the following
sudo nano /boot/config.txt
Then add the following line.
ctrl + x, y enter, and reboot, done deal.
JeffZ123
Tue Dec 17, 2019 3:30 pm
Confirmed this solution is working for me as well with one switch for wake/halt and an IC2 display.
Enabling the display no longer shuts down the pi :P
caramabby
Thu Oct 15, 2020 9:46 am
Hi! I want to try this, because im using also the I2C channels for an Imu and a touch sensor, but I dont understand what have you done...you are using the SDA or the GPIO17.
I want to use it for on/off button and the SDA and SCL for the other components.
Can someone explain this again.
Thank you so much
alphanumeric
Thu Oct 15, 2020 11:16 am
Is shutdown only, via a ground (low), being applied to GPIO 17 (BCM number).
You can change the 17 to another GPIO. You can use active high too etc.
I used GPIO 17 because that pin is grounded by the button on the Pimoroni Fan Shim, when its pressed.
That same button also grounds GPIO 3 when pressed, that does the Boot Up part for me. The GPIO 3 boot up works regardless of whether i2c is enabled or not.
caramabby
Thu Oct 15, 2020 4:07 pm
Ok I made that
I connect the button to gpio 17 and GND, and when i push it it doesnt work, it didnt do anything, do you know what's possibly happen?
thank you!
caramabby
Thu Oct 15, 2020 4:17 pm
I dont understand how i connect it with GPIO3... sorry to not understand it :(
alphanumeric
Thu Oct 15, 2020 6:19 pm
For clarification, the edit is done to config.txt, and you have to reboot at least once after doing it.
And its GPIO 17, physical pin 11.
For the boot up to work via GPIO 3, physical pin 5. The Pi is shutdown but left powered up.
What are you using for a switch, and how have you got it wired?
Ideally you want a normally open, momentary contact switch. When pressed its two contacts are shorted together, and when released its an open circuit.
