EasyComp Zeeland
How to open navit from kodi?
Tue Jul 24, 2018 10:13 am
Hi there,
as I mentioned before in previous posts, I'm building a CarPI on Raspbian using Kodi and Navit;
as theme for kodi I use carpi, which has a navigation button to open navit from kodi, but what code do I need to insert to make it work and overlay kodi in the button it's settings?
It works fine but thats the last step!
Rascas
Re: How to open navit from kodi?
Tue Jul 24, 2018 2:28 pm
Where did you download that skin? If it has a button to open Navit, I think it is better to ask directly to the respective skin developer.
EasyComp Zeeland
Tue Jul 24, 2018 4:21 pm
just downloaded it somewhere from the internet. From someone who isn't the developer.
EasyComp Zeeland
Thu Jul 26, 2018 11:56 am
Still waiting for an answer?
topguy
Fri Jul 27, 2018 2:06 pm
I'm not even sure how to read this sentence correctly.. can you expand a bit about exactly what setting you are talking about and what you mean with "code"..
Refering us to another (unlinked) thread for background info is not that polite either..
EasyComp Zeeland
Sun Jul 29, 2018 8:57 am
I forgot to paste that url but I meant this post; viewtopic.php?f=73&t=217472&p=1346519#p1346519
here is some more info about the sentence you didn't quite get
What do I need to insert here (video) to make Navit run?!
https://easycompzeeland.nl/site/assets/ ... .53.49.mp4
topguy
Mon Jul 30, 2018 12:43 pm
Have you installed "navit" on the Pi ?
EasyComp Zeeland
Mon Jul 30, 2018 3:59 pm
Yes and it works fine! but just doesn't open from kodi.
topguy
Tue Jul 31, 2018 1:48 pm
How would you start "navit" outside of Kodi ?
In a terminal if you write the command "which navit" you will probably get the response "/usr/bin/navit" or something similar which is the full path to the "navit" executable. You might try to enter that full path into the field in Kodi.
EasyComp Zeeland
Thu Aug 02, 2018 2:49 pm
I already tried that method but it doesn't work...
Rascas
Thu Aug 02, 2018 10:50 pm
Like I said above, I am not familiar with that skin and navit but I am pretty sure that you cannot run any other graphical program on the RPi while Kodi is running. Well, you can start it, but you will only see it when you exit Kodi.
So the script you are looking for must:
1- Exit Kodi
2- Start Navit
3- Start Kodi again when you exit Navit
If you contact the skin developer, he probably has or knows some script for that.
EasyComp Zeeland
Sat Aug 04, 2018 2:41 pm
Now I've created;
import os
import xbmc
#activate GPS USB Dongle
os.system("sudo systemctl stop gpsd.socket")
os.system("sudo systemctl disable gpsd.socket")
os.system("sudo gpsd /dev/ttyUSB0 -F /var/run/gpsd.sock")
#open navit
os.system("navit")
It works although how to minimize kodi so navit can be on top of it?
DirkS
Sat Aug 04, 2018 3:46 pm
Well, that's the problem as Rascas already identified.
Video output of Kodi on the Pi uses hardware acceleration and output is sent (more or less) directly to the hardware; it bypasses the framebuffer.
There's nothing to minimize. You would have to quit Kodi or maybe it's possible to 'switch off' Kodi output.
Rascas
Sat Aug 04, 2018 4:33 pm
Now I've created;
import os
import xbmc
#open navit
os.system("navit")
You can't minimize Kodi, it is rendered in an overlay on the framebuffer. You have to close it and open it again when you exit navit.
EasyComp Zeeland
Sat Aug 04, 2018 5:34 pm
Now I've created;
import os
import xbmc
#open navit
os.system("navit")
Hmm, wondering if there is a workaround!
Rascas
Sun Aug 05, 2018 2:33 am
Try this:
-Create a bash script with the following:
#!/bin/bash
sudo killall -9 kodi.bin
navit
kodi &
-Change the last line of your python script by this:
os.system("bash /path/to/the/script/scriptname")
Other solution would be to compile Kodi yourself with support for X server and OpenGL, but it will be much slower and without video decoding acceleration.
EasyComp Zeeland
Sun Aug 05, 2018 6:50 pm
Try this:
#!/bin/bash
navit
kodi &
I created this now it seems to do something at least, it doesn't kill kodi but It suddenly restarts kodi when I'll exit navit, I can control navit from vnc ;) not from my 7" pi screen which got kodi on it.
import os
import xbmc
#activate GPS dongle
os.system("bash /home/pi/.kodi/addons/skin.CarPc-Carbon/scripts/ActiveerGPS.sh")
#run navit
os.system("navit")
#kill kodi and comeback when navit gets killed
os.system("bash /home/pi/.kodi/addons/skin.CarPc-Carbon/scripts/minimizekodi.sh")
Main .py script
Code to activate GPS dongle - ActiveerGPS.sh
#!/bin/bash
navit
kodi &
Kill kodi and comeback script - Minimizekodi.sh
Rascas
Sun Aug 05, 2018 7:53 pm
If it is a RPi 2 or 3, it is:
sudo killall kodi_v7.bin
EasyComp Zeeland
Mon Aug 06, 2018 9:52 am
it seems completely ignored, kodi doesn't get killed..
Rascas
Mon Aug 06, 2018 10:06 am
Check the processes running with top or something. I can kill Kodi here just fine via ssh with that.
EasyComp Zeeland
Mon Aug 06, 2018 11:25 am
Well I can kill it with ssh as well but the script doesn't seem to work..
EasyComp Zeeland
Mon Aug 13, 2018 5:27 pm
Any Response please?
Rascas
Mon Aug 13, 2018 5:47 pm
Try without -9, try to debug that by yourself, add some echos/printfs to a file, on both python and bash scripts, try to launch navit first and kill kodi after, I don't know... You already know what you have to do, try different approaches to do the same.
Rojit K Johncy
Sat Oct 13, 2018 6:03 pm
Try this:
#!/bin/bash
navit
kodi &
import os
import xbmc
#run navit
os.system("navit")
Main .py script
#!/bin/bash
navit
kodi &
I am very new to Raspberry Pi and Kodi. I need your help in getting called Navit from Kodi. Can you please provide step by step procedure how to call Navit from Kodi? The python script works fine from RPi terminal but i dont understand how i should call Navit from Kodi.. Need your help plss..
