skathi
PPM signal creating
Thu Aug 02, 2018 9:18 am
Hey, I'm new Raspberry Pi user, and I'm trying to write software PPM signal code(python), but I've got some problems. How can I separate channels one pack from another ? Is there any protocols for single channel duration? Does anybody have any PPM signal modulation code example?
P.S. Thank you in advance)
P.S.S Sorry for my bad English
drgeoff
Re: PPM signal creating
Thu Aug 02, 2018 1:47 pm
What is PPM? Peak Programme Meter?
scotty101
Thu Aug 02, 2018 3:40 pm
I think the most likely meaning of PPM is Pulse Position Modulation.
Often used with Servos and RC control applications.
skathi, you are going to have to provide a bit more information. What are you trying to interface with? Are you sending or recieving a PPM signal?
From my time doing stuff with quadcopters, i remember some C code to separate the 8 channels of data from each other in the Ardupilot source code.
skathi
Fri Aug 31, 2018 12:22 pm
thank you very much for your reply, but I've already modulated it.
PPM is Pulse Position Modulation. It's for sending signal to my pixracer.
joan
Fri Aug 31, 2018 1:30 pm
Here is a pigpio Python script to generate PPM.
#!/usr/bin/env python
# PPM.py
# 2016-02-18
# Public Domain
import time
import pigpio
class X:
   GAP=100
   WAVES=3
   def __init__(self, pi, gpio, channels=8, frame_ms=27):
      self.pi = pi
      self.gpio = gpio
      if frame_ms < 5:
         frame_ms = 5
         channels = 2
      elif frame_ms > 100:
         frame_ms = 100
      self.frame_ms = frame_ms
      self._frame_us = int(frame_ms * 1000)
      self._frame_secs = frame_ms / 1000.0
      if channels < 1:
         channels = 1
      elif channels > (frame_ms // 2):
         channels = int(frame_ms // 2)
      self.channels = channels
      self._widths = [1000] * channels # set each channel to minimum pulse width
      self._wid = [None]*self.WAVES
      self._next_wid = 0
      pi.write(gpio, pigpio.LOW)
      self._update_time = time.time()
   def _update(self):
      wf =[]
      micros = 0
      for i in self._widths:
         wf.append(pigpio.pulse(0, 1<<self.gpio, self.GAP))
         wf.append(pigpio.pulse(1<<self.gpio, 0, i))
         micros += (i+self.GAP)
      # off for the remaining frame period
      wf.append(pigpio.pulse(0, 1<<self.gpio, self._frame_us-micros))
      self.pi.wave_add_generic(wf)
      wid = self.pi.wave_create()
      self.pi.wave_send_using_mode(wid, pigpio.WAVE_MODE_REPEAT_SYNC)
      self._wid[self._next_wid] = wid
      self._next_wid += 1
      if self._next_wid >= self.WAVES:
         self._next_wid = 0
      remaining = self._update_time + self._frame_secs - time.time()
      if remaining > 0:
         time.sleep(remaining)
      wid = self._wid[self._next_wid]
      if wid is not None:
         self.pi.wave_delete(wid)
         self._wid[self._next_wid] = None
   def update_channel(self, channel, width):
      self._widths[channel] = width
      self._update()
   def update_channels(self, widths):
      self._widths[0:len(widths)] = widths[0:self.channels]
      self._update()
   def cancel(self):
      self.pi.wave_tx_stop()
      for i in self._wid:
         if i is not None:
            self.pi.wave_delete(i)
if __name__ == "__main__":
   import time
   import PPM
   import pigpio
   pi = pigpio.pi()
   if not pi.connected:
      exit(0)
   pi.wave_tx_stop() # Start with a clean slate.
   ppm = PPM.X(pi, 6, frame_ms=20)
   updates = 0
   start = time.time()
   for chan in range(8):
      for pw in range(1000, 2000, 5):
         ppm.update_channel(chan, pw)
         updates += 1
   end = time.time()
   secs = end - start
   print("{} updates in {:.1f} seconds ({}/s)".format(updates, secs, int(updates/secs)))
   ppm.update_channels([1000, 2000, 1000, 2000, 1000, 2000, 1000, 2000])
   time.sleep(2)
   ppm.cancel()
   pi.stop()
skathi
Fri Aug 31, 2018 1:56 pm
thank you very much
bem22
Fri Nov 01, 2019 9:24 pm
Is there a way to do this in C?
