ChriWo
Problem mounting network drive with fstab after change to SMB2 in NAS with jessie
Sat Aug 25, 2018 2:45 pm
changed in the NAS from SMB1 to SMB2 with stretch I can connect to the NAS but with jessie not!
I have added in /etc/samba/smb.conf
# SMB2 and SMB3
client min protocol = SMB2
client max protocol = SMB3
content of fstab
//192.168.1.200/Temp /media/DS-Temp/ cifs defaults,username=RasTest,password=RasTest,x-systemd.automount,x-systemd.requires=network-online.target 0 0
Thanks for the help
DirkS
Re: Problem mounting network drive with fstab after change to SMB2 in NAS with jessie
Sat Aug 25, 2018 3:31 pm
Maybe you need to add the vers= option (probably 'vers=2'; google for possible values)
DirkS
Sat Aug 25, 2018 4:28 pm
ChriWo wrote:
Sat Aug 25, 2018 4:24 pm
sorry not working :(
Did you investigate a bit yourself or just use my suggestion.
As I said: you need to search for valid values...
ChriWo
Sat Aug 25, 2018 5:18 pm
I try since 3 days ...
I also installed the smbclient (sudo apt-get install cifs-utils smbclient)
with this i can connect to the NAS with the following command
smbclient -U RasTest%RasTest -L //192.168.1.200/
I can connect to the NAS, but with
content of fstab
(and several version=2.0, version=2, ver=2.0, ver=2)
or if I use the
sudo mount -t cifs -o vers=2,username=RasTest,password=RasTest //192.168.1.200/Temp //media/DS-Temp
sudo mount -t cifs -o version=2,username=RasTest,password=RasTest //192.168.1.200/Temp //media/DS-Temp
sudo mount -t cifs -o vers=2.0,username=RasTest,password=RasTest //192.168.1.200/Temp //media/DS-Temp
sudo mount -t cifs -o version=2.0,username=RasTest,password=RasTest //192.168.1.200/Temp //media/DS-Temp
I canot connect the the share.
ChriWo
Sat Aug 25, 2018 6:22 pm
It is working ... :D
new content of fstab
//192.168.1.200/Temp /media/DS-Temp/ cifs vers=2,username=RasTest,password=RasTest,x-systemd.automount,x-systemd.requires=network-online.target 0 0
delete = defaults
add = vers=2
