geekinchief
SSH over USB with Raspberry Pi 3B?
Thu Sep 27, 2018 7:16 pm
I want to control my headless Raspberry Pi 3B via a USB cable connection to my PC. I know how to do this (and it works really well) for the Pi Zero W, but following the same instructions for the 3B doesn't work.
Re: SSH over USB with Raspberry Pi 3B?
Thu Sep 27, 2018 7:30 pm
USB requires a Host / Client relationship.
The RPi Zero can run in either Host or Client (on the go / gadget mode)
https://blog.gbaman.info/?p=791
The RPi 3B can like your PC can only be a USB Host, therefore what you wish to achieve is not feasible....
....unless you use a USBNET Cable:
https://www.raspberrypi.org/forums/view ... 6&t=131042
sajeevank
Mon Jul 15, 2019 9:14 am
Shall You share the steps required for communicating Raspberry Pi 3 B+ with an Ubuntu Laptop, through SSH, with USBNET cable?
I think USBNET cable need to be connected to one of the USB Host ports of Raspberry Pi 3 B+(not in USB slave port). Right?
drgeoff
Mon Jul 15, 2019 9:29 am
Neither RPi3B nor RPi3B+ has a USB slave port. Only host ports.
Mon Jul 15, 2019 12:05 pm
removed as unhelpful response.....
Last edited by fruitoftheloom on Mon Jul 15, 2019 12:47 pm, edited 2 times in total.
thagrol
Mon Jul 15, 2019 12:12 pm
Correct. But a "UBSNET" cable (i.e. one designed to connect two USB hosts via a fake ethernet link) should make that a moot point.
Unfortunately I don't have one so can help directly.
If the "USBNET" cable present to each end as an ethernet devicve it should be just a matter of configuring the interfaces apropriately.