Gavinmc42
Sat Nov 02, 2019 12:57 am
I'm dancing on Rainbows.
bem22
Sun Nov 10, 2019 4:18 pm
Does anyone have any experience with worked examples for generating PPM on raspberry pi using the pigpio library written by joan, please? I've hit a dead end with this.
joan
Sun Nov 10, 2019 8:17 pm
http://abyz.me.uk/rpi/pigpio/examples.h ... ode/PPM.py shows how to use Python to generate PPM on a GPIO.
You will need to translate the Python to C. That should not be too difficult as there is a direct mapping from the Python pigpio calls to the C pigpio calls. I don't expect that the translation will be difficult to anyone with a reasonable level of C experience.
bem22
Thu Nov 14, 2019 12:57 pm
@joan, I tried to reach you in different ways for this problem. I am struggling to understand the code because there are no comments and I can't inherit any functionality from how the library is written.
Some variables are not self-explanatory, such as class X in the example above.
I am willing to create multiple examples for C and C++ and contribute to your repository if you help me a little bit with this.
bem22
Wed Jan 08, 2020 3:33 pm
Here's an update about this post. I followed joan's guidance and I almost managed to translate the python to C.
#include "ppmer.h"
#include <pigpio.h>
#include <sys/time.h>
#include <malloc.h>
#include <asm/errno.h>
#include <errno.h>
#include <zconf.h>
#include <string.h>
int microsleep(long tms)
    struct timespec ts;
    int ret;
    if (tms < 0)
        errno = EINVAL;
        return -1;
    ts.tv_sec = tms / 1000;
    ts.tv_nsec = tms * 1000;
    do {
        ret = nanosleep(&ts, &ts);
    } while (ret && errno == EINTR);
    return ret;
int init(unsigned int gpio, int channels, int frame_ms) {
    GAP = 300;
    NO_WAVES = 3;
    if (gpioInitialise() < 0) return 0;
    // Initialize all the variables in the PPM encoder structure
    ppm_factory.gpio = gpio;
    ppm_factory.channel_count = channels;
    ppm_factory.frame_ms = frame_ms;
    ppm_factory.frame_us = frame_ms * 1000;
    ppm_factory.frame_s = frame_ms / 1000;
    ppm_factory.widths = malloc(sizeof(int) * 8);
    for(int i=0; i<3; i++) {
        ppm_factory.waves[i] = malloc(6 * (channels + 1) * sizeof(gpioPulse_t));
    // Set the pulse width of each channel to 1000
    for(int i=0; i<channels; i++) {
        ppm_factory.widths[i] = 1000;
    // Set the wave ids to control value
    for(int i=0; i<NO_WAVES; i++) {
        ppm_factory.wave_ids[i] = -1;
    // Set wave id counter
    ppm_factory.next_wave_id = 0;
    // Set GPIO pin to ground
    gpioWrite(gpio, PI_LOW);
    // Set the update time
    gettimeofday(&ppm_factory.update_time, NULL);
    return 0;
void update() {
    uint32_t  micros = 0;
    int i, wave_id;
    struct timeval remaining_time;
    // Set the first channel_count * 2 elements in the wave pulse (i.e lows and highs)
    for(i=0; i < ppm_factory.channel_count*2; i+=2) {
        ppm_factory.waves[ppm_factory.next_wave_id][i] = (gpioPulse_t){1u << ppm_factory.gpio, 0, GAP};
        ppm_factory.waves[ppm_factory.next_wave_id][i+1] = (gpioPulse_t){0, 1u << ppm_factory.gpio, ppm_factory.widths[i/2] - GAP};
        micros+=ppm_factory.widths[i];
    // Fill with ground for the remaining time of the frame
    micros+=GAP;
    ppm_factory.waves[ppm_factory.next_wave_id][++i] =
            (gpioPulse_t){0, 1u << ppm_factory.gpio, ppm_factory.frame_us - micros};
    // Create the wave
    gpioWaveAddGeneric(i, ppm_factory.waves[ppm_factory.next_wave_id]);
    wave_id = gpioWaveCreate();
    // Send the wave to the wire
    gpioWaveTxSend(wave_id, PI_WAVE_MODE_REPEAT_SYNC);
    // Save the wave id in the array and increment the counter
    ppm_factory.wave_ids[ppm_factory.next_wave_id++] = wave_id;
    // Reset the counter when it reaches NO_WAVES
