** Find Instructions and downloads on GitHub under the GPL3 **
Direct download for latest Debian (.deb) installer
Turn 2x Raspberry Pis into Network Testers with Kootnet Network Testers. MTR & iPerf3 are used between the 2 units to test latency & throughput on individual cables or network routes.
Use E-Ink display and buttons OR the built-in web interface to operate.
Note: I recommend using the Raspberry Pi 4 due to its 1GB Network adapter
Note: The Raspberry Pi 3B+ can't test bandwidth higher than 300Mbps, HOWEVER, bad cables and routes usually still show as irregular results
Hardware
2x Raspberry Pi's /w Ethernet Connection *Required
1x 2.7" E-Ink display with 4 buttons (WaveShare) *Optional
With the WaveShare 2.7" E-Ink Display, you can use the 4 built-in buttons to operate the device.
The 4th button changes what the first 3 buttons do. When the 4th button is pressed, it will display a message describing what each button does. There are currently 3 "Levels" you can switch between with the 4th button, which are as follows.
Primary Button Functions
1. Run & Display MTR tests
2. Run & Display iPerf3 tests
3. Nothing (WIP)
4. Change Button Functions
Secondary Button Functions
1. System Information
2. Upgrade Kootnet Ethernet Tester Software
3. Upgrade Kootnet Ethernet Tester Software Developmental
Tertiary Button Functions
1. Shutdown Remote Test Server
2. Shutdown Local Unit
3. Nothing (WIP)
Note: Each button displays a message before and after they do something, so you know if it's working
Kootnet Network Tester Pictures
Web Portal
WaveShare 2.7" E-Ink Display + Buttons
