buczoprazy
No static ip config file before first boot
Wed Sep 12, 2018 4:38 pm
Hi
Is any one know how to setup static ip before first boot please?
I have no access to router and I can not scan network. I have not access to connect raspberry locally using HDMI. I am using windows so I have no access to etc folder on sd card. Only what I can do is change a setting file on boot partition.
Could any one tell me why that is so difficult to set up one of the most important thing please?
I should be able to setup everting from configure file, and after first boot I should be able to connect using ssh.
Please is there any solution please?
jbudd
Re: No static ip config file before first boot
Wed Sep 12, 2018 11:11 pm
I think most people would be able to scan their network (Angry IP scanner on your PC, Fing on a mobile phone etc.) If for some reason you can't scan the network, how will you choose a static IP address that is not already in use?
But anyway, probably the best way to get access to the ext4 partition from a PC is to boot the PC from a live Linux DVD or USB.
DirkS
Thu Sep 13, 2018 6:57 am
Try adding the ip address on the kernel command line. Add it at the end the first line of /boot/cmdline.txt
e.g.
ip=192.168.1.101
Boot, log in and add make the change permanent and remove the ip from cmdline.txt
Alternatively: don't use static, but use the name: raspberrypi.local
You may have to install Bonjour if you have a windows PC or Avahi on a Linux PC.
buczoprazy
Thu Sep 13, 2018 7:27 am
e.g.
ip=192.168.1.101
Thanks for reply, adding ip=10.0.0.1/21 do not work.
I can not use raspberrypi.local, there is no dhcp.
I have ip mask and dns, and I have only access to boot partition. No hdmi device no linux device with sdcard slot.
jbudd
Thu Sep 13, 2018 7:31 am
Boot your pc from a live Linux dvd.
DirkS
Thu Sep 13, 2018 7:57 am
Wrong format. Leave out the '/21' and try again.
If that does not work then see https://www.kernel.org/doc/Documentatio ... fsroot.txt. Look for 'ip='
ip=10.0.0.1:::255.255.248.0
Odd address, BTW
Nothing to do with DHCP. Please search for mDNS, Zeroconf, avahi and / or Bonjour on this forum
Thu Sep 13, 2018 8:06 am
Hi
By default most Routers issue IP Addresses via DHCP, therefore if both your Windows PC and the RPi are connected to Router you only need to follow*:
https://www.raspberrypi.org/documentati ... /README.md
3. Enable SSH on a headless Raspberry Pi (add file to SD card on another machine)
* if you use NoobS to create the SD Card then forget above, I have no idea how NoobS functions !
mattmiller
Thu Sep 13, 2018 8:16 am
AFAIK using names to find access your pi on a windows network is still broken (very unreliable) following a windows update back in spring so its not an option at the moment
DirkS
Thu Sep 13, 2018 8:21 am
That's on Win 10 of course.
For me it has always been on and off for years and it's still the same.
On my fully updated Win 10 machine It is certainly not more broken than before.
buczoprazy
Tue Apr 21, 2020 12:37 pm
Odd address, BTW
Your solution work perfect! THANK YOU!