    if(ppm_factory.next_wave_id >= NO_WAVES) { ppm_factory.next_wave_id = -1; }
    struct timeval current_time;
    gettimeofday(&current_time, NULL);
    remaining_time.tv_sec = ppm_factory.update_time.tv_sec + ppm_factory.frame_s - current_time.tv_sec;
    remaining_time.tv_usec = ppm_factory.update_time.tv_usec + ppm_factory.frame_us - current_time.tv_usec;
    // Sleep for the remaining time
    if(remaining_time.tv_usec > 0) {
        gpioDelay(remaining_time.tv_usec);
    // Update the timer
    // Get next wave_id
    wave_id = ppm_factory.wave_ids[ppm_factory.next_wave_id];
    // Delete the next wave (by id) and clear the wave_id in the wave reference array
    if(wave_id != -1) {
        gpioWaveDelete(wave_id);
        ppm_factory.wave_ids[ppm_factory.next_wave_id] = -1;
        memset(ppm_factory.waves[ppm_factory.next_wave_id], 0 , (ppm_factory.channel_count + 1) * 2);
void update_channel(unsigned int channel, unsigned int width) {
    ppm_factory.widths[channel] = width;
    update();
void update_channels(unsigned int *widths) {
    ppm_factory.widths = widths;
    update();
void destroy() {
    // Stop the current wave
    gpioWaveTxStop();
    // Clean all waves and wave_ids
    for(int i=0; i < NO_WAVES; i++) {
        if (ppm_factory.wave_ids[i] != -1) {
            gpioWaveDelete(ppm_factory.wave_ids[i]);
    gpioTerminate();
#include <time.h>
#include <bits/types/struct_timeval.h>
#include <pigpio.h>
#ifndef SERVER_PPMER_H
#define SERVER_PPMER_H
short GAP;
short NO_WAVES;
typedef struct encoder_struct {
    int channel_count;
    unsigned int gpio;
    int frame_ms;
    int frame_us;
    int frame_s;
    int next_wave_id;
    struct timeval update_time;
    int wave_ids[3];
    gpioPulse_t *waves[3];
    unsigned int *widths;
} encoderStructy;
struct encoder_struct ppm_factory;
int init(unsigned int gpio, int channels, int frame_ms);
void update();
void update_channel(unsigned int channel, unsigned int width);
void update_channels(unsigned int *widths);
void destroy();
#endif //SERVER_PPMER_H
I say almost because although I can generate the first 8 waves, unfortunately, I can't manage to have the break between the waves.
Joan, could you assist me with this, please?
bem22
Wed Jan 08, 2020 4:44 pm
Here's a function call of the above.
int main(int argc, char *argv[]) {
    init(4, 8, 20);
    update_channel(0, 1500);
    destroy();
This is the output on the oscilloscope.
This is almost what I want, but if you look at the last pulse (highlighted by the cursor), it's only 600ms, whereas it should have been 300 and then ~11000 gap.
I debugged this and every function call seems fine. I don't know what to do next
deepo
Wed Jan 08, 2020 8:05 pm
I don't know whether it's relevant, but this line in int microsleep(long tms):
The n in nsec indicated nano seconds, but it's initialised with micro seconds. You need to multiply with a further 1000 to get nano seconds from the input value in milli seconds.
Right?
/Mogens
deepo
Wed Jan 08, 2020 8:16 pm
And these lines in int init(unsigned int gpio, int channels, int frame_ms):
I'm not sure, but shouldn't they be separate values, and not an expression of the same value in seconds, milli seconds and micro seconds?
I mean if frame_ms was 1500 shouldn't frame_s=1 and frame_ms=500?
This code in void update():
This code seems to require frame_s and frame_us to not be representing the same value.
/Mogens
bem22
Sun Jan 12, 2020 2:15 am
You were right.
https://electronics.stackexchange.com/q ... pberry-pi/
Here's the code, guys
snroeust
Wed Feb 10, 2021 7:26 pm
Even though this post is a little old, it is the first goole entry on ppm output from rpi.
I have tried the python code, it works well but is a little slow. (46 updates/sec) on raspberry pi zero.
does anyone have ways to make this faster?
